| sixaddict |
Sep 7 2010, 11:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,069 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Need a source for decent quality floor jack that will lift at least 23". 914-6 needs to be fairly high and if the car is raised most jacks will not reach bottom of engine. Amazingly all auto parts stores carry jacks that max out at about 20".
Harbor Freight used to have a tall one but it was discontinued. I pulled two engines over the weekend and reinstalled one and I used a rental jack that had me playing games to make it work....hassle and dangerous. Never again .... Thanks for leads Help please ! |
| bandjoey |
Sep 7 2010, 12:06 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I use the HF 3ton floor jack. It lifts to 20" and I always use wood between the jack and the motor and it works ok. I've seen others use their motorcycle jacks. I used their lift table once too. It lifts to wast high.
| Mark Henry |
Sep 7 2010, 01:10 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I got a good used 7000lbs lift for a 1000 bones off of Kijiji (like craigslist).
I'm never looking back...I drop my engines on a 40" high roll around table now. |
| Rleog |
Sep 7 2010, 02:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 611 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States
The Bird Board lists a jack by AC Hydraulic that goes from 3.5 in to 29 in. It's a bit pricey.
| sixaddict |
Sep 7 2010, 02:18 PM
FAct is I just bit the bullet on AC jack...life is too short and to valuable to waste on a crummy jack...Chinese cvrap is exactly that. When I posted it said temporarly unavailabe but site was out of date ..>Hated to spend that much but better than to suffere through another change without right equipment. Now I will surely find a cheaper one! (IMG:style_emoticons/default/sheeplove.gif)
... The Bird Board lists a jack by AC Hydraulic that goes from 3.5 in to 29 in. It's a bit pricey. |
| pcar916 |
Sep 7 2010, 03:31 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
| VaccaRabite |
Sep 7 2010, 05:14 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,878 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
And, like many things at Pelican, it is currently unavailable. I wish they would take the things down from their website if they did not have them for sale. Zach |
| elmonte |
Sep 7 2010, 05:37 PM
Member ![]() ![]() Group: Members Posts: 225 Joined: 31-March 03 From: Danville.ca Member No.: 499 |
Wayne ran this thread in June
http://forums.pelicanparts.com/porsche-911...back-stock.html Maybe give them a call Cheers p.s. got some AC hydraulic jack stands (very good quality) from these guys about 5 yrs ago. http://www.asedeals.com/Ranger_floor_jacks.html |
| sixaddict |
Sep 7 2010, 08:54 PM
It said unavail;able but sales checked and it wsa it stock...I hope
| StratPlayer |
Sep 8 2010, 09:13 AM
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,372 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains
Bit spendy, not sure if this is what you had in mind..
http://www.handsontools.com/Norco-71155B-1...ack_p_4883.html |
| 914rat |
Sep 8 2010, 03:41 PM
Member ![]() ![]() Group: Members Posts: 280 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
If you are under a car a lot ,a mid rise lift makes it a lot easier on a 53 year old fat guy like me.They run $1500-$2000.Dropping an engine is almost fun.Set the engine on a cradle unbolt and disconnect everything,raise the car and roll out the engine.Makes routine brake jobs,tire rotations,valve adjustments, and oil changes easier too.The only problem is friends and relatives want you to move your project every time they need brakes or an oil change.
| jim_hoyland |
Sep 8 2010, 04:43 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,080 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
If you are under a car a lot ,a mid rise lift makes it a lot easier on a 53 year old fat guy like me.They run $1500-$2000.Dropping an engine is almost fun.Set the engine on a cradle unbolt and disconnect everything,raise the car and roll out the engine.Makes routine brake jobs,tire rotations,valve adjustments, and oil changes easier too.The only problem is friends and relatives want you to move your project every time they need brakes or an oil change. Got a picture of a cradle... (IMG:style_emoticons/default/smile.gif) |
| 914rat |
Sep 8 2010, 04:54 PM
If you are under a car a lot ,a mid rise lift makes it a lot easier on a 53 year old fat guy like me.They run $1500-$2000.Dropping an engine is almost fun.Set the engine on a cradle unbolt and disconnect everything,raise the car and roll out the engine.Makes routine brake jobs,tire rotations,valve adjustments, and oil changes easier too.The only problem is friends and relatives want you to move your project every time they need brakes or an oil change. Got a picture of a cradle... (IMG:style_emoticons/default/smile.gif) I just used a wooden dolly with a 6x6 on one end and a 4x4 on the other to rest the engine on.You just got to space them properly to get the engine and tranny to sit level.Screwed the wood together from under the dolly. |
| Steve |
Sep 8 2010, 11:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,047 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Bendpack scissor lift. Best $1500 bucks I ever spent.
| sixaddict |
Sep 9 2010, 09:13 AM
Jim:
Shoot me your email address..and I will do it ..This thing is a dream ...MAkes the process very clean..MAy have bought it direct ..Pelican may also offer. Terry If you are under a car a lot ,a mid rise lift makes it a lot easier on a 53 year old fat guy like me.They run $1500-$2000.Dropping an engine is almost fun.Set the engine on a cradle unbolt and disconnect everything,raise the car and roll out the engine.Makes routine brake jobs,tire rotations,valve adjustments, and oil changes easier too.The only problem is friends and relatives want you to move your project every time they need brakes or an oil change. Got a picture of a cradle... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 9th June 2026 - 12:02 AM |
