FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
Rotary'14 |
Aug 15 2010, 11:49 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO.
Engine Compartment $25 each + $15 shipping Engine Compartment set (2 lines) $45 + $15 shipping Tunnel fuel line each $40 + $25 shipping Tunnel fuel line (set of 2)$75 + $35 shipping If ordering a complete set shipping will be $40 in continental US. complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring NLA for now Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! Attached thumbnail(s) |
mittelmotor |
Jul 30 2012, 09:38 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Hi Robert,
Got the lines and they look great! Over the long, straight sections of the line, they're bent slightly. Is this intentional for an easy install, or did it just happen in shipping? No big deal to bend them back, but I thought I'd check. Thanks! --Doug Attached image(s) |
Rotary'14 |
Aug 3 2012, 09:34 PM
Hi Robert, Got the lines and they look great! Over the long, straight sections of the line, they're bent slightly. Is this intentional for an easy install, or did it just happen in shipping? No big deal to bend them back, but I thought I'd check. Thanks! --Doug Hi Doug, the slight bend is intentional,, that's why the box is not flat. yes these lines are still available,, check first post for pricing. -Robert |
Lo-Fi Version | Time is now: 16th May 2024 - 01:41 AM |
