3 Pages V < 1 2 3 >
> Bluetooth while maintaining the look
Montreal914
post Mar 14 2021, 01:05 PM
Post #21
QUOTE(Jett @ Mar 14 2021, 09:47 AM) *
Cool solution!
We wanted to use BT but also the radio, so for each of our Blapunk’s a fellow name Matthias from Oldtimer-radio builds them. They use high quality parts and connects to the back DIN. With shipping from Germany these are about $110 USD, but click in the back of the stereo, connect BT, and go. No AMP though!
Related discussion.
http://www.914world.com/bbs2/index.php?sho...w=&st=&
Very nice! Any of these DIN plugs in the back of the Original Blaupunkt for signal output to connect to an amp?
moldygreg
post Mar 15 2021, 11:46 AM
Post #22
Stay Golden
QUOTE(Montreal914 @ Mar 14 2021, 12:05 PM) *
Cool solution!
Related discussion.
Just got mine today. Will fit in an altoid tin -- pretty slick.
stickyfingers
post Mar 15 2021, 12:20 PM
Post #23
QUOTE(moldygreg @ Mar 15 2021, 12:46 PM) *
Cool solution!
Related discussion.
Nice. Enjoy.
moldygreg
post Mar 15 2021, 01:18 PM
Post #24
Stay Golden
QUOTE(stickyfingers @ Mar 15 2021, 11:20 AM) *
Cool solution!
Related discussion.
Nice. Enjoy.
Bench tested. Fired right up. Zero bluetooth connection finickiness.
Much better than an 'aux' plug Woody hidden radio I am replacing it with.
Two thumbs up! (IMG:style_emoticons/default/piratenanner.gif)
stickyfingers
post Mar 15 2021, 01:23 PM
Post #25
Glad to hear. It’s crazy how quickly it connects.
914forme
post Mar 15 2021, 02:15 PM
Post #26
To connect both radio and amp, you can place a zener diode on each circuit this will block the back feed of power through the circuits, and keep the magic smoke in the components.
Just takes 4 of them one on each 12V Positive leg, I guess I could diagram it out, but it is not hard just need to remember which way the stripe goes. It should work. Or you can use a switch and a relay, to pick the source you want. It will require 2 relays.
Im going to try one of these in my Boxster build
Rotary'14
post Mar 15 2021, 03:55 PM
Post #27
I got rid of stock radio, and mounted this on the blank cover. All you see is the volume/power knob.
https://www.amazon.ca/Bluetooth-Audio-Recei...207&sr=1-12
Pretty close to your system.
-Robert
stickyfingers
post Mar 15 2021, 04:48 PM
Post #28
QUOTE(Rotary'14 @ Mar 15 2021, 04:55 PM) *
-Robert
Nice. That works. I wanted to maintain the classic look with the original radio.
bkrantz
post Mar 15 2021, 08:35 PM
Post #29
Not quite the same, but I am thinking about using this (with no visible radio).
https://www.crutchfield.com/p_020CMS20/Clarion-CMS20.html
moldygreg
post Mar 15 2021, 08:47 PM
Post #30
Stay Golden
QUOTE(bkrantz @ Mar 15 2021, 07:35 PM) *
Yes. Was looking at Out Of Sight Audio as well.
For $20 bucks, I find it just this solution to good to pass up. Actually sounds better than the Woody's hidden radio I have.
Really impressed how easily it connected to bluetooth.
FWIW, I have the Porsche Classic Radio / Navigation in my 911sc. And it's slow to connect to bluetooth.
If I could've found a blaupunkt monterrey, I would've used this sytem in that car.
stickyfingers
post Mar 15 2021, 08:56 PM
Post #31
To be honest you’d never look at the unit. I got my phone mounted in the 3D printer ashtray with a MagSafe so I get my waze directions over Bluetooth and sweet music. And as moldygreg mentioned for $20 it’s worth the effort to install over other more pricier options. I’m going to upgrade my speakers next to get some more fuller sound. The speakers I have in there are not the best but very functional. I’d like to blast the music a little louder with top off. Lol.
Montreal914
post Mar 15 2021, 09:08 PM
Post #32
@Jett
My question in post #21 got lost in all of the enthusiasm of this blue tooth option. (IMG:style_emoticons/default/smile.gif) If you get a chance to read it and comment, I would appreciate. (IMG:style_emoticons/default/beerchug.gif)
Jett
post Mar 15 2021, 09:27 PM
Post #33
Cool solution!
Related discussion.
I connected the BT unit via DIN, no AMP. When there is no BT connection the radio plays as normal, but when the iPhone is connected it changes source. I play music from Alexa (IMG:style_emoticons/default/smile.gif)
This retains the stock radio functionality but adds an additional music source.
stickyfingers
post Mar 25 2021, 11:22 AM
Post #34
Just wanted to provide an update. I have moved on to a different amp altogether - still a cheap alternative so that I can add a powered sub.
I have tested this on the bench outside the car and the sound is amazing. The sub is a little big at 6x9 inches but I think I can mount it behind the existing radio (next to the gas pedal - eek). Car is in the shop for another couple of days so when I get it back I'll get it mounted and send some updates. The sub is really impressive at a low cost.
https://www.amazon.ca/gp/product/B07VRJ5WNH...=UTF8&psc=1
This is the new amp:
https://www.amazon.ca/gp/product/B07DB52812...=UTF8&psc=1
CoronaMike
post Mar 25 2021, 01:10 PM
Post #35
Here's MY bluetooth solution.
It's plenty loud, has great bass, only needs to be charged once a month or so, and is easy to take out if needed. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/aktion035.gif)
stickyfingers
post Mar 25 2021, 01:13 PM
Post #36
QUOTE(CoronaMike @ Mar 25 2021, 03:10 PM) *
I had a bose bluetooth speaker - was pretty good but wanted to go with the semi-traditional approach. I had to charge it every few days. Got annoying for me but nevertheless any approach is a good approach as long as it works for you.
Jett
post Mar 25 2021, 01:56 PM
Post #37
QUOTE(stickyfingers @ Mar 14 2021, 09:48 AM) *
QUOTE(Jett @ Mar 14 2021, 11:47 AM) *
Cool solution!
nice - Did you have to ship him the radio?
No, I just told him what I have. That said, he does restore all of our radios (IMG:style_emoticons/default/smile.gif)
Rotary'14
post Mar 25 2021, 01:59 PM
Post #38
QUOTE(Montreal914 @ Mar 15 2021, 07:08 PM) *
@Jett
You can use one of these and input your stock radio into bluetooth amp's input plug.
https://www.amazon.com/Converter-BOSS-Audio...la-440197526529
But not sure if this answers your question,,,
stickyfingers
post Mar 25 2021, 02:08 PM
Post #39
Is that needed only if there is noise on the line?
Rotary'14
post Mar 25 2021, 02:54 PM
Post #40
QUOTE(stickyfingers @ Mar 25 2021, 12:08 PM) *
The device I listed converts the speaker output, to RCA level output, I doubt it filters noise in your signal, but it prevents the aux input circuit on BT amp from getting too much voltage, if I remember correctly it's 0-5v for RCA level inputs.
3 Pages V < 1 2 3 >
- Lo-Fi Version Time is now: 2nd April 2026 - 09:10 AM
