2 Pages V < 1 2
> any 914 enthusiests who did away with pop up headlight?, if you know of anyone?what did they do for headlights?
Rocky
post Apr 5 2017, 08:47 PM
Post #21
From the cockpit
Nice job Craig! That's a bitchen look for sure!
boxstr
post Apr 5 2017, 08:56 PM
Post #22
The car went to Canepas, and was sold to Bruce Levin, who is up there in your neck of the woods Rocky.
Craig at CAMP
dlkawashima
post Apr 5 2017, 09:23 PM
Post #23
A lot of info for pop-up headlight delete options in this thread:
http://www.914world.com/bbs2/index.php?showtopic=213472
mlindner
post Apr 6 2017, 04:47 AM
Post #24
Pop-up delete. Just added driving lights up front. Best, MarkAttached Image
AZBanks
post Apr 6 2017, 07:44 AM
Post #25
I've been working on something similar on my 944 Cab.
The burgundy car was my inspiration and the white one is my work in progress.
AZBanks
post Apr 6 2017, 07:50 AM
Post #26
Here is s shot with a better view of what I am doing.
I have thought of making this a kit for the 944. I could build up something similar for the 914.
VaccaRabite
post Apr 6 2017, 07:52 AM
Post #27
En Garde!
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-1435-1491486777.1.jpg)
I can tell you that if you put driving lights or headlights on your bumper, you _will_ need to treat them like high beams.
I had so many people flash me for using my driving lights. The low placed lights reflect up off the road and blind oncoming traffic. These days I treat them just like high beams and don't use them if there opposing traffic.
If your head lights are low on the bumper, and you don't have any higher placed lighting options, you are going to piss off traffic and eventually get noticed by the police. Your state may have ways around this (if you are registered as a hot rod or kit car or something). YMMV.
Zach
Mike Fitton
post Apr 6 2017, 08:19 AM
Post #28
QUOTE(GregAmy @ Apr 5 2017, 11:22 AM) *
I find it funny that the high-demand mod for 911s is to add pop-up headlights (Kremer look) and yet we want to remove them...
Not anymore on the 911's, that was back in the 80's slant nose look.
Mike Fitton
post Apr 6 2017, 08:23 AM
Post #29
QUOTE(AZBanks @ Apr 6 2017, 05:44 AM) *
I say hack away on the 944's & 968's they aren't worth squat!!
jmitro
post Apr 6 2017, 11:09 AM
Post #30
QUOTE(Mike Fitton @ Apr 6 2017, 09:23 AM) *
QUOTE(Rand @ Apr 5 2017, 03:33 PM) *
These cars are now appreciating rapidly, so please think about it before you start stabbing it to death.
kinda off topic, but I'd argue the 968 IS or WILL BE worth squat; the 914 is so plentiful that it really doesn't matter if a few are hacked up.
I personally don't like modifying a car away from its original appearance (other than maybe a factory special edition) but I say....hack away on ANY car - it's YOUR car.
post Apr 6 2017, 11:26 AM
Post #31
Resident German
QUOTE(My 914 @ Apr 5 2017, 07:03 PM) *
I like the chopped roof a lot. Improves the lines of the car tremendously, especially with the flares.
If you're over 6' you may want to reconsider doing that. I've sat in that car and at 6,2 i was practically hitting the roof with meiner Birne ...
AZBanks
post Apr 7 2017, 01:04 PM
Post #32
QUOTE(Mike Fitton @ Apr 6 2017, 07:23 AM) *
They are starting to appreciate in value. Not as fast as 911's and 914's but prices are going up.
RJMII
post Apr 7 2017, 01:06 PM
Post #33
Jim McIntosh
QUOTE(SirAndy @ Apr 5 2017, 01:39 PM) *
Also worth noting, if you delete the popups and use lower mounted lights, that is most likely illegal as there are minimum height requirements for headlights.
4wd and 12 inches of lift should remedy that...
mgp4591
post Apr 7 2017, 09:27 PM
Post #34
QUOTE(AZBanks @ Apr 6 2017, 07:50 AM) *
The light looks pretty compact - where did you find them?
Front yard mechanic
post Apr 8 2017, 07:22 AM
Post #35
QUOTE(Mike Fitton @ Apr 6 2017, 06:23 AM) *
When was the last time you priced a nice 968! Try 20,000 and some change
rnellums
post Apr 9 2017, 09:11 PM
Post #36
Professional Enthusiast
I drove for 3-4 years with driving lights mounted in the fog location. Visibility was terrible with the lights mounted so low. Just went back to pop ups last year (LEDs) and couldn't be happier.
AZBanks
post Apr 9 2017, 10:42 PM
Post #37
QUOTE(mgp4591 @ Apr 7 2017, 08:27 PM) *
They were put together from two kits I picked up on ebay.
http://www.ebay.com/itm/H1-H3-H4-H7-H11-Xe...=item3f3699e08d
and
http://www.ebay.com/itm/271497426147?item=...123&vxp=mtr
I mounted the lights on aluminum brackets I made and mounted the brackets to steel supports I built.
The most challenging part was figuring out the wiring. The Projector headlights switch from low to high beam through the use of a little metal plate that blocks part of the light beam to create the low beam pattern. Voltage is passed to a switch that causes the plate to move out of the way for the high beam pattern. That circuit is completely independent of the circuit for the light beam itself. The entire operation and circuit structure is completely different than the operation and circuit structure of the factory lights. On the 944, the high and low beam circuits are completely separate. When the high beam circuit turns on, the low beam circuit turns off.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 2nd April 2026 - 08:12 AM
