| Robnxious |
Mar 18 2017, 01:45 PM
RobnxiousOne ![]() ![]() Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
I bought one of these, but could never get it to work right with my stock 1.8 FI. Probably need a 6 to get it up to 88 MPH (IMG:style_emoticons/default/av-943.gif) |
| thelogo |
Mar 19 2017, 12:41 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Carbs, Best drivability are Dellortos 36mm for your engine. Next would be Webers, Italian, Spain, avoid all else unless you have to. These will be 40mm 44 and 48 are to big. BTW, them Germans being crafty bastards happened to us carbs, on some of the European 914s. And I am not talking 914-6s I am talking -4s Some times you can find these also. I would also not shy away from the single barrel dual carb units on a basic 1.7L build. Used a lot in the VW crowd, and a re a good little carb if your not looking for big numbers. Here is a set of Redline Weber single carbs, $419 not sure of quality And a good article on understanding VW carbs. And Ebay Dell 36mm complete kit, there about, you will also need a fuel pump. I like the CB Performance Rotaries. I think the redlines you had the link for seems perfectly doable But the photo showed the manifolds that didnt seem to be for a 914? But being as my 1sr car was a baja bug and my neighbors builds class 5 bajas . They always use a single carb dual throat weber over dual setup With dual port curved manifold and the carb in a airbox I guess its easier to protect 1 vs 2 No cross linkage No multiple fuel lines Since it will be taking a beating they avoid the dual setup So i wouldn't be opposed to that setup But any guy selling a single carb 914 manifold is probably a asshole (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/smash.gif) |
| mgphoto |
Mar 19 2017, 08:24 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Carbs, Best drivability are Dellortos 36mm for your engine. Next would be Webers, Italian, Spain, avoid all else unless you have to. These will be 40mm 44 and 48 are to big. BTW, them Germans being crafty bastards happened to us carbs, on some of the European 914s. And I am not talking 914-6s I am talking -4s Some times you can find these also. I would also not shy away from the single barrel dual carb units on a basic 1.7L build. Used a lot in the VW crowd, and a re a good little carb if your not looking for big numbers. Here is a set of Redline Weber single carbs, $419 not sure of quality And a good article on understanding VW carbs. And Ebay Dell 36mm complete kit, there about, you will also need a fuel pump. I like the CB Performance Rotaries. I think the redlines you had the link for seems perfectly doable But the photo showed the manifolds that didnt seem to be for a 914? But being as my 1sr car was a baja bug and my neighbors builds class 5 bajas . They always use a single carb dual throat weber over dual setup With dual port curved manifold and the carb in a airbox I guess its easier to protect 1 vs 2 No cross linkage No multiple fuel lines Since it will be taking a beating they avoid the dual setup So i wouldn't be opposed to that setup But any guy selling a single carb 914 manifold is probably a asshole (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/smash.gif) You will hate the way it runs with FI cam... This is a sports car not a bus. |
| 914forme |
Mar 19 2017, 09:08 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Class 5 is a different animal and you are correct, the mantra is keep it simple.
I would go after a set of Dells before I went with any weber variants. The Dells have an extra transition circuit in them, make the more linear in the response. To do a carb system correctly you will also need to find the now rather unobatiuum Mallory Unilite dizzy. Or go with a stand alone coil pack setup. Don't forget the cam, and headers, the 1.8L heads can be pretty good, 2.0L are better, but have a bunch of problems and finding good ones, next to impossible. Don't forget headers also. Unless you need heat. I ran just seat heaters in mine, keep the wife happy. I need to save some coin and get a set of headers on my -6, Chris will be my call. So again, this would be my build if you can find th pieces to do it. 1.8L 96mm pistons stock bored over, or if you can find round Das go for them. Keith Black Pistons. Cam depends on EFI or Carb 1.7Litter rockers modified to clear the 911 swivel foot adjusters. valve train geometry set, some times stock rods are dead on, it is odd, I got lucky. Solid spacers on the rocker arms Do not vent the heads, if they ae vented plug them. EFI D-jet you have to keep the stock dizzy, everything else will be dependent on what you do. Header If you need heat, SS heat exchangers, tubing slightly bigger than stock, and a 2.0L banana, you can make them into a sport muffler if you want dual pipes hanging out back. Or rally and cap two or one depending on what your doing. Better oil pump, or dry sump it Street you can keep the simple stock setup, though I would make it full flow. I am a huge fan of EFI, and have considered changing my -6 over, but the cost of TBs have keep me from doing that currently. I am running a coil pack independent ignition system from Simple Digital Systems called the CPI. Why because my 914-6 came with a Mallory Dizzy, can't find the parts, I have a Bosch, but figured why mess with points, confessors, and compromise. If you want to do EFI, It is as simple as stock intake runners, and using modern components to replace the aging D-jet stuff, as discussed here all read. Or you can go individual runner TBs, but a single TB in a common manifold is a very good system for a street car, and it is quite. So now the key is pull the trigger and do something anything really. (IMG:style_emoticons/default/poke.gif) We can build these things in our heads millions of times over it is getting out and doing that separates you from the rest of the pack. Some people are died in the wool think Porsche VW engineers where the best and would only build the best they could. That is true when given free rein and no budget, unfortunately the 914 was built to be sold as a mass produced car, lots of compromises. So it is your turn to make the car the best version you want it to be. If that is dropping a slightly warmed over type-4 cool, if it is a -6, cool, if it is a subaru, or LS, or even a TDI, I say cool go for it. It is your ride enjoy it, make it your own, just make it. (IMG:style_emoticons/default/poke.gif) Last two paragraphs was also for me, to get off my ass today and spend some time in the shop, building the -6. |
| Dave_Darling |
Mar 19 2017, 01:51 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
If you do go with a single-carb setup, consider heating the manifolds. The Beetles with the single carbs had heat risers to try to keep the fuel mixed into the air; most of the setups for the Type IV engine give you long unheated intake pipes which are very prone to fuel drop-out.
Realize that there isn't a lot of expertise around single-carb setups on a 914. Most people who have them don't deal with them at all and just accept however they run as how the car runs. --DD |
| 913B |
Mar 19 2017, 05:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 864 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:23 AM |
