FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
Rotary'14 |
Aug 15 2010, 11:49 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO.
Engine Compartment $25 each + $15 shipping Engine Compartment set (2 lines) $45 + $15 shipping Tunnel fuel line each $40 + $25 shipping Tunnel fuel line (set of 2)$75 + $35 shipping If ordering a complete set shipping will be $40 in continental US. complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring NLA for now Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! Attached thumbnail(s) |
Rotary'14 |
Jan 27 2014, 04:52 PM
Bump for a new year,,,,,,
RenoRoger |
Jul 13 2014, 01:13 AM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
Bump for a new year,,,,,, Are you still making fuel lines? I have a '73 2.0 and would like to replace the original plastic lines. I also need at least the grommets for the fuel line holes leading into the engine compartment. If I move the fuel pump to the front under the tank, should I use a 9.5 mm line for delivery or 8 mm for both delivery and return? Please advise current pricing and shipping charges to 89503. RenoRoger |
Lo-Fi Version | Time is now: 15th May 2024 - 10:46 PM |
