Painting Rocker Panels |
Cambo |
Sep 22 2010, 10:15 PM
Member Group: Members Posts: 122 Joined: 21-April 10 From: California Member No.: 11,641 Region Association: Northern California |
My rocker panels have porsche decals that are dried out and peeling. The paint is pretty beat up. So I was thinking it was time to paint them. I've got zero experience in this sort of thing. so a couple questions:
What's involved in prep? Clean them. Rough them up with sand paper? Can I rattle can them? What kind of paint? Do I primer? Going with black. Dare I ask? Can I paint them without removing them? If I do remove them, I was thinking of getting an install kit from AA. Good idea? Thanks. |
Elliot Cannon |
Sep 22 2010, 10:35 PM
You need to contact Mike Wills (MoveQik) in Scottsdale Arizona. He is an expert on rocker painting. This guy.
70_914 |
Sep 22 2010, 10:40 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
I roughed mine up with scotch brite pads and sprayed them with the spray-on bedliner. Went on nice, got a good bumpy finish and will be resistant to rock chips. NOT going to pass muster if anybody is going to judge my car on originality, but those people can (IMG:style_emoticons/default/KMA.gif) or come out and paint my next set in the original manner.
I did my rear valence and bumper tops with the same stuff and am very happy with the results, but time will tell. |
avidfanjpl |
Sep 22 2010, 10:44 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I have done and redone rockers on 6 cars in 34 years.
You did not say if they were metal, and I have no familiarity with the raised letter versions. Are they metal? So, if metal, here is heaven in a sentence, or 7. Satin black powdercoat cost 50 bucks. Peel them off and check the jackpoints, then get the kits from AA. If the jackpoints are rotten, cut them out and buy new tubes and plates from Restoration Design in Canada. 70 bucks for both sides. See the picture below of mine cut out before and after welding. You must check the jacktubes. Or there will be blood. Then, if metal, just take them to powdercoaters, but if there is rust, you must weld the holes closed in the metal rockers. Powdercoating melts Bondo. You will have a hole where Bondo was. Sort of nothing short of powdercoating looks like it was factory. Then, when you get them home, you can mask and paint the PORSCHE if you must. I like them black on black. If your's are metal, powdercoat. Otherwise, rattlecan away. John Before Before After without primer or paint After with Wurth's Zinc Primer And last weekend rockers reinstalled on Orangina She dat fast gal that wears black rocker panties |
avidfanjpl |
Sep 22 2010, 10:52 PM
If I read this right, now that I am sitting calmly, you can go to Embee Performance in Santa Ana, if you are in SoCal, and they will do them for 80 bucks.
ALL 4 panels, front, rear, and both sides. I did 8 parts for 108 cash. EMBEE, recommended to me by Detox Cowboy, one smart cookie that California is missing. He moved away last month, I think. But his recommendations are ROCK SOLID. Where he landed, does anyone know? John |
KELTY360 |
Sep 22 2010, 11:09 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
MoveQik |
Sep 23 2010, 07:50 AM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
You need to contact Mike Wills (MoveQik) in Scottsdale Arizona. He is an expert on rocker painting. This guy. (IMG:style_emoticons/default/bootyshake.gif) |
balljoint |
Sep 23 2010, 06:06 PM
You need to contact Mike Wills (MoveQik) in Scottsdale Arizona. He is an expert on rocker painting. This guy. (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/biggrin.gif) |
Pat Garvey |
Sep 23 2010, 07:07 PM
My rocker panels have porsche decals that are dried out and peeling. The paint is pretty beat up. So I was thinking it was time to paint them. I've got zero experience in this sort of thing. so a couple questions: What's involved in prep? Clean them. Rough them up with sand paper? Can I rattle can them? What kind of paint? Do I primer? Going with black. Dare I ask? Can I paint them without removing them? If I do remove them, I was thinking of getting an install kit from AA. Good idea? Thanks. Some interesting "versions" of what the Factory did. None of which are correct. PM me if you want them to look proper(no,I'm not selling anything). DO NOT POWDERCOAT! Yes, you will need to remove them, but it's easy. And, you need to remove them to clear the gunk behind them. |
Tom_T |
Sep 23 2010, 10:11 PM
My rocker panels have porsche decals that are dried out and peeling. The paint is pretty beat up. So I was thinking it was time to paint them. I've got zero experience in this sort of thing. so a couple questions: What's involved in prep? Clean them. Rough them up with sand paper? Can I rattle can them? What kind of paint? Do I primer? Going with black. Dare I ask? Can I paint them without removing them? If I do remove them, I was thinking of getting an install kit from AA. Good idea? Thanks. Some interesting "versions" of what the Factory did. None of which are correct. PM me if you want them to look proper(no,I'm not selling anything). DO NOT POWDERCOAT! Yes, you will need to remove them, but it's easy. And, you need to remove them to clear the gunk behind them. Pat, Can you put the O&H link to this subject for those who are looking for the OE finish for them? I had it bookmarked, but lost it when my hard drive died - otherwise I'd do it for you. Anyway, you're the O&H maestro on these! (IMG:style_emoticons/default/biggrin.gif) I just got a set of Restoration Design repro steel ones to replace my rusted/tweaked OE ones last weekend at GPR! (IMG:style_emoticons/default/piratenanner.gif) Thanx! Tom /////// |
Elliot Cannon |
Sep 23 2010, 10:51 PM
If I read this right, now that I am sitting calmly, you can go to Embee Performance in Santa Ana, if you are in SoCal, and they will do them for 80 bucks. ALL 4 panels, front, rear, and both sides. I did 8 parts for 108 cash. EMBEE, recommended to me by Detox Cowboy, one smart cookie that California is missing. He moved away last month, I think. But his recommendations are ROCK SOLID. Where he landed, does anyone know? John Here's a PM I got from the "one smart cookie"..... Fuck you again, It is people like you who make online experiences stupid. Your probably a bigger "man" online than in reality, as seems the case more often than not.. I would deal with you to your face in the same manner I am now.. or even more direct.. Try to show some respect fif not for anyone yourself.. you bag of shit.. I am getting off this site so I will never get to see your response, but if you see a Marathon Blue 914 driving through you town next Sunday, feel free to flag me down you complete ass will get what it deserves and I do not give a damn if I end back in Prison for giiving you a beat down.. Joe |
MoveQik |
Sep 23 2010, 11:02 PM
Your probably a bigger "man" online than in reality Ell-yut, I think you're perfect online and in person. (IMG:style_emoticons/default/wub.gif) |
Sleepin |
Sep 23 2010, 11:38 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/blink.gif)
What am I doing wrong? I never get hateful PMs! Screw all of you! |
avidfanjpl |
Sep 24 2010, 12:23 AM
Holy crap!
I had to read that 4 times to understand it. Elliot, I got a lot of good stuff from Detox in advice. I am so sorry that you got what you got, but I almost thought I did something wrong. I really am shocked that he dissed you. I am really stupid in love with 914World, and have strong feelings about how cool this place and people are, so I didn't get it at all, and try to be evenhanded, but this made me dizzy. I do hope to meet you and all the MidCal and NorCal people, and I burn no bridges. I am weirded out at that reaction he gave you. John |
balljoint |
Sep 25 2010, 10:53 AM
(IMG:style_emoticons/default/blink.gif) What am I doing wrong? I never get hateful PMs! Screw all of you! If you want I can stop sending them by regular mail and just use the PM system? |
Lo-Fi Version | Time is now: 21st May 2024 - 02:39 AM |
