44 Pages V « < 21 22 23 24 > »
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
Andyrew
post Nov 6 2015, 10:04 AM
Post #431
Spooling.... Please wait
Happy Birthday to me! (IMG:style_emoticons/default/cheer.gif)
I received my new fuel setup in the mail. Very excited about this.
Bosch 1000CC EV fuel injectors (Can run up to a 93% duty cycle reliably) This puts me right at 545HP max at E85 with 43.5psi.
Fuel pump is the outstanding Bosch O44 which is one of the strongest and linear in the industry and can change the fuel pressure if I find that being required.
Now here is the fun bit (IMG:style_emoticons/default/smile.gif)
http://store.034motorsport.com/fully-enclo...-bosch-044.html
Fuel surge tank. This encloses the Bosch 044 fuel pump and allows for it to be submerged constantly(Less noise and cooler running). The surge tank is primed by a carb low pressure fuel pump and remains full constantly effectively preventing any possibility of fuel starvation in corners. This also has the added benefit of allowing me to use the stock style fuel lines since they will be under zero pressure and allow for 100% flow of the lines. I will put this surge tank in the engine bay and it will keep my expensive high pressure lines very short and allow for no line pressure loss due to length (IMG:style_emoticons/default/smile.gif)
Its a win win win!
Presents from my wife.
Ironically my wife checked out my amazon wish list and grabbed a couple items.
1.Low pressure fuel pump
2. Roller and corner roller tools for building the interior
3. Shades (Because you have to look cool)
4. Candy (IMG:style_emoticons/default/smile.gif)
5. Beer chiller
Finally had some friendly competition between my car and her car with her driving on Forza! Very proud that she actually beat me when I was using a stock 914!
Mike Bellis
post Nov 6 2015, 08:02 PM
Post #432
Resident Electrician
turn up the pressure and turn down the duty cycle. I'm running at 4 bar (58.8 psi). 034 recommended my 330cc injectors at that pressure for my hp goal.
Andyrew
post Nov 7 2015, 11:15 AM
Post #433
Really 330CC's? Im really surprised that your able to push those injectors that much... I had 440's that I maxed out and IIRC I was running a 4bar FPR, mind you I was making similar power that you are now. You sure your only on 330's?
And yes I don't plan on running my duty cycle that high, I'm just showing where the injectors currently are at the standard pressure. I am probably going to tune for 4bar FPR. Whatever my tuner thinks is the best for my needs (IMG:style_emoticons/default/smile.gif)
Justinp71
post Nov 16 2015, 02:57 PM
Post #434
With being a recent vw/audi owner (GTI), I am excited to watch this build.
Andrew are you pulling the motor out of the A4?
Andyrew
post Nov 16 2015, 03:56 PM
Post #435
QUOTE(Justinp71 @ Nov 16 2015, 12:57 PM) *
A4 has been sold as a driver. My daily being my Fiesta ST has given me no need for the quattro...
Motor I have is out of the junkyard. Im going to open it up to see if I want to built it. But I am keeping an eye out for a good usable motor. Maybe one with VVT so I can get some more low end.
End goal is to build a motor with cams, ported, oversized titanium valves and springs, rods/ stroker/pistons. Build it to rev to 8500 and put a larger hot side if I feel it needs to breath better up top. That would give me well over 4k rpms of usable power.
post Nov 16 2015, 04:44 PM
Post #436
OT: Just saw your car in the calendar. Great shot! (IMG:style_emoticons/default/evilgrin.gif)
Andyrew
post Nov 16 2015, 05:35 PM
Post #437
Last years calendar right? I specifically didnt enter this year as I was already in it last year and wanted to give more people an opportunity to pop in..
Besides I voted for the hillside shot of the "multiple" cars, my Fiesta ST is actually hiding in the back (IMG:style_emoticons/default/smile.gif)
Andyrew
post Nov 23 2015, 12:06 AM
Post #438
Gotta get back on the horse!
Engine shelf removed/trimmed.
Test mounted the engine/trans then test set it in the engine bay. Looks like to make the axles level the pass side needs to be 1/2" higher than the drivers side when its on the movers dolly. Simple enough (IMG:style_emoticons/default/smile.gif)
Andyrew
post Nov 23 2015, 12:10 AM
Post #439
Im still positioning the setup left,right, up, down, tilt, back. In my head the setup needs to come back an inch and up 2-3, or tilted forward about 5-10 deg to get the trans tucked up a bit more and the axles more level with the suspension. I'd like to get the axles almost level when the car is in its resting position.
Hard to see in this photo, but the trans is about 1" forward of the axles when the engine is touching the firewall.
And finally, started reinforcing the rear shock tower for my brace. I am going to remove the firewall where the blue tape is (did get a full pic of it) and rebuild/box it about 6" back where the shocks are. I'm going to have a local metal shop bend up some steel similar to the 914 humps for strength and weld it in to the 1" bar brace I weld in between the towers. I am going for a near factory look when done.
rightpedal
post Nov 23 2015, 05:48 AM
Post #440
rightpeda;
Are you going to add more support in the front corners of the engine bay? I ask because we were looking at my build car (cut out engine tray) and the parts car (tray intact) thinking that's a fair amount of triangulation/support. Just looking to what others are doing in that arena.
Steve
Andyrew
post Nov 23 2015, 09:17 AM
Post #441
Its a fair amount of triangulation to the firewall which is essentially non structural.
That being said yes there is some additional reinforcements to come in the rear suspension console. Specifically the typical firewall to rear suspension ear. I am debating how exactly I am going to do my engine bar at this point, so I want to make sure everything is as strong as possible.
Mike Bellis
post Nov 23 2015, 09:48 PM
Post #442
I think you will end up cutting out the battery tray. There is very little room once you get everything bolted on. My turbo is smaller than yours... (IMG:style_emoticons/default/sawzall-smiley.gif)
Andyrew
post Nov 23 2015, 10:50 PM
Post #443
My manifold is more compact (IMG:style_emoticons/default/smile.gif)
Ill test mount it after I cut the firewall and see.
Mike Bellis
post Nov 23 2015, 10:54 PM
Post #444
QUOTE(Andyrew @ Nov 23 2015, 09:50 PM) *
I'm running the smallest T3 manifold I could find. Ended up being the cheapest too.
Andyrew
post Nov 26 2015, 12:34 AM
Post #445
It fits just fine (IMG:style_emoticons/default/smile.gif) in fact the manifold is about an inch away from the head so itll suck in more.
Also I got my water to air intercooler. Big hunking thing, a full 20lbs.
Mike Bellis
post Nov 26 2015, 05:27 PM
Post #446
QUOTE(Andyrew @ Nov 25 2015, 11:34 PM) *
That turbo sites nice and low! More pics please...
Andyrew
post Dec 1 2015, 08:33 AM
Post #447
Overnight Parts from Japan! (IMG:style_emoticons/default/shades.gif) left is radiator tank for the water injecton (might not use this), middle is gold foil heat shielding, and right is turbo blanket.
YZ85 radiator. Should make a nice water to air intercooler radiator. Shown in the dr side fenderwell.
Electronic boost controller. Best on the market for features. Used this one many times.
Davies Craig EWP130 water pump with LCD controller. Really happy about this one (IMG:style_emoticons/default/smile.gif)
Andyrew
post Dec 1 2015, 08:40 AM
Post #448
I did a thing... welded in a reinforcement to the shock towers prior to making the cut. Im going to cover the hole in ribbed 16ga steel. But before I do that ill box in a reinforcement to the shock tower from the rear long and seam weld all the joints for strength.
Not pictured but I got the injectors back from cleaning. Apparently they are 1300cc injectors not 1000cc, so lots of headroom for e85, should keep the injectors nice and efficient.
Justinp71
post Dec 7 2015, 12:31 PM
Post #449
Looking Good! What turbo are you running?
Andyrew
post Dec 7 2015, 02:04 PM
Post #450
Justin,
Comp Turbo triple ball bearing CTB5356 About the size of a GT3071R.
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th November 2026 - 10:22 AM
