FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
Rotary'14 |
Aug 15 2010, 11:49 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO.
Engine Compartment $25 each + $15 shipping Engine Compartment set (2 lines) $45 + $15 shipping Tunnel fuel line each $40 + $25 shipping Tunnel fuel line (set of 2)$75 + $35 shipping If ordering a complete set shipping will be $40 in continental US. complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring NLA for now Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! Attached thumbnail(s) |
jjbunn |
Sep 4 2010, 10:19 AM
Julian Group: Members Posts: 121 Joined: 20-May 09 From: Pasadena, CA Member No.: 10,383 Region Association: Southern California |
Does the engine need to be out to fit these?
Rotary'14 |
Sep 4 2010, 01:13 PM
Does the engine need to be out to fit these? The engine can be in the car to install these. The most you might have to do is support the engine with a jack, and pull the engine mount back a little on the right side for some clearance. I will work on an install video with the engine in the car next time. -Robert |
Lo-Fi Version | Time is now: 16th May 2024 - 01:31 AM |
