> Anyone know the generic part # for rear wheel bearings?, And what shall I do while the arms are off?
stugray
post Jan 10 2011, 06:52 AM
Years ago, I needed to replace the bearings on either my Ghia or 914, and the VW dealer wanted an arm & leg for OEM.
I took the part number from the bearing and called a local bearing specialty house in Denver, and they had the exact same part for less than 1/4 of what the dealer wanted.
Anyone know a cross ref. part number for rear wheel bearings?
How about the dozens of bearings on ebay? Any good?
Any ideas for the best deal?
Oh, and what is the deal with the rear bearing seals?
The manual states that if these are damaged, the entire trailing arm needs to be replaced...
While I'm at it. Both arms are off and I am cleaning them up.
What does everyone suggest I do while I have them off?
I plan on painting them, but what else should I do while I'm at it?
I have the welder at the ready, so I could do some reinforcing too.
Stu
type47
post Jan 10 2011, 07:06 AM
Viermeister
don't know cross reference but PET shows 999.053.035.00 so maybe you can use that to get what you want.
914Sixer
post Jan 10 2011, 07:11 AM
There are no rear bearing seals. You may be confused about the control arm bushings, I think they are what the manual is refering to. They are now replaceable.
Bearing 33411130617
Size 42x75x37mm
One source: Autohausaz.com $43.16 FAG Bearing FREE Shipping over $50
post Jan 10 2011, 07:29 AM
914-6 GT in waiting
Eric Shea- www.PMBPerformance.com
dr914@autoatlanta.com
post Jan 10 2011, 10:08 AM
443 407 625 is another number. We have several different brands as low as 24.50 to as high as about 55 bucks.
QUOTE(stugray @ Jan 10 2011, 05:52 AM) *
Stu
andys
post Jan 10 2011, 11:07 AM
513106 is the generic number for the 914 rear wheel bearing.
Andys
stugray
post Jan 10 2011, 12:20 PM
"513106"
Now that's what I'm talking about!
Found them for $20 each!
Thanks! I could probably find them at an industrial supply even cheaper, but they cannot cross-reference the number above. Any chance there is another number like NA107464 or something similar?
If I remember they were only ~$10 ea last time, but that was almost 20 years ago.
Here is another bearing related question:
The bearings feel fine and turn very smoothly out of the car.
However since I want to cleanup & strengthen the arms, I needed to break them all the way down.
I knocked the spindles out using a 30mm socket and a hammer since I was planning on replacing the bearings anyway.
Does this damage the bearings ( as opposed to pressing them out )? ....should I just reuse them for now?
Stu
Cap'n Krusty
post Jan 10 2011, 12:58 PM
Cap'n Krusty
It destroys the bearings. No way would I install a "generic" bearing in this application, ESPECIALLY a Chinese made part. Do it right, do it once. BTW, after you press in the bearing (or use the "chill and drop" method, you MUST press (or draw) the hub into place. NEVER hammer it. Ever.
The Cap'n
rohar
post Jan 10 2011, 01:21 PM
I'm with the Cap'n. Of all the maintainance tasks on a 914, rear bearings are my least favorite. Aside from the possible safety issues, it seems better to buy decent name brand bearings and extend the period between changes.
That, and when you put it all back together, don't forget the anti seize!
stugray
post Jan 10 2011, 01:54 PM
Cap'n,
Could you explain the "chill and drop" method?
Is just putting it in my freezer overnight good enough? Or Dry Ice ( or I could take all the parts to work with me and use liquid nitrogen ;-)
I am used to heating things up to get them together, but obviously we dont want to heat the bearing enough for that to work.
I would just press them in with my vise, but I dont think the jaws open enough with the bearing installed in the arm already.
Looks like I'll just order them from www.PMBPerformance.com, but I want to inspect the CV joints first (didnt get that far last night) before I place the order.
Stu
post Jan 10 2011, 02:02 PM
914-6 GT in waiting
QUOTE(stugray @ Jan 10 2011, 02:54 PM) *
Cap'n,
Stu
Eric has a video for removal and reinstall on his website.
I know from working in the bike industry there are many different grades of bearings. They cheap ones will sometimes fall apart before your even done the install. Buy the best you can and install per directions.
Mark Henry
post Jan 10 2011, 02:59 PM
that's what I do!
I don't know how accurate this list is, but here's a cross reference I found on the net.
Item Specs
Vehicle Fitment
Year Make Model Engine Fit Note
1977 - 1975 Alfa Romeo Alfetta GT 2.0L L4 120ci Rear Wheel
1977 - 1975 Alfa Romeo Alfetta Sport 2.0L L4 120ci Rear Wheel
1986 - 1981 Alfa Romeo GTV-6 2.5 2.5L V6 2492cc Rear Wheel
1989 - 1987 Alfa Romeo Milano Gold 2.5L V6 2492cc Rear Wheel
1988 - 1987 Alfa Romeo Milano Platinum 2.5L V6 2492cc Rear Wheel
1987 - 1987 Alfa Romeo Milano Silver 2.5L V6 2492cc Rear Wheel
1989 - 1988 Alfa Romeo Milano Verde 3.0L V6 2959cc Rear Wheel
1979 - 1978 Alfa Romeo Sport 2.0L L4 120ci Rear Wheel
1979 - 1977 Alfa Romeo Sprint Veloce 2.0L L4 120ci Rear Wheel
1987 - 1986 Audi 4000 Quattro CS 2.2L L5 2226cc Rear Wheel
1985 - 1984 Audi 4000 Quattro S 2.2L L5 2226cc Rear Wheel
1985 - 1979 Audi 5000 2.0L L5 1986cc Front Wheel
1983 - 1978 Audi 5000 2.2L L5 2144cc Front Wheel
1986 - 1986 Audi 5000 CS 2.2L L5 2226cc Front Wheel; 1st Design
1981 - 1979 Audi 5000 S 2.0L L5 1986cc Front Wheel
1986 - 1985 Audi 5000 S 2.2L L5 2226cc Front Wheel
1984 - 1979 Audi 5000 S 2.2L L5 2144cc Front Wheel
1985 - 1984 Audi 5000 S Turbo 2.2L L5 2144cc Front Wheel
1983 - 1981 Audi 5000 Turbo 2.2L L5 2144cc Front Wheel
1986 - 1986 Audi 5000 Quattro CS 2.2L L5 2226cc Rear Wheel; 1st Design
1988 - 1988 Audi 80 Quattro 2.3L L5 2309cc Rear Wheel; Exc. ABS
1988 - 1988 Audi 90 Quattro 2.3L L5 2309cc Rear Wheel; Exc. ABS
1986 - 1983 Audi Quattro 2.2L L5 2144cc Rear Wheel
2009 - 2008 BMW 128i 3.0L L6 2996cc Rear Wheel
1995 - 1991 BMW 318i 1.8L L4 1796cc Rear Wheel
1999 - 1996 BMW 318i 1.9L L4 1895cc Rear Wheel
1995 - 1991 BMW 318is 1.8L L4 1796cc Rear Wheel
1999 - 1996 BMW 318is 1.9L L4 1895cc Rear Wheel
1995 - 1992 BMW 320i 2.0L L6 121ci Rear Wheel
2005 - 2001 BMW 320i 2.2L L6 132ci Rear Wheel
2000 - 2000 BMW 323Ci 2.5L L6 152ci Rear Wheel
2000 - 1998 BMW 323i 2.5L L6 152ci Rear Wheel
2008 - 2006 BMW 323i 2.5L L6 2497cc Rear Wheel
1999 - 1998 BMW 323is 2.5L L6 152ci Rear Wheel
1988 - 1987 BMW 325 2.7L L6 2693cc Rear Wheel
2006 - 2001 BMW 325Ci 2.5L L6 152ci Rear Wheel
1987 - 1987 BMW 325e 2.7L L6 2693cc Rear Wheel
1987 - 1987 BMW 325es 2.7L L6 2693cc Rear Wheel
2005 - 1987 BMW 325i 2.5L L6 152ci Rear Wheel
2006 - 2006 BMW 325i 3.0L L6 2996cc Rear Wheel
1995 - 1987 BMW 325is 2.5L L6 152ci Rear Wheel
1991 - 1988 BMW 325iX 2.5L L6 152ci Rear Wheel
2000 - 2000 BMW 328Ci 2.8L L6 2793cc Rear Wheel
2000 - 1996 BMW 328i 2.8L L6 2793cc Rear Wheel
2009 - 2007 BMW 328i 3.0L L6 2996cc Rear Wheel
1999 - 1996 BMW 328is 2.8L L6 2793cc Rear Wheel
2000 - 1999 BMW Z3 Coupe 2.8L L6 2793cc Rear Wheel
2002 - 2001 BMW Z3 Coupe 3.0L L6 2979cc Rear Wheel
1998 - 1996 BMW Z3 Roadster 1.9L L4 1895cc Rear Wheel; Coupe
2002 - 1999 BMW Z3 Roadster 2.5L L6 152ci Rear Wheel
2000 - 1997 BMW Z3 Roadster 2.8L L6 2793cc Rear Wheel; Coupe
2002 - 2001 BMW Z3 Roadster 3.0L L6 2979cc Rear Wheel
2005 - 2003 BMW Z4 2.5i 2.5L L6 152ci Rear Wheel
2005 - 2003 BMW Z4 3.0i 3.0L L6 2979cc Rear Wheel
2008 - 2006 BMW Z4 Coupe 3.0si 3.0L L6 2996cc Rear Wheel
2008 - 2006 BMW Z4 M Coupe 3.2L L6 3246cc Rear Wheel
2008 - 2006 BMW Z4 M Roadster 3.2L L6 3246cc Rear Wheel
2008 - 2006 BMW Z4 Roadster 3.0i 3.0L L6 2996cc Rear Wheel
2008 - 2006 BMW Z4 Roadster 3.0si 3.0L L6 2996cc Rear Wheel
2004 - 2004 Porsche 911 40th Anniversary Edition 3.6L H6 3596cc Front Wheel
2001 - 1999 Porsche 911 Carrera 3.4L H6 3400cc Front Wheel
1998 - 1995 Porsche 911 Carrera 3.6L H6 3606cc Front Wheel
2004 - 2002 Porsche 911 Carrera 3.6L H6 3596cc Front Wheel
1994 - 1990 Porsche 911 Carrera 2 3.6L H6 3606cc Front Wheel
2001 - 1999 Porsche 911 Carrera 4 3.4L H6 3400cc Front Wheel
1998 - 1989 Porsche 911 Carrera 4 3.6L H6 3606cc Front Wheel
2003 - 2002 Porsche 911 Carrera 4 3.6L H6 3596cc Front Wheel
1993 - 1993 Porsche 911 Carrera 4 Turbo Look 3.6L H6 3606cc Front Wheel
1998 - 1996 Porsche 911 Carrera 4S 3.6L H6 3606cc Front Wheel
2004 - 2002 Porsche 911 Carrera 4S 3.6L H6 3596cc Front Wheel
1998 - 1998 Porsche 911 Carrera S 3.6L H6 3606cc Front Wheel
1969 - 1969 Porsche 911 E 2.0L H6 121ci Rear Wheel
1971 - 1970 Porsche 911 E 2.2L H6 2195cc Rear Wheel
1973 - 1972 Porsche 911 E 2.4L H6 2341cc Rear Wheel
2004 - 2004 Porsche 911 GT3 3.6L H6 3606cc Front Wheel
1994 - 1992 Porsche 911 RS America 3.6L H6 3606cc Front Wheel
1969 - 1969 Porsche 911 S 2.0L H6 121ci Rear Wheel
1971 - 1970 Porsche 911 S 2.2L H6 2195cc Rear Wheel
1973 - 1972 Porsche 911 S 2.4L H6 2341cc Rear Wheel
1994 - 1994 Porsche 911 Speedster 3.6L H6 3606cc Front Wheel
1969 - 1969 Porsche 911 T 2.0L H6 121ci Rear Wheel
1971 - 1970 Porsche 911 T 2.2L H6 2195cc Rear Wheel
1973 - 1972 Porsche 911 T 2.4L H6 2341cc Rear Wheel
1998 - 1994 Porsche 911 Targa 3.6L H6 3606cc Front Wheel
1992 - 1991 Porsche 911 Turbo 3.3L H6 3294cc Front Wheel
1997 - 1996 Porsche 911 Turbo 3.6L H6 3606cc Front Wheel
1994 - 1993 Porsche 911 Turbo 3.6 3.6L H6 3606cc Front Wheel
1994 - 1992 Porsche 911 Turbo Look 3.6L H6 3606cc Front Wheel
1971 - 1970 Porsche 914 4 1.7L H4 1679cc Rear Wheel
1971 - 1970 Porsche 914 6 2.0L H6 121ci Rear Wheel
1973 - 1972 Porsche 914 1.7L H4 1679cc Rear Wheel
1975 - 1974 Porsche 914 1.8L H4 1795cc Rear Wheel
1975 - 1973 Porsche 914 2.0L H4 1971cc Rear Wheel
1976 - 1976 Porsche 914 2.0L H4 1967cc Rear Wheel
1972 - 1972 Porsche 914 2.0L H6 121ci Rear Wheel
1999 - 1997 Porsche Boxster 2.5L H6 2480cc Front Wheel
2004 - 2004 Porsche Boxster 2.7L H6 2687cc Front Wheel
2003 - 2000 Porsche Boxster Roadster 2.7L H6 2687cc Front Wheel
2000 - 2000 Porsche Boxster Roadster 3.2L H6 3179cc Front Wheel
2003 - 2000 Porsche Boxster Roadster S 3.2L H6 3179cc Front Wheel
2004 - 2004 Porsche Boxster S 3.2L H6 3179cc Front Wheel
2004 - 2004 Porsche Boxster S Special Edition 3.2L H6 3179cc Front Wheel
1990 - 1981 Saab 900 2.0L L4 1985cc Front Wheel
1992 - 1991 Saab 900 2.1L L4 2119cc Front Wheel
1990 - 1981 Saab 900 S 2.0L L4 1985cc Front Wheel
1993 - 1991 Saab 900 S 2.1L L4 2119cc Front Wheel
1991 - 1991 Saab 900 S Turbo 2.0L L4 1985cc Front Wheel
1991 - 1991 Saab 900 SE Turbo 2.0L L4 1985cc Front Wheel
1991 - 1986 Saab 900 SPG 2.0L L4 1985cc Front Wheel
1993 - 1981 Saab 900 Turbo 2.0L L4 1985cc Front Wheel
1993 - 1993 Saab 900 Turbo Commemorative Edition 2.0L L4 1985cc Front Wheel
andys
post Jan 10 2011, 05:03 PM
QUOTE(Cap'n Krusty @ Jan 10 2011, 11:58 AM) *
The Cap'n
I don't think I'd have a problem with installing a Timken 513106 "generic" bearing; I suspect it X-ref's with all the majors (FAG, Fafnir, etc, etc). I agree with avoiding the Chinese ones.
Andys
SLITS
post Jan 10 2011, 06:37 PM
"This Utah shit is HARSH!"
QUOTE(Mark Henry @ Jan 10 2011, 12:59 PM) *
Item Specs
Vehicle Fitment
List is correct, but I thought it was longer.
Just take the number off the damn bearing and call a bearing supplier.
They don't care what it fits.
draganc
post Jan 10 2011, 08:09 PM
QUOTE(mepstein @ Jan 10 2011, 12:02 PM) *
Cap'n,
Stu
get the best bearings you can get. installing them is a medium PITA and I wouldn't like to do the task every year. I let my bearings sit for 3-4 days in the freezer before I installed them. one side just dropped in, the other need very light tapping on the OD. make sure the arm surfaces are clean before you drop them in. in addition, I used a very thin coat of cooper paste.
dragan
ps: eric’s video is excellent. buy the bearings with him and support his efforts.
sww914
post Jan 10 2011, 10:30 PM
I have a pair of SKF in boxes on my desk. The 999 number is there as well as BA2B633457 and 394 43020 365. On the inner race it says 633457.
They're made in Spain. You know what they say about those Spanish made bearings... (IMG:style_emoticons/default/smile.gif)
Eric_Shea
post Jan 11 2011, 10:09 AM
PMB Performance
545495AD
The 999 numbers are insaine. That's "Supplier Code" for P-O-R-S-C-H-E "Proceed to Obstantaciously Rape the Sons-a-bitches Cause-they Have Extra-cash"
(IMG:style_emoticons/default/agree.gif) with what the Cap'n said. Watch the install video here:
http://www.pmbperformance.com/videos.html
Hans Zupp
post Jan 11 2011, 05:28 PM
Yugo Driver
QUOTE(Eric_Shea @ Jan 11 2011, 05:09 PM) *
545495AD
Thanks for posting the video URL (IMG:style_emoticons/default/beer.gif)
stugray
post Jan 12 2011, 06:31 AM
Funny,
Now that the part number above (545495AD) appears, I see that this topic has been discussed before:
http://www.914world.com/bbs2/lofiversion/i...php?t94702.html
Thanks for all the help.
Any opinions on what I should do to the arms while they are off?
I will reinforce them like the AA trailing arm plates before I paint them.
Has anyone ever considered having these parts plated for corrosion resistance during a refurb?
That would get the insides as well as the outsides....
Stu
tradisrad
post Jan 12 2011, 09:03 AM
It's a good time to replace the bushings. How about the brake calipers? Did you rebuild them? When I did mine I painted my calipers and I regret not having them plated like Eric does to his.
- Lo-Fi Version Time is now: 15th January 2026 - 08:51 PM
