> Quick Jack Assistance is Needed Please., One side is stuck up
913B
post Jul 18 2020, 05:40 PM
If anyone had run into this before or have any helpful tips, it would be appreciated. If not no worries I plan to call their troubleshooting hotline Monday.
I was able to lift a vehicle up then down, didn't really come all the way down but good enough to slide the QJ out and pretty much applied my weight on them to finish going all the way down. Curiosity got the best of me so I lifted them with no weight they both went up. And only one came back down slowly. The other side appears to be stuck and would not come down or up. It is currently stuck in the up position.
The thing I have tried is to ensure the side tank was pressurized to 50psi.
I tried swapping the hydraulic lines still that one side won't move. The other side works fine up and down. So it seems it's not the lines or the hydraulic unit. But the that particular cylinder?
Any thoughts for the weekend.
Thanks, everyone!
Aualexa1
post Jul 18 2020, 05:52 PM
https://help.quickjack.com/support/solution...ith-no-vehicle-
Maybe try adding a bunch of weight
Cairo94507
post Jul 19 2020, 06:45 AM
Michael
I agree with the weight. When I raise my lift (not a quick jack though) if there is not a car on it, it takes a long time to go all the way down. And in the winter time, it is really slow. I used the recommended hydraulic fluid BTW. Of course with a car on the lift it goes down quite nicely. (IMG:style_emoticons/default/beerchug.gif)
Olympic 914
post Jul 19 2020, 08:12 AM
Check the air pressure in the cylinders. Mine started acting wonky and the air was low.
I don't remember the pressure, But it will be listed in the manual.
Edit. Sorry i didn't see you already checked the pressure...…
914sgofast2
post Jul 19 2020, 09:00 AM
The Quick Jacks need weight on them to come down. Put a couple of cinder blocks on the one stuck in the up position, then hit the down function on the control button. If that doesn’t work, then slowly open the bleed screw on the offending lift, but don’t get your hand or fingertips caught when it crashes down!
Robarabian
post Jul 19 2020, 09:14 AM
914 A Roo
15 psi..
QUOTE(Olympic 914 @ Jul 19 2020, 07:12 AM) *
914werke
post Jul 19 2020, 11:35 AM
it says specifically in the instructions you must always have weight on the lifts when raising/lowering them
pilothyer
post Jul 19 2020, 09:56 PM
QUOTE(Robarabian @ Jul 19 2020, 10:14 AM) *
15 psi..
Put 50 PSI (NO MORE) in the cylinders. It won't take much as they are small, Their job is to return to full down position.
Coondog
post Jul 19 2020, 11:15 PM
Just stand on it while lowering.
913B
post Jul 19 2020, 11:48 PM
I tried stack a set of tire and wheels on it and no dice.
drem914
post Jul 20 2020, 07:55 AM
QUOTE(913B @ Jul 19 2020, 10:48 PM) *
I had the happened to me when I first bought mine and I set a bunch of cases of water bottles on it. You just need weight. when you call customer service they will say 300 lbs. (ask me how I know)
Robarabian
post Jul 20 2020, 08:24 AM
914 A Roo
Put them side by side.. you cant stand on just one the other will rise. Get the whole family and a few neighbors.. divide up the people and stand on both of them... with a few hundred pounds only, they will come down slow.
Robarabian
914 A Roo
The instructions say a max of 15... so be careful with that much pressure..
QUOTE(pilothyer @ Jul 19 2020, 08:56 PM) *
15 psi..
913B
post Jul 20 2020, 10:12 AM
Hmm my instruction manual says 50 psi max not 15 that’s kind of odd, maybe older models. I recently bought my QJ less than 1 yr ago. Good idea I will get the entire family to balance on them and see if they will go down.
KELTY360
post Jul 20 2020, 10:43 AM
914 Neferati
QUOTE(913B @ Jul 20 2020, 08:12 AM) *
Be sure to get pics of this. (IMG:style_emoticons/default/biggrin.gif)
eric9144
post Jul 20 2020, 01:53 PM
QUOTE(913B @ Jul 20 2020, 09:12 AM) *
Same, I have the 7500# version and it wanted 40-50 PSI--could be model dependent.
pilothyer
post Jul 22 2020, 11:22 AM
QUOTE(Robarabian @ Jul 20 2020, 09:24 AM) *
15 psi..
Watch this official Quick Jack Video (2:00 into the video starts the air it up part.)
QUICK JACK
913B
post Jul 22 2020, 04:21 PM
QUOTE(drem914 @ Jul 20 2020, 08:55 AM) *
Yup, that was the trick. I stacked a set of tires and my kids and I stood on it, >#300
I operated a few more times to bleed the system but just lifted to about the first lock.
It still needs a little assistance to finally rest all the way down, but hopefully, after time it will be better.
Thanks, everyone,
- Lo-Fi Version Time is now: 2nd April 2026 - 06:06 AM
