| rhodyguy |
Jul 18 2005, 08:08 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
surprizing cr. it's been a while since i visited your site. i look forward to the feature when you post it. when? 78mm(?), and i'm doing the fomula backwards to figure the piston size.
k |
| Jake Raby |
Jul 18 2005, 08:30 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
90.5 mm bore.. its a 78.4mm crank...
I used a TI 90.5mm piston inside a Nikisil plated, rebored 90mm (1700) TIV cylinder. CR = Efficiency! It only has .035 deck to boot! |
| rhodyguy |
Jul 18 2005, 08:33 AM
save those good 1.7 cyl guys!! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) would those be oem or the "other" "nickies"? (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
k |
| cnavarro |
Jul 18 2005, 08:39 AM
Cylinder Guru ![]() ![]() Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None |
I plated a set of cast iron cylinders for Jake for that project- trying to improve the wear and oiling properties while getting a little more power from the reduction in friction. :-)
| Jake Raby |
Jul 18 2005, 08:42 AM
They aren' really Nickies... Just plated stock cylinders..
I am only doing it for friction reduction. I am doing this for friction reduction as well... And also to control windage. http://www.aircooledtechnology.com/r_d_superfinish.htm Thats not chrome plated fellas- Those parts have been RAT Super Finished! |
| Type 4 Unleashed |
Jul 19 2005, 12:46 PM
CREATIVE TYPE lV ENGINEERING ![]() ![]() ![]() Group: Retired Members Posts: 787 Joined: 20-June 04 From: Aliso Viejo, ca Member No.: 2,231 Region Association: None |
Jake, whats the cam advance here? 4 deg? And is it both in the cam and gear? or more one than the other? Whats it work out to, 2 deg a tooth?
| TravisNeff |
Jul 19 2005, 12:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
I thought on a type IV that the cam advance/retard was done by a selected cam gear itself, not by adjustment - no?
| Type 4 Unleashed |
Jul 19 2005, 01:31 PM
Yes and No, some cam companies make there cams with a 2 deg advance built in, some 0 deg, some of the type lV cam gears have a 2 deg advanced built in, some one may have there own gears made with a 4 deg advance. There are the adjustable strait cuts, Magnum gears, makes strait cuts for type 1, and now makes them for type lV, $225 Fat performance has them made by Pauter $325. Attached image(s)
| Type 4 Unleashed |
Jul 19 2005, 11:50 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) Attached image(s)
| DNHunt |
Jul 20 2005, 07:17 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
I didn't advance the cam at all. Looking at the picture it's not as clear as I would have liked but, the dot on the cam is between the dots on the crank. If there is any advance built into the cam I'm not aware of it.
I'm back on track. 15 of the 16 head studs are in. I'm waiting for one from Charles to finish that task. The missing one is in a blind bore so I'll assemble the case. Dave |
| DNHunt |
Jul 20 2005, 07:24 AM
Oil pressure relief pistons. I test fit them and the pistons are nice and free in the bore. So I laid out the pieces. It was finally time to get into the gasket kit. There is a copper sealing ring for the smaller assembly and an aluminum one for the larger
| DNHunt |
Jul 20 2005, 07:56 AM
The large one goes on the right side front on the bottom
| DNHunt |
Jul 20 2005, 07:59 AM
I found this old square from my dad and I used it with vice grips to tighten it. It fit the slot very well. Then a couple of taps with a mallet and chisel and it was seated real well
| DNHunt |
Jul 20 2005, 08:00 AM
The small one goes between the lifter bores on cylinder # 1.
| DNHunt |
Jul 20 2005, 08:02 AM
Here's a type 1 oil pump that's ready to go.
| DNHunt |
Jul 20 2005, 08:04 AM
Nice and clean and packed with a little grease
| root |
Jul 20 2005, 10:58 AM
Two Wheeled Type4 Completed! ![]() ![]() ![]() Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
Allright I was following along O.K. until you got to the type1 oil pump??
Why are you using a type 1 pump? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) By the way! This thread 'ROCKS!' (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
| groot |
Jul 20 2005, 12:04 PM
Dis member ![]() ![]() ![]() Group: Members Posts: 897 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Dave,
I think I topped your breaking the stud move. I tightened the case down while the front cam bearing was not set properly... thinking the case was binding up a dowel or something. Well, I cracked the front cam bearing journal. |
| Jake Raby |
Jul 20 2005, 12:18 PM
He is using a TI pump because it is far superior, it came in my kit and he is using my other oil system mods based on the TI pump.
My 3 liter is running the same pump- they rule. Tons of volume, better pressure and less HP draw from the engine.. |
| DNHunt |
Jul 21 2005, 06:00 PM
Still making progress. Here's something that's easy to overlook. Thermostat cable pulley. It goes where the Q-tip is.
Lo-Fi Version | Time is now: 2nd April 2026 - 12:40 PM |
