| Justinp71 |
Dec 7 2015, 12:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
Looking Good! What turbo are you running?
| Andyrew |
Dec 7 2015, 02:04 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Justin,
Comp Turbo triple ball bearing CTB5356 About the size of a GT3071R. |
| Andyrew |
Dec 7 2015, 02:35 PM
Progress from this weekend.
Triangulated the rear shock tower against the frame with 14ga steel. Also seam welded the frame to shock tower joint (not pictured). Reinforced the suspension ear with a Tangerine Racing reinforcement kit, and then my sheet of 14ga for mounting the brace to. Engine with turbo mounted. (IMG:style_emoticons/default/smile.gif) Brace mounted to the firewall and suspension ear. You can see the turbo mounted (Bolted in all the way). Plenty of room! This is with the engine in place. I didnt mount it up because I wasnt happy with the height of the engine/trani. I move the front of the engine up 3/4" and the rear of the trani up 1 1/2". I'll get that in place this week and hopefully that will be where I want it to sit. |
| Andyrew |
Dec 16 2015, 09:02 AM
Progress from this extended weekend. There wont be any more progress until after christmas and maybe not even this year.. But I hope I can put a couple more hours in and finally mount the engine in place.
This may seem overkill but this seemed to be the most solid way to mount this. Instead of coming off the engine bar I made that goes under the engine I decided to come off the front of the motor mount. I am currently debading if I want to cut off the crossmember alltogether to save 4lbs, but I am leaning towards no. Great pic showing the relationship to the mounts. You can see 4 really easy to get to bolts and the front is out. Put the shift linkage on the test trani (Audi a4 1.8t fwd) only difference was I had to remove about 1/4" from a bolt mount to match the other trani. And then came the issue I was not expecting. My shift linkage was touching the trans mount. This is without the cable being attached to the linkage which adds 3/4"... At this point I wasnt sure how to proceed. |
| Andyrew |
Dec 16 2015, 09:12 AM
You can see its pretty much touching. You can also see in this the bar mounted to the trans mount. Its currently facing right but it will be facing forward and joined to the two pipes you can see jutting out from the trans. So what to do? Well move the mount over of course! This took longer than I had anticipated... the spot welds were a PITA and I broke my spot weld remover as well.. (still had 5 bits left too (IMG:style_emoticons/default/mad.gif) ) And finally A really cool temp controller. Tested on the bench and it works great. Audible relay click when it hits the set temp, and there is a 2 deg buffer. Its got provisions for keeping the temp both hot and cold which is really cool! With all these screens I have I am debating the "stockish" dash display I have. I have an idea that could work well for hiding these. |
| 76-914 |
Dec 16 2015, 06:27 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,926 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Incorporate a hinged face plate onto the dash face that folds up to reveal digi's? (IMG:style_emoticons/default/confused24.gif) Good to see you working on your build again, Andrew. One thing about fabbing shit up. Be prepared to do, re-do and then re-do again. (IMG:style_emoticons/default/headbang.gif)
| Andyrew |
Dec 16 2015, 06:38 PM
Yup a hinged face trim on the pass side is my first idea. Second is a magnetic or snap in trim that I can remove/install. I dont have a glove box figured in my install but I could make it a large glove box that hinges or slides down.
| 76-914 |
Dec 16 2015, 07:29 PM
Yup a hinged face trim on the pass side is my first idea. Second is a magnetic or snap in trim that I can remove/install. I dont have a glove box figured in my install but I could make it a large glove box that hinges or slides down. HF has some small (appx 8mm rd. x 2mm) rare earth magnets for < $5. |
| Andyrew |
Dec 16 2015, 08:03 PM
Yup. Thought about putting that behind the fiberglass trim. I would be worried about noise/vibration though.
It also doesnt allow me to quickly check the displays so Im leaning towards hinged. |
| Andyrew |
Dec 26 2015, 08:51 AM
Quick present recap. Amazon wish lists are awesome (IMG:style_emoticons/default/smile.gif)
From left to right. 6" sub, Water injection pump, 1000w Amp, 5.5" speakers, Valve train bits, Amp volume controller, "8ga" amp install kit, Tubing flare, Tubing bender, Media button, Tweeters, 914mug/stickers, Flexible ruler. The only thing left for my Stereo is the actual tablet. But I'll wait till it gets closer for that. I can run my phone till I get something that will work for a long time. |
| 76-914 |
Dec 26 2015, 09:04 AM
Cool presents. Hopefully we can all get kitchen pass' to work on our cars this weekend. (IMG:style_emoticons/default/beerchug.gif)
| Andyrew |
Dec 26 2015, 06:57 PM
I got a pass to go for a drive with my cousin which was really nice so I call that a win (IMG:style_emoticons/default/smile.gif)
I think I will be able to find some time this week to finally weld in the mounts for the engine/trani. Thats my goal, Not sure if I can get it done but it will be a HUGE step forward if I can get it mounted. |
| Andyrew |
Jan 1 2016, 12:26 PM
My final update for December 2015 is below (IMG:style_emoticons/default/smile.gif)
Guess who welded up the engine/trani mounts for their final position? ![]() I'll add one support to this, I dont have any bolts on the trani closer up top that will triangulate this for load so I am going to use the hoist hole for one. This is immediately after tack welds, They are all 90% welded now, but will finish that up in January. I was able to remove the 8 bolts holding it all together (4 up front and the 4 trani bolts for the oem mounts) and raise the car up in a couple minutes. Really happy with how that turned out (IMG:style_emoticons/default/smile.gif) |
| 76-914 |
Jan 1 2016, 02:34 PM
Muy congrats, Andrew. Question. In your last pic, I see you cut out the piece adjacent to the trunk light and then welded a piece back in the same spot? Re-enforcement or change of plans? More pics, pls. (IMG:style_emoticons/default/beerchug.gif)
| Andyrew |
Jan 1 2016, 02:42 PM
That 1' cutout is for the distributor on a SBC conversion. Different clearancing is needed for the Audi engine.
| dan10101 |
Jan 1 2016, 03:03 PM
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Looking good. Progress!
| Mike Bellis |
Jan 1 2016, 09:17 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
| Andyrew |
Jan 2 2016, 11:49 AM
From yesterday, Finished off the welding on the body and the mounts, added the support, cutoff the excess and welded plugs to prevent rusting. Bench tested my boost controller finally and its bad.... (IMG:style_emoticons/default/headbang.gif) Trying to get a refund from ebay but the guy that sold it to me didnt sell me the wiring harness (he played stupid in his auction, stating it was something else...) so I had to wait for a harness from China to come in and when I tested it well... ya. Dead LCD. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-172-1451756993.1.jpg) So there happens to be a sale going on right now for another EBC that I am interested in. 6 settings (Which I like....) and its programed via computer. Gear based, RPM based, speed based, and can control my water injection as well (awesome!) Its very small so it would fit with my dash layout much better than the other one as well which I like. http://www.usrallyteam.com/index.php?main_...roducts_id=2017 |
| paroxysm |
Jan 2 2016, 09:19 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 4-April 04 From: chilliwack bc canada Member No.: 1,888 |
Not trying to hijack your thread
It looks very similar to my build, but for my rear tranny mount I just built an adapter. I certainly need to upgrade my shifter assembly to be more rugged like yours mine was just some spare VW mk3 parts I had laying around. (IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.3.jpg) I hope to just finish this car enough to drive the bugs out of it this year. Anyone know if I can drive on a base stage 3 big turbo tune? Or should I try and dyno tune this thing without any of the bugs worked out? |
| Andyrew |
Jan 2 2016, 10:51 PM
Awesome!
Do you have an active build thread on here? If not you should really make one, your build looks interesting! I think you have your engine about 2" forward of mine, do you have any cv issues and what cvs are you using? What turbo are you using and what turbo is your stage 3 file for? I ran my turbo on my apr stage 3 file(made for a gr28rs) and didnt have any issues at 10psi but I was getting stuttering above that. You can get it tuned by some online tuners that give you a base tune and then fine tune it from logs you run. |
Lo-Fi Version | Time is now: 5th August 2026 - 06:18 AM |
