| SirAndy |
May 20 2021, 02:25 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
http://www.914world.com/specs/bodydims.php
http://www.914world.com/specs/underdims.php Ideally, most of this work would be done on a celette bench. http://www.914world.com/bbs2/index.php?s=&...t&p=2868545 (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-419-1606081064.jpg) |
| wonkipop |
May 20 2021, 05:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,480 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
http://www.914world.com/specs/bodydims.php http://www.914world.com/specs/underdims.php Ideally, most of this work would be done on a celette bench. http://www.914world.com/bbs2/index.php?s=&...t&p=2868545 (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-419-1606081064.jpg) if there was one of those in aus we'd use it too. with a heap of steel bracing. and one panel at a time if possible. very interesting to see on this site discussion and photos of that bench. valuable resource to have and for it to still be around. |
| KBMC1304 |
May 23 2021, 05:33 PM
Member ![]() ![]() Group: Members Posts: 227 Joined: 23-January 21 From: Algiers Member No.: 25,113 Region Association: France |
With no door bracing from what I can see, what are you doing to prevent twisting while welding? thank you for your advice. I will do it. (IMG:style_emoticons/default/agree.gif) for the moment I'm cleaning the floor from the rust |
| KBMC1304 |
http://www.914world.com/specs/bodydims.php http://www.914world.com/specs/underdims.php Ideally, most of this work would be done on a celette bench. http://www.914world.com/bbs2/index.php?s=&...t&p=2868545 (IMG:style_emoticons/default/idea.gif) (IMG:http://www.914world.com/bbs2/uploads/post-419-1606081064.jpg) thank you |
| KBMC1304 |
May 23 2021, 05:36 PM
| KBMC1304 |
May 23 2021, 05:39 PM
I would like to know what is the best alternative to restore my 914/6 and increase its selling value.
Keep engine stock or performance rebuild? |
| gereed75 |
May 24 2021, 05:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
Khaled, Not sure what the attitude is in your part of the world but since you do not have the original motor anyway, I would think a 2.2 or 2.4 carbureted S motor would be an “attractive” choice.
What motor came in most ‘72 sixes from the factory? |
| rgalla9146 |
May 24 2021, 05:47 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
I would like to know what is the best alternative to restore my 914/6 and increase its selling value. Keep engine stock or performance rebuild? Given the extensive metalwork that your car has needed and the approach you've taken you should feel free to go with a higher performance engine. Without the original engine you have good reason to do as you like. |
| Cairo94507 |
May 24 2021, 07:10 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Since your original 2.0 911 T motor is gone (sadly) the replacement depends upon what your finances can handle. I think any of the 911 motors are terrific in these cars. Of course a bit of horsepower/torque in a 914 is always fun. (IMG:style_emoticons/default/beerchug.gif)
| KBMC1304 |
May 24 2021, 07:43 AM
I found the original engine 901/38 642... (IMG:style_emoticons/default/smilie_pokal.gif) . that is why I asked you if a keep it stock or performance
| Root_Werks |
May 24 2021, 08:43 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,929 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Number matched cars always fetch more money. If you put a different engine in the car, keep the original engine to sell with the car.
| rgalla9146 |
May 24 2021, 09:07 AM
I found the original engine 901/38 642... (IMG:style_emoticons/default/smilie_pokal.gif) . that is why I asked you if a keep it stock or performance Please tell how you connected with the original engine. Was it in Algeria ? As for stock or modified I'd correct the known faults of that era engine and modify it without changing the block beyond return to stock. Build a 2.0S or a 2.2 S |
| KBMC1304 |
May 24 2021, 02:40 PM
I found the original engine 901/38 642... (IMG:style_emoticons/default/smilie_pokal.gif) . that is why I asked you if a keep it stock or performance Please tell how you connected with the original engine. Was it in Algeria ? As for stock or modified I'd correct the known faults of that era engine and modify it without changing the block beyond return to stock. Build a 2.0S or a 2.2 S I asked the former owner where the engine was exchanged. luckily the mechanic is still there. Then the engine was sold in France and since it stayed with the same owner. I asked Mittlemotor for an upgrade, they told me its possible to increase it power to 200/220 HP |
| KBMC1304 |
May 25 2021, 11:32 AM
| KBMC1304 |
May 25 2021, 11:33 AM
| KBMC1304 |
May 27 2021, 03:19 PM
| KBMC1304 |
May 27 2021, 03:45 PM
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.servimg.com-25113-1622151940.1.jpg)
does anyone know the rubbers references? |
| rgalla9146 |
May 27 2021, 03:55 PM
The blue circled hole is not original. The green circled hole is for the fuel pump wire.
Don't loose the two hole plugs they're hard to find. The single fuel supply hose for a 6 goes through the open oval hole with a black tubing grommet. |
| Root_Werks |
May 27 2021, 05:27 PM
Red circle = factory plugged rain tray drain? On a 1972 914-6 maybe they left them stamped, then plugged them?
| rgalla9146 |
May 28 2021, 05:52 AM
Red circle = factory plugged rain tray drain? On a 1972 914-6 maybe they left them stamped, then plugged them? They were plugged on all 6s....no rain tray Only one fuel delivery on a 6, other oval hole plugged in engine tray The oval nylon plug is a tough one to find. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:10 AM |
