Seam Sealer |
Seam Sealer |
thomasotten |
Apr 26 2004, 05:53 PM
Senior Member Group: Members Posts: 1,544 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Does anyone have a recommended sealer for putting on top of welds? I am finishing up some major rust repair and want to hide my crappy welds as well as protect the backside of the seam. I saw some in the AA catalog, but I was looking for something that I could buy locally.
Thomas 73 914 |
ejm |
Apr 26 2004, 06:22 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE(thomasotten @ Apr 26 2004, 03:53 PM) I saw some in the AA catalog, Run Forrest Run (IMG:style_emoticons/default/ar15.gif) AA Any good body shop supply store has seam sealer. It might work well to hide crappy welds but will eventually loosen and trap moisture. A little cosmetic work with a grinder and some cold galvanizing primer or POR15 might make for a longer lasting repair. |
DuckRyder |
Apr 26 2004, 06:44 PM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Any automotive refinish supply store should have 3m brushable seam sealer.
Any thing by Wurth is good too. Not sure seam sealer will help to hide much weld though, maybe after grinding, but it is pretty aggravating to work with as well. |
TonyAKAVW |
Apr 26 2004, 06:54 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I have to agree with ejm regarding not using seam sealer. The problem is that seam sealer hides too much. It hides the rust that develops until its too late. I'm about to do some welding myself and I've pretty much decided to use POR-15 over everything. Take some time and grind the welds down. You've probably put a lot of work into it by now, there's no reason to use something that is responsible for the rust in many of our cars.
-Tony |
TimT |
Apr 26 2004, 07:13 PM
QUOTE Take some time and grind the welds down no need to be grinding welds unless they are fugly here is a pic of my 911 front pan rustoration.. The welds dont look factory, but they look good, and are good welds.. no need to hide them Attached image(s) |
TimT |
Apr 26 2004, 07:15 PM
Oh and must mention all welds and seams are cleaned before and after welding, then primed with a good zinc coating...appropriate finish coats are applied
Slowpoke |
Apr 26 2004, 07:53 PM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
SEMS is the only decent seam sealer around. The gun cost $65. But if you tell the guy you just moved into town and your gun broke, they will give you one, if they are cool. Once you have the gun you can use all of their products. Structural bonding agents to expanding seam sealer. The shop selling SEMS will have a display board. Once you use it you'll never go back to anything else. I don't like 3M, I have had nothing but problems with it.
Peter |
Lo-Fi Version | Time is now: 15th May 2024 - 10:27 AM |
