| orange71 |
Mar 20 2007, 03:09 PM
Newbie ![]() Group: Members Posts: 11 Joined: 12-March 07 From: CA Member No.: 7,597 |
Hey folks, just thought i'd take this chance to introduce myself.
I'm the new owner of a 1971 914-4 that has been in my family since my father bought it new back in the day. It's floated around my family until finally coming into my hands at the beginning of this year. It sat for the last 3 years and tooks minimal effort to get it back on the road. A fuel flush, new fuel, new battery, new tires and a tune-up and it's been a dream since I picked it up on Friday. Even took it for a long drive up the coast on sunday. Also, I saw a thread about wood dashes, this one appears to have a solid wood dash that was installed soon after it was bought, I'll try to post some pics when the weather clears up here. I've not got a BUNCH of questions and hope y'all don't mind me rattling them off here in hopes that everyone's experience can help catch me up quickly! 1) That lever that is just rear of the shift lever, what does it do? I can't find head not tail about it in any of my manuals! 2) I've taking the horn ring off and the 'Rubber Sleeve' that sits between the horn sleeve and the nut/steering wheel is missing. I also don't see anything that looks like a horn switch in there, not too much about it in my manuals, anyone got a picture or description of what should be in there? Any suggestions on where to go for the 'Rubber Sleeve'? 3) Shifting has gotten MUCH more difficult to the point that I can't get into 4th and 5th gears anymore! (as of last night) 2nd and 3rd gear appear to be extremely 'wide' on the shifter... does this sound like a simple adjustment or potentially a larger problem? (Mechanic who got her running/tune up did replace the transmission fluid) 4) The tab that is welded to the chassis to bolt to the engine cover just behind the seat has broken off. Does anyone make repro tabs or should i just have a body shop fab something up? 5) My rear trunk hinge on the right side has also come off it's weld and parts of it look in bad knack... can anyone recommend a body shop in/around San Francisco CA? |
| SirAndy |
Mar 20 2007, 03:23 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
... I've not got a BUNCH of questions and hope y'all don't mind me rattling them off here in hopes that everyone's experience can help catch me up quickly! 1) That lever that is just rear of the shift lever, what does it do? I can't find head not tail about it in any of my manuals! 2) I've taking the horn ring off and the 'Rubber Sleeve' that sits between the horn sleeve and the nut/steering wheel is missing. I also don't see anything that looks like a horn switch in there, not too much about it in my manuals, anyone got a picture or description of what should be in there? Any suggestions on where to go for the 'Rubber Sleeve'? 3) Shifting has gotten MUCH more difficult to the point that I can't get into 4th and 5th gears anymore! (as of last night) 2nd and 3rd gear appear to be extremely 'wide' on the shifter... does this sound like a simple adjustment or potentially a larger problem? (Mechanic who got her running/tune up did replace the transmission fluid) 4) The tab that is welded to the chassis to bolt to the engine cover just behind the seat has broken off. Does anyone make repro tabs or should i just have a body shop fab something up? 5) My rear trunk hinge on the right side has also come off it's weld and parts of it look in bad knack... can anyone recommend a body shop in/around San Francisco CA? (IMG:style_emoticons/default/welcome.png) now that we got that out of the way ... (IMG:style_emoticons/default/biggrin.gif) 1. heater lever. it has two functions, it opens the flapper boxes on your heat exchangers to let warm air into the cabin and if moved all the way up, it also switches on the heater fan in the engine compartement (if present) to pump even more air through your heat exchangers. 2. this sounds a bit confusing. i'm not sure you're talking about a stock steering wheel. could it be aftermarket? there are lots of those around. a pic would help ... 3. if your car was converted to a sideshift transmission, then that sounds like the cone setscrew at the firewall shifter coupler has come lose. if it still is a tailshifter, the screw at the end coupler could have come lose. also, now is probably a good time to replace *all* shift bushings, as they do wear over time. 4. / 5. Yeaman Autobody in Palo Alto. Scott Yeaman is a 914 guy himself, his guys know 914s and they do great work. or, if you're further up north, Original Customs in Napa does great work as well. Mark (the owner) is a regular here ... (IMG:style_emoticons/default/bye1.gif) Andy |
| AZ914 |
Mar 20 2007, 03:26 PM
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,469 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
2. Ok, if you removed your horn pad and are looking for a somewhat conical rubber part.. thats what keeps the metal rings on the horn pad and column apart. There shouls be a wire connecting the two as well. Pelican Parts may sell these 'horn replacement kits' or the like.
Welcome! |
| orthobiz |
Mar 20 2007, 03:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
Signal Orange or Tangerine? Brown or Black interior?
My first was a Signal Orange with a brown interior... Paul |
| orange71 |
Mar 20 2007, 04:18 PM
Thanks for the info guys....
Sir Andy: Glad i know what that darn flapper box lever does now! I believe I'm still a tailshifter, so I'll look into that now.. Thanks for the autobody recommendations! Andy/AZ: Steering wheel is stock and pelican DID have something for it under what you suggested AZ... Ortho... I'm actually not sure! Black interior though... maybe you can tell me from the pics? or i'll look up the color codes to figure it out soon (IMG:style_emoticons/default/smile.gif). The car in question: (IMG:http://www.neoedo.com/914/o71_0.jpg) Porsche windshield banner curtesy of my cousin 20 years ago (IMG:http://www.neoedo.com/914/o71_1.jpg) Why o why?!?! Bike rack bolted through holes drilled in the bodywork! Nice emblem though... and a racing exhaust from 15 years ago? (IMG:http://www.neoedo.com/914/o71_2.jpg) Driver and Passenger aftermarket mirrors (IMG:http://www.neoedo.com/914/o71_3.jpg) The stock steering wheel (and lovely wood dash of which i'm quite fond) (IMG:http://www.neoedo.com/914/o71_4.jpg) Open up the horn ring/steering wheel and it's got no horn guts!!! argh! Anyone have pics of what SHOULD be in there? (IMG:http://www.neoedo.com/914/o71_5.jpg) |
| Johny Blackstain |
Mar 20 2007, 04:26 PM
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region
Anyone have pics of what SHOULD be in there? Check this link out: http://cgi.ebay.com/ebaymotors/Porsche-356...1QQcmdZViewItem You should also check your engine & tranny mounts for wear & deterioration. Amazing how new ones help clean up the shifting. Welcome to the madness (IMG:style_emoticons/default/thumb3d.gif) ! (IMG:style_emoticons/default/cool_shades.gif) |
| Bleyseng |
Mar 20 2007, 04:36 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
A wire should come out of the hollow steering column and thru that small hole in the ring and push onto the male tab. It just grounds out the circuit to make the horn work.
Nice car (IMG:style_emoticons/default/drunk.gif) |
| Jeffs9146 |
Mar 20 2007, 06:01 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE 3) Shifting has gotten MUCH more difficult to the point that I can't get into 4th and 5th gears anymore! (as of last night) 2nd and 3rd gear appear to be extremely 'wide' on the shifter... does this sound like a simple adjustment or potentially a larger problem? (Mechanic who got her running/tune up did replace the transmission fluid) While you are down there check the clutch tube at the fire wall! Clutch Tube Info (IMG:style_emoticons/default/welcome.png) |
| orange914 |
Mar 20 2007, 06:55 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
QUOTE 1) That lever that is just rear of the shift lever, what does it do? I can't find head not tail about it in any of my manuals! 3) Shifting has gotten MUCH more difficult to the point that I can't get into 4th and 5th gears anymore! (as of last night) 2nd and 3rd gear appear to be extremely 'wide' on the shifter... does this sound like a simple adjustment or potentially a larger problem? (Mechanic who got her running/tune up did replace the transmission fluid) 4) The tab that is welded to the chassis to bolt to the engine cover just behind the seat has broken off. Does anyone make repro tabs or should i just have a body shop fab something up? 5) My rear trunk hinge on the right side has also come off it's weld and parts of it look in bad knack... can anyone recommend a body shop in/around San Francisco CA? orange71 (IMG:style_emoticons/default/welcome.png) #! i just went through my sons entire heating system becouse all the engine ducting was missing.--learned a few things 1 you need at least a 2 year degree to use it effectively 2 the hot air tubing maze is interesting to say the least that said the console lever also turns on the rear blower by a grounding switch when the lever is pulled up #3 sounds like you may have had thicker gear lube put in last service causing harder shifting #4 let me know what tab it is your looking for i have a parts car body #5 i live about 1 hour from bay area and i had "prestige auto" do my sons 914 they were very reasonable and did an excellent job. lt me know if your interested in more info. orange914 (IMG:style_emoticons/default/thumb3d.gif) |
| Dave_Darling |
Mar 20 2007, 09:41 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
A wire should come out of the hollow steering column and thru that small hole in the ring and push onto the male tab. It just grounds out the circuit to make the horn work. I know that's how the later cars (I think 72+) work, but I believe that the early ones have a separate horn switch that grounds the wire going up the steering column. Similar to the one in the evil-bay link--but I don't know if the one in the link is the original part or not. --DD |
| Tobra |
Mar 21 2007, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Clean out under the rocker panels. Use blue loctite on the cone/set screws. New shift bushings will make a big difference if worn
| orange71 |
Mar 27 2007, 09:58 PM
Well I missed the Ebay auction as I was down in LA for a few days (when the auction finished), but I'm back now and started poking around the inspection panel for the shift linkage and looking at the firewall.
New shift bushings will make a big difference if worn Shift bushings it was! but actually.. it was the shift bushing at the REAR! the grease was so old it had gummed up and the rod was pulling the bushing with it. I've packed some new grease on there after cleaning the old, and pushed the bushing back into sorts. It shifts like a whole new car now! I'll have to order the Shift Bushing Replacement kit from Pelican and see how much it improves when I redo the entire rod grease and put in new bushings. Thanks a ton for the advice. Now back to sourcing the bits to fix the horn (IMG:style_emoticons/default/smile.gif) |
| orthobiz |
Mar 27 2007, 10:06 PM
Looks like you have a Signal Orange car, the color of my first 914, near and dear to my college memories. Way to go!
Paul |
| markb |
Mar 27 2007, 10:22 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
I have a couple of early (70-71) steering columns, if you can pull off your steering wheel to see what parts are there, I can send you the missing (if any are) parts.
| SGB |
Mar 27 2007, 10:42 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Thatsa really nice car! And now you have fallen into the 914 DIY ZONE. It is like gambling; at first you win...
Just kidding. I believe you will have a blast. We are a wierd lot, lovers of the outcast and nearly great 914. I hope you are ready, because it is more than just a Porsche, its a relationship. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:37 AM |
