6 Pages V « < 3 4 5 6 >
> Gasoline Heaters, 914's and buses
post Oct 13 2015, 03:40 PM
Post #81
914-6 GT in waiting
The factory heat exchangers bolt right in. The gas heater, not so much.
horizontally-opposed
post Oct 13 2015, 05:08 PM
Post #82
QUOTE(mepstein @ Oct 13 2015, 02:40 PM) *
And...price for NOS factory heaters? The Dansk alternative were big dollars, and had some serious issues that makes one wary. Used factory exchangers, which are also $,$$$ in varying condition, may have CO problems. Hard to tell, harder to justify buying.
None of the aftermarket HEs are attractive to me, personally.
Gas heater seems problematic to me. Basic needs in warmer climes seem to be body heat (heated seats?) and defrost/foot warmers (minor electric heat?).
Thoughts?
pete
Mark Henry
post Oct 13 2015, 06:21 PM
Post #83
that's what I do!
QUOTE(bandjoey @ Oct 13 2015, 05:00 PM) *
Drawback is cost. They're darn tootin expensive!
New Espar D2 airtronic is about a grand, so that's about a 1/3 of the cost of the new /6 heat exchangers. I see complete systems on Kijiji/Craigslist for half that price.
I have seen them, there's nothing to them, hardest part would be the fab up on a fuel tank.
Alapone
post Oct 15 2015, 02:38 PM
Post #84
-Yea I was looking at a used gas airtronic on ebay for reasonable amount just wondering the difficulty level for install. If anyone has successfully tamed this dragon please post the how to.
-I don't know about you but after a couple seasons with headers and no heat Im screaming for a real solution (read; not electric heated clothing)
Alapone
post Oct 15 2015, 02:39 PM
Post #85
QUOTE(Alapone @ Oct 15 2015, 04:38 PM) *
I am in the NE though. A real solution could extend my season 2+ months
Mueller
post Oct 15 2015, 04:57 PM
Post #86
914 Freak!
If it does not rain this weekend, I will see how the heater I have fits in the front trunk.
edit...Ouch....lowest price on on eBay is $450 with shipping for same exact model.
edit again (IMG:style_emoticons/default/smile.gif) I just placed an order on ebay for a a 12vdc to 24vdc power supply.
(IMG:http://www.914world.com/bbs2/uploads/post-87-1423322924.jpg)
lonewolfe
post Oct 15 2015, 08:29 PM
Post #87
QUOTE(Mueller @ Oct 15 2015, 03:57 PM) *
What kind of heater is that? I can't make out the brand. Please keep us posted on your progress. I've been thinking of adding a gas heater for the last couple years. It never occurred to me to locate it in the rear trunk or in the engine bay. The rear trunk is appealing to me. Is your heater gas or diesel? Are you going to use a separate fuel tank? Mostly what you see on Ebay are diesel heaters because all the semi-trucks use them for heat. The gas heaters are not nearly as common.
Mueller
post Oct 15 2015, 08:36 PM
Post #88
914 Freak!
QUOTE(lonewolfe @ Oct 15 2015, 07:29 PM) *
Benmar is the brand, gasoline for fuel. I think it is too big for the rear trunk , but I could be wrong. Will try and snap pictures of it sitting in both front and rear.
post Oct 15 2015, 08:55 PM
Post #89
914-6 GT in waiting
QUOTE(Alapone @ Oct 15 2015, 04:39 PM) *
If you have a type 4 engine then the stock heat exchangers are a real solution. Available, bolt on, reasonably priced and work great.
I have only ever seen one 914 with a working gas heater. Every year it is often talked about but almost never done.
Mueller
post Oct 16 2015, 12:23 PM
Post #90
914 Freak!
Pictures as promised....pic 1 and 2 inside front trunk.
Last pic in the rear trunk, looks like it would fit with no real problems, I'd cut a hole in the trunk floor for the exhaust to gain another 2 inches of space. Rear lid would close like shown in the picture.
Mueller
post Oct 18 2015, 12:13 PM
Post #91
914 Freak!
I found the installation manual for mine...
Fuel: gasoline, diesel and JP-4
Weight: 10 pounds, figure another 10 pounds worth of stuff to install it (ducting and fuel pump...3psi to 15psi max)
Mueller
post Oct 21 2015, 11:07 PM
Post #92
914 Freak!
Need to find a low pressure fuel pump now....
Hooked it up to 12VDC and thru magic, 24VDC popped up on the other side of the wires!
Steve
post Oct 22 2015, 06:34 PM
Post #93
It seems like a good spot to mount it would be in place of the battery. You could then just run the hose down the stock passenger side or get a "T" to connect both sides. I would be paranoid to put something combustible in the front trunk with the gas tank. Even though it looks like there was an aftermarket unit available for the front trunk. I am also curious if there is enough circulation in the rear trunk. Especially with the top back there and other personal crap.
euro911
post Oct 22 2015, 07:46 PM
Post #94
Sounds logical to me (IMG:style_emoticons/default/confused24.gif)
Mueller
post Jan 2 2018, 02:34 PM
Post #95
914 Freak!
Update on this heater I've had for years!
No go with the 12vdc to 24vdc converter, it claims it is 10 amps yet it will barely run the fan.
I did get the heater to fire up using 2 12vdc car batteries in series, however after 5 minute run time it shut off. I smoked quite a bit out of the exhaust, could be due to age and from someone previously running a different fuel? (I used gas)
Decided not worth it and will be in the market for real heat exchangers to replace my patched up no name header.
post Jan 2 2018, 03:07 PM
Post #96
914-6 GT in waiting
QUOTE(Mueller @ Jan 2 2018, 03:34 PM) *
HE’s are the way to go. Bolt up quickly and throw tons of heat. Do you need 1.7’s or 2.0
Mueller
post Jan 2 2018, 03:13 PM
Post #97
914 Freak!
QUOTE(mepstein @ Jan 2 2018, 01:07 PM) *
1.8 with a slightly hotter cam.
post Jan 2 2018, 03:54 PM
Post #98
914-6 GT in waiting
QUOTE(Mueller @ Jan 2 2018, 04:13 PM) *
I have stock steel ones (1.7, 1.8) that you can have for free. a bunch of connector tubes, hanger and (probably) a cable and barrel nuts. I don't have flapper boxes. Have a good muffler to use until you buy a nice one. all for cost of shipping.
probably have a lever if you need one.
I can do a SS setup with everything but flapper boxes for $300 shipped.
Offer is good any time.
GeorgeRud
post Jan 2 2018, 05:06 PM
Post #99
I also purchased the same heater as Mueller, and glad to see that it could fit in the car. Perhaps using two 12-24 volt converters could provide adequate wattage to run the fan. I also have a used B1L Eberspacherthat I was going to use with my headers, but eventually found some good heat exchangers so went that route. I remember that gas heaters do work quite well in heating the interior, but they’re not the easiest thing to fit safely.
Mueller
post Jan 2 2018, 06:07 PM
Post #100
914 Freak!
QUOTE(GeorgeRud @ Jan 2 2018, 03:06 PM) *
Looking at a schematic I found online, the ignitor is actually 12vdc , they use a resistor to drop reduce the voltage so it might be possible to install a different fan and convert it to run entirely on 12vdc (I used a Mr Gasket carb fuel pump ran off of 12vdc)
One thread I found about these heaters mention ditching the stock ignitor and using a car cigarette lighter element. I'm at the point now that I really don't feel that comfortable modifying something that burns raw fuel like these heaters!
- Lo-Fi Version Time is now: 7th March 2026 - 02:00 AM
