| Geezer914 |
Jan 27 2022, 06:46 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,260 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Does anyone make a replacement channel? Or if it is perforated, can it be repaired using fiberglass mat and POR 15?
| mepstein |
Jan 27 2022, 07:23 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Restoration Design sells it. Maybe 914rubber.
| Jett |
Jan 27 2022, 07:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,697 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest
Just saw the metal on 914Rubber… we need some for a new project (IMG:style_emoticons/default/smile.gif)
| Mark Henry |
Jan 27 2022, 07:51 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
THIS IS THE 914 PO-PO! (IMG:style_emoticons/default/busted_cop.gif)
Step away from the fiberglass sir! (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/slap.gif) |
| 76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Just finished my rain channel repair today and used 914rubbers channel. It's spot on and is the correct metric thickness. Each order contains two pieces. One wide and one narrow. Together they form the channel. (IMG:style_emoticons/default/beerchug.gif)
| bkrantz |
Jan 27 2022, 09:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Does anyone make a replacement channel? Or if it is perforated, can it be repaired using fiberglass mat and POR 15? Fiberglass? Don't be THAT guy. (IMG:style_emoticons/default/shades.gif) |
| SKL1 |
Jan 27 2022, 10:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,778 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
And after your project Bob, if anyone should know, it's you!
| Mikey914 |
Jan 28 2022, 02:22 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Metal is 48" long so you may need more than one set, but it works well.
Cary asked us to make these right so we did. Relatively inexpensive and looks OEM. Thay are here https://914rubber.com/front-trunk-metal-for-porsche-914 Attached thumbnail(s) |
| Geezer914 |
Jan 28 2022, 03:22 AM
Thanks for the replies!
Lo-Fi Version | Time is now: 2nd April 2026 - 06:49 AM |
