newbie questions -electric's and interior |
advtracing |
Oct 16 2009, 03:42 PM
Member Group: Members Posts: 73 Joined: 27-September 09 From: New Zealand Member No.: 10,853 Region Association: None |
Ok, i am getting ready to start the resto on a 74 2.0ltr. The car has been stored for 16 years and parts ( engine and interior ) stored under a house in cardboard boxes on the ground (IMG:style_emoticons/default/headbang.gif)
As you can imagine the parts now have a lovly coating of rust and the interior is shot, SO questions ; - the engine will be rebuilt with carbs , so do i still need a ecu and what do i do with the injection system chuck it / any parts worth anything? - With the interior and seats do i (a) look for a mint set out of another car and import everything or ((IMG:style_emoticons/default/cool.gif) buy the recover items and pay for the trim guy to recover everything? - what changes to the wiring harness is required when changing to carbs? |
underthetire |
Oct 16 2009, 03:52 PM
Ok, i am getting ready to start the resto on a 74 2.0ltr. The car has been stored for 16 years and parts ( engine and interior ) stored under a house in cardboard boxes on the ground (IMG:style_emoticons/default/headbang.gif) As you can imagine the parts now have a lovly coating of rust and the interior is shot, SO questions ; - the engine will be rebuilt with carbs , so do i still need a ecu and what do i do with the injection system chuck it / any parts worth anything? - With the interior and seats do i (a) look for a mint set out of another car and import everything or ((IMG:style_emoticons/default/cool.gif) buy the recover items and pay for the trim guy to recover everything? - what changes to the wiring harness is required when changing to carbs? I know you will have to re-configure the fuel pump wiring, and get a different fuel pump. ECU will go away for sure. Same with all the sensors and Aux air regulator. Someone with carbs can chime in. Parts are worth something for sure, don't chuck them. Interior---thats just personal choice. |
Oct 16 2009, 03:57 PM
Resident German Group: Admin Posts: 41,632 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
http://www.914world.com/bbs2/index.php?showtopic=25954
Slippery slope ahead ... (IMG:style_emoticons/default/biggrin.gif) You'll want a better than stock Cam for your carbs. And a better exhaust. And that's just for starters ... (IMG:style_emoticons/default/driving.gif) Andy PS: Get a low pressure carb rotary fuel pump, like the one sold by CB Performance. Worth every penny. |
Cupomeat |
Oct 16 2009, 04:43 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Don't be so hasty to dump the FI.
When i bought my 914 in 87, the engine had sat on a bench outside (uncovered) for 7 years. In the end, all I had to do was buy new hoses (and rebuilt injectors) and I was able to get the car to start. FI stuff is worth something as so much is NLA, and make sure you are ready to split the case to put a new cam in if you go with carbs. Otherwise, it will never be right. Good luck and I hope this helps. |
advtracing |
Oct 16 2009, 06:03 PM
I'll give you some back ground , the car has been stored for 16 years , and the engine is all stripped prior to the last owner storing under the house on the ground (IMG:style_emoticons/default/headbang.gif) so we are starting from scratch on the engine . I am basically taking the block and buying all new parts and building something interesting.
The past two owner , with all good intentions , brought alot of new parts inc carbs , linkages , etc... so i will use the carb set up . The fuel injection system is in parts and as there is only 5 914's in new zealand i would have to ship the stuff overseas to sell it , which kills any value. andy thanks for the electrical detail, i love NOT having to use early ecu's, it's a pity that pmo don't do 4 cylinder set up's. If you would like to see exaclty were the car is at as far as work needed , check out our group's website below and look under restorations |
Lo-Fi Version | Time is now: 12th May 2024 - 02:37 AM |
