| matthepcat |
Sep 12 2011, 03:14 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Had a couple of cooling related issues. First off the autozone chrome water inlet on the intake manifold has been corroding away on the inside and finally corroded so far that it created a leak. Pretty bad.. So I drained and flushed the system and installed a factory cast piece that looks like it wont ever have that problem. Took a couple of tries to get all the air out of the system but I did it. Another issue I had was I had a pusher and a puller 12 or 14" fans (cant remember) and the pusher's connections broke and caused for fraying of wires and a contained electrical fire. I removed the pusher and have been running just a puller, however I wired it backwards on accident and I also decided that one fan just isnt enough. So while dad was picking up some bolts at pick and pull for my honda he picked up a Lincoln Mark VIII radiator fan. 18" of fan glory that fits the radiator PERFECT. MY OH MY does this thing suck air. Absolutely dwarfs the old fan and supposedly pulls 4k CFM. I have it running on just the LOW setting and will setup a separate switch for the HIGH setting (its a 2 stage fan). The only thing I think I have left to do for the radiator is setup a duct to force the air out the wheel wells as I think there is some turbulence currently and I dont think its as efficient as it could be. What size inlet hole did you cut? Mine seems much smaller than modern renegade conversions, and I wonder if this is causing my 200 degree freeway temps. |
| Mike Bellis |
Sep 12 2011, 03:42 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Mine is the entire width of the front trunk, from fog lamp gril to fog lamp grill. The key is to have twice as much on the air exit. That way it creates a low pressure zone. My rotary stays at 180 and slowly creeps to 200 if I'm not moving.
| Andyrew |
Sep 12 2011, 04:24 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
My inlet on the bumper is ~ 5.5 x 21"
You can see the bumper cutout in the pic Jim posted, the cutout in the front of the trunk is a couple inches larger than that. The problem that I see with the inlet setup right now is that air that goes through the hole in the bumper isnt forced into the trunk, there is a couple of inches around the bumper all the way around between the bumper and the trunk. If I eliminated this gap with fiberglass on the bumper I suspect more airflow at higher speeds (Granted I dont have cooling problems at high speeds except on hot hot days). And Mike has it right, the biggest thing is 2x the outlet as the inlet. Which is why I believe if you shroud the outlet the efficiency of the hole size would be much increased, for example you would only need 1.5x the size. Just one of those things im looking to experiment with. |
| Mike Bellis |
Sep 12 2011, 06:34 PM
I have a rubber dam between the bumper hole and radiator. This forces all the air through my shroud.
| Andyrew |
Sep 12 2011, 10:06 PM
Do you have a pic of said rubber? I never noticed it on your car
| Mike Bellis |
Sep 12 2011, 10:09 PM
Do you have a pic of said rubber? I never noticed it on your car You can barely see it if you look through the grill. I would have to dissassemble the shroud to get a picture. It's made from a bed liner mat. 1/4" thick and cut to shape. EDIT: Found a pic. Not great but you get the idea... ![]() |
| Andyrew |
Sep 12 2011, 11:51 PM
So that material attatches to your bumper? Looks like that kind of thing could certainly work.. Better than hours of fiberglassing...
| Andyrew |
Oct 23 2011, 10:53 PM
This is just a teaser to some of our kick ass engagement pics. I was able to convince her to let me incorporate the 914 in some of our pictures. Were really happy how these have turned out so far and we hope you guys like them as much as we do! I'll post up some more in a couple of weeks.
(IMG:style_emoticons/default/biggrin.gif) Attached image(s)
| Mike Bellis |
Oct 23 2011, 10:58 PM
| Andyrew |
Oct 23 2011, 11:03 PM
High resolution for pic 2
Attached thumbnail(s) |
| davidj |
Oct 24 2011, 12:56 AM
Newbie ![]() Group: Members Posts: 41 Joined: 19-November 08 From: Ventura, Ca Member No.: 9,771 Region Association: Southern California |
Very sweet. Congrats Andyrew, you have rocked it yet again. Take this with a grain of salt: The rockers.... dude, what you going to do wit the rockers? It seems like the flow is interrupted by the fender. Body color? Blacken bottom edge of fender to continue the stripe that's in front and behind that spot? Not picking on it - amazing as is, just thinking out loud. (IMG:style_emoticons/default/agree.gif) Still, this is an awesome 914!! Great Job!! |
| Andyrew |
Oct 24 2011, 10:13 AM
My friend (Photographer) gets a little "edit crazy" sometimes (IMG:style_emoticons/default/biggrin.gif)
| jimkelly |
Oct 24 2011, 11:07 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
those pics are keepers for sure - all of them.
black wheels - red longs - purple dress - wicked awesome shoes she is smoking - and i ain't taliing about the ....... : ) all the best !!! |
| computers4kids |
Oct 24 2011, 06:50 PM
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Andrew,
These pics are awesome...I love them. Great idea. PS I like your side valances painted body color. (IMG:style_emoticons/default/beer.gif) |
| tscrihfield |
Oct 24 2011, 07:03 PM
Drive Fast and Take Chances ![]() ![]() ![]() Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None
(IMG:style_emoticons/default/drooley.gif) Awesome photos!
Now take that lady and drive off into the sunset! (IMG:style_emoticons/default/grouphug.gif) |
| Mike Bellis |
Oct 24 2011, 07:08 PM
Is there a 914 caravan to the wedding? (IMG:style_emoticons/default/poke.gif)
| Andyrew |
Oct 27 2011, 10:52 PM
There is a 914 going FROM the wedding (IMG:style_emoticons/default/smile.gif)
Update on the car, Going in for a dyno tune tomorrow. Im looking for 225whp and 250wtq. (I have to consider that I have 100lbs in wheels and tires in the back) but most importantly im looking for smooth tq curve, smooth power through the powerband, better cruising (it never was that bad..), better cold starts, and better gas mileage. |
| arkitect |
Oct 27 2011, 11:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Andrew,
Good looking picts. Great idea!!!!!!!!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) Dave |
| Andyrew |
Oct 28 2011, 02:18 PM
Dyno tune is done. Found a couple of problems and fixed them (Mostly I was running without the secondary's... Vacuum pod had a solid gasket instead of an O ring. ). I need to figure a bigger air cleaner system as thats witholding some power, and I also need to go a general tuneup (wires, plugs, ect).
Overall it pushed out 235whp and 295wtq. It made at least 250wtq from 2k-5k rpms. I havent gotten to drive it yet but I am sure looking forward to it! Its supposedly very smooth and sounds really good. |
| ewdysar |
Oct 28 2011, 03:03 PM
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
Dyno tune is done. Found a couple of problems and fixed them (Mostly I was running without the secondary's... Vacuum pod had a solid gasket instead of an O ring. ). I need to figure a bigger air cleaner system as thats witholding some power, and I also need to go a general tuneup (wires, plugs, ect). Overall it pushed out 235whp and 295wtq. It made at least 250wtq from 2k-5k rpms. I havent gotten to drive it yet but I am sure looking forward to it! Its supposedly very smooth and sounds really good. Is that still carb'ed or did you switch back to the FI setup? |
Lo-Fi Version | Time is now: 3rd October 2026 - 11:31 PM |
