Outer longitudinal replacement advice? Nobody? |
detoxcowboy |
Nov 2 2009, 01:35 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
When replacing the outer longitudinal what can I expect for issues, keeping the car aligned? removal of old? refitting new ect.. I am asking prior to attempting for the first time so treat me as an ignorant. I do not want to miss align or have the car sag in half on me or something like that..
detoxcowboy |
Nov 2 2009, 09:38 PM
When replacing the outer longitudinal what can I expect for issues, keeping the car aligned? removal of old? refitting new ect.. I am asking prior to attempting for the first time so treat me as an ignorant. I do not want to miss align or have the car sag in half on me or something like that.. Bump.... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/drunk.gif) No one has done this? Any input appreciated? I know there are rusted inside out longs sagging out there.. (IMG:style_emoticons/default/poke.gif) |
Nov 2 2009, 10:44 PM
Resident German Group: Admin Posts: 41,631 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Leave the top on. Remove the door. Add bracing to the door opening. Ideally a triangle from the striker plate to the upper front mount to the upper seat-belt mount. Do all that while the car is still on the ground. If you make the bracing adjustable, you can re-measure while you're working on the long and adjust if needed.
Dimensions are here: http://www.914world.com/specs/bodydims.php http://www.914world.com/specs/underdims.php When welding large parts, try to move around to different spots to let your welds cool. Too much heat in one spot will shrink the metal. Do a search here, there are a few very good step by step pictorials of a complete long replacement. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) Andy |
detoxcowboy |
Nov 2 2009, 10:55 PM
Leave the top on. Remove the door. Add bracing to the door opening. Ideally a triangle from the striker plate to the upper front mount to the upper seat-belt mount. Do all that while the car is still on the ground. If you make the bracing adjustable, you can re-measure while you're working on the long and adjust if needed. Dimensions are here: http://www.914world.com/specs/bodydims.php http://www.914world.com/specs/underdims.php When welding large parts, try to move around to different spots to let your welds cool. Too much heat in one spot will shrink the metal. Do a search here, there are a few very good step by step pictorials of a complete long replacement. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) Andy Andy thank you brother!!, that all I needed and then some.. Joe |
Nov 2 2009, 11:07 PM
One more. Remove the engine and transmission. Not only will it take weight off the car while it's up in the air, it'll also make access to everything much, much easier ...
Take as much weight off as you can. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
rick 918-S |
Nov 2 2009, 11:19 PM
Hey nice rack! -Celette Group: Members Posts: 20,452 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
There are many guys that have posted detailed photo documentation of the process here on this site. Use the search function when you get ready to start and take the lap top out to the shop with you. Don't get discouraged, you can do it. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif)
jimkelly |
Nov 2 2009, 11:27 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
detoxcowboy |
Nov 3 2009, 01:01 PM
Thank You every body!! Definately Something I want to do and as with most projects thus far I should uncover the "reality" of the depth of doing such work. I am detailed and a perfectionist syill never perfect(slurring). I am sure once I get going into rustoration, the project will grow considerabley. Good to know that others have treaded where I want to learn. I will ask again w/ pics when I am in it. But I am thinking now that it would be smart to finsh the engine shelfs, jack posts and stop until summer as I work in a driveway and am readying for paint in 3 weeks which means just about a complete disassemble of everything I have restored so far. God I which I had a shop, lift and a rotessirie, engine stand and of course more tools. I am just a perma dirt backed gravel head. Until Summer,... (IMG:style_emoticons/default/drunk.gif)
Lo-Fi Version | Time is now: 11th May 2024 - 09:29 PM |
