FS - SS fuel lines, engine compartment lines,, all 4, fuel tank socks, sealing rings, FI hose clamps, grommets |
Rotary'14 |
Aug 15 2010, 11:49 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO.
Engine Compartment $25 each + $15 shipping Engine Compartment set (2 lines) $45 + $15 shipping Tunnel fuel line each $40 + $25 shipping Tunnel fuel line (set of 2)$75 + $35 shipping If ordering a complete set shipping will be $40 in continental US. complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring NLA for now Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! Attached thumbnail(s) |
02loftsmoor |
May 16 2015, 08:36 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
I've made this set, it's 9.5 mm SS .028 tubing, and 8mm SS .028. The ends have beads to keep the fuel lines from blowing off. I've bent it and test fitted the prototypes upon my car. They fit very well IMHO. Engine Compartment $22 each + $10 shipping Engine Compartment set (2 lines) $40 + $10 shipping Tunnel fuel line each $38 + $14 shipping Tunnel fuel line (set of 2)$70 + $16 shipping complete your installation with the following,,, Fuel tank fuel sock $10 Fuel tank sealing ring $.50 each Firewall grommets $2.00 each Engine shelf grommets $4.00 each FI hose clamps $2.00 each or $1.75 each(if you order more than 10) Shipping included if you buy a set of lines. Thanks for looking! are you still making fuel lines, need the one tunnel line, fire wall grommets, engine shelf grommets, fuel tank sealing ring. going with Carbs.. Wes |
Lo-Fi Version | Time is now: 16th May 2024 - 08:11 AM |
