| SirAndy |
Feb 23 2005, 07:28 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
unless ... he's got a DSL router, in which case the router and the DSL modem have a static IP because they're in one box ! (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
| SirAndy |
Feb 23 2005, 07:29 PM
thanks ! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
| vortrex |
Feb 23 2005, 07:33 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
this is a possibility but I think this is pretty much just two devices in one chassis, so I think the modem (DSL interface) would still have the private IP and the router half would get the public IP from the ISP. EDIT: I looked it up on the qwest website, he probably has the Actiontec® GT701-wg device which is an all-in-one DSL/router. it has a private IP and the public CPE IP given from qwest. so it's just two devices in the same box. |
| Rockaria |
Feb 23 2005, 08:12 PM
ZippidyDoDah... ![]() ![]() ![]() Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
I have this exact same device. Turn it off, wait, turn it on and it should get a new IP. If not call qwest and they can change it for you. I have had to do that before on mine. Committe tech support at its best... Oh Yeah, Try and reboot the box with a chopstick... But don't break it off man... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
| Rockaria |
Feb 23 2005, 08:17 PM
| Twystd1 |
Feb 23 2005, 08:43 PM
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,515 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 |
I R thunk it R broke...
Twystd1 |
| redshift |
Feb 23 2005, 09:19 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Why are we helping Eric?
We aren't. So, there. M |
| bd1308 |
Feb 23 2005, 09:41 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
okay I have your solution. Had the EXACT SAME PROBLEM. here's what you do.....first unplug your DSL/Cable modem and yell at it until you feel your throat getting sore. Then, you go to your breaker box and take out every OTHER breaker except the computer/router one. Then you Overclock your computer and make it run real crappy and instable. Lastly, you take a regular ethernet cord, and instead of hooking it to your cable modem, you take the receiving pairs to 120VAC common and the sending pairs to 120VAC hot. The computer will love it. BUT, wire it up to a switch. After that, you buy some platic explosive and line your cable modem with it and attach the ignition lead to that very switch. Stand 10 feet away and watch all of your problems dissapear at the flick of the switch. Then go outside and work on your 914...worked for me!
| Eric_Shea |
Feb 24 2005, 09:09 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Good Morning Andy (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Anyone have a line on plastic explosives? |
| Rockaria |
Feb 24 2005, 10:46 AM
Sure, Wideboy: Attached image(s)
| Rockaria |
Feb 24 2005, 10:47 AM
Or Narrow:
| Eric_Shea |
Feb 24 2005, 02:02 PM
Good afternoon Andy (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
| redshift |
Feb 24 2005, 02:15 PM
What about Bob? What about Bob?
M |
| SirAndy |
Feb 24 2005, 03:21 PM
any luck with getting a new IP address ??? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
| Eric_Shea |
Feb 24 2005, 05:28 PM
Is that what you want me to do?
Should I call Qwest to do this or is there some other way such as winipconfig, release all etc...?? |
| Rockaria |
Feb 24 2005, 05:39 PM
There is only 2 ways to get a new IP on the qwest box. 1) Call Qwest Tech support and ask. 2) Turn off the modem/router for the night and you should get a new address in the Morning when you turn it back on. At least Mine does. If yours does not, You need to call qwest. |
| Eric_Shea |
Feb 24 2005, 05:46 PM
I've unplugged mine about a dozen time since this has happened... does that count or does it have to be a certain period of time.
I'll just call Qwest. |
| redshift |
Feb 24 2005, 05:49 PM
Eric, how long is a piece of string?
ROFL Why don't you just call Qwest? M |
| SirAndy |
Feb 24 2005, 05:50 PM
your modem get's what's called a "lease", so if you just recycle your modem, it won't get a new IP because your lease has not yet expired. as i said some 20 posts ago, either leave the modem off for long enough (which entirely depends on how qwest has set up their lease-config) or call them and have them manually expire it for you to make sure you get a new IP ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
| Rockaria |
Feb 24 2005, 05:52 PM
I have noticed it takes anywhere from 5 to 12 hours being off before it will get a new IP. Call qwest and it will be at least 20 minutes of holding. But that is faster. |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:15 PM |
