44 Pages V « < 22 23 24 25 > »
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
Andyrew
post Dec 7 2015, 02:35 PM
Post #451
Spooling.... Please wait
Progress from this weekend.
Triangulated the rear shock tower against the frame with 14ga steel. Also seam welded the frame to shock tower joint (not pictured).
Reinforced the suspension ear with a Tangerine Racing reinforcement kit, and then my sheet of 14ga for mounting the brace to.
Engine with turbo mounted. (IMG:style_emoticons/default/smile.gif)
Brace mounted to the firewall and suspension ear. You can see the turbo mounted (Bolted in all the way). Plenty of room! This is with the engine in place. I didnt mount it up because I wasnt happy with the height of the engine/trani. I move the front of the engine up 3/4" and the rear of the trani up 1 1/2". I'll get that in place this week and hopefully that will be where I want it to sit.
Andyrew
post Dec 16 2015, 09:02 AM
Post #452
Progress from this extended weekend. There wont be any more progress until after christmas and maybe not even this year.. But I hope I can put a couple more hours in and finally mount the engine in place.
This may seem overkill but this seemed to be the most solid way to mount this. Instead of coming off the engine bar I made that goes under the engine I decided to come off the front of the motor mount. I am currently debading if I want to cut off the crossmember alltogether to save 4lbs, but I am leaning towards no.
Great pic showing the relationship to the mounts. You can see 4 really easy to get to bolts and the front is out.
Put the shift linkage on the test trani (Audi a4 1.8t fwd) only difference was I had to remove about 1/4" from a bolt mount to match the other trani.
And then came the issue I was not expecting. My shift linkage was touching the trans mount. This is without the cable being attached to the linkage which adds 3/4"... At this point I wasnt sure how to proceed.
Andyrew
post Dec 16 2015, 09:12 AM
Post #453
You can see its pretty much touching. You can also see in this the bar mounted to the trans mount. Its currently facing right but it will be facing forward and joined to the two pipes you can see jutting out from the trans.
So what to do?
Well move the mount over of course! This took longer than I had anticipated... the spot welds were a PITA and I broke my spot weld remover as well.. (still had 5 bits left too (IMG:style_emoticons/default/mad.gif) )
And finally A really cool temp controller. Tested on the bench and it works great. Audible relay click when it hits the set temp, and there is a 2 deg buffer. Its got provisions for keeping the temp both hot and cold which is really cool! With all these screens I have I am debating the "stockish" dash display I have. I have an idea that could work well for hiding these.
post Dec 16 2015, 06:27 PM
Post #454
Incorporate a hinged face plate onto the dash face that folds up to reveal digi's? (IMG:style_emoticons/default/confused24.gif) Good to see you working on your build again, Andrew. One thing about fabbing shit up. Be prepared to do, re-do and then re-do again. (IMG:style_emoticons/default/headbang.gif)
Andyrew
post Dec 16 2015, 06:38 PM
Post #455
Yup a hinged face trim on the pass side is my first idea. Second is a magnetic or snap in trim that I can remove/install. I dont have a glove box figured in my install but I could make it a large glove box that hinges or slides down.
post Dec 16 2015, 07:29 PM
Post #456
QUOTE(Andyrew @ Dec 16 2015, 04:38 PM) *
HF has some small (appx 8mm rd. x 2mm) rare earth magnets for < $5.
Andyrew
post Dec 16 2015, 08:03 PM
Post #457
Yup. Thought about putting that behind the fiberglass trim. I would be worried about noise/vibration though.
It also doesnt allow me to quickly check the displays so Im leaning towards hinged.
Andyrew
post Dec 26 2015, 08:51 AM
Post #458
Quick present recap. Amazon wish lists are awesome (IMG:style_emoticons/default/smile.gif)
From left to right.
6" sub, Water injection pump, 1000w Amp, 5.5" speakers, Valve train bits, Amp volume controller, "8ga" amp install kit, Tubing flare, Tubing bender, Media button, Tweeters, 914mug/stickers, Flexible ruler.
The only thing left for my Stereo is the actual tablet. But I'll wait till it gets closer for that. I can run my phone till I get something that will work for a long time.
post Dec 26 2015, 09:04 AM
Post #459
Cool presents. Hopefully we can all get kitchen pass' to work on our cars this weekend. (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Dec 26 2015, 06:57 PM
Post #460
I got a pass to go for a drive with my cousin which was really nice so I call that a win (IMG:style_emoticons/default/smile.gif)
I think I will be able to find some time this week to finally weld in the mounts for the engine/trani. Thats my goal, Not sure if I can get it done but it will be a HUGE step forward if I can get it mounted.
Andyrew
post Jan 1 2016, 12:26 PM
Post #461
My final update for December 2015 is below (IMG:style_emoticons/default/smile.gif)
Guess who welded up the engine/trani mounts for their final position?
I'll add one support to this, I dont have any bolts on the trani closer up top that will triangulate this for load so I am going to use the hoist hole for one.
This is immediately after tack welds, They are all 90% welded now, but will finish that up in January. I was able to remove the 8 bolts holding it all together (4 up front and the 4 trani bolts for the oem mounts) and raise the car up in a couple minutes. Really happy with how that turned out (IMG:style_emoticons/default/smile.gif)
post Jan 1 2016, 02:34 PM
Post #462
Muy congrats, Andrew. Question. In your last pic, I see you cut out the piece adjacent to the trunk light and then welded a piece back in the same spot? Re-enforcement or change of plans? More pics, pls. (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Jan 1 2016, 02:42 PM
Post #463
That 1' cutout is for the distributor on a SBC conversion. Different clearancing is needed for the Audi engine.
dan10101
post Jan 1 2016, 03:03 PM
Post #464
TORQUE-o-holic
Looking good. Progress!
Mike Bellis
post Jan 1 2016, 09:17 PM
Post #465
Resident Electrician
Andyrew
post Jan 2 2016, 11:49 AM
Post #466
From yesterday, Finished off the welding on the body and the mounts, added the support, cutoff the excess and welded plugs to prevent rusting.
Bench tested my boost controller finally and its bad.... (IMG:style_emoticons/default/headbang.gif) Trying to get a refund from ebay but the guy that sold it to me didnt sell me the wiring harness (he played stupid in his auction, stating it was something else...) so I had to wait for a harness from China to come in and when I tested it well... ya. Dead LCD.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-172-1451756993.1.jpg)
So there happens to be a sale going on right now for another EBC that I am interested in. 6 settings (Which I like....) and its programed via computer. Gear based, RPM based, speed based, and can control my water injection as well (awesome!) Its very small so it would fit with my dash layout much better than the other one as well which I like.
http://www.usrallyteam.com/index.php?main_...roducts_id=2017
paroxysm
post Jan 2 2016, 09:19 PM
Post #467
Not trying to hijack your thread
It looks very similar to my build, but for my rear tranny mount I just built an adapter.
I certainly need to upgrade my shifter assembly to be more rugged like yours mine was just some spare VW mk3 parts I had laying around.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i106.photobucket.com-1888-1451791151.3.jpg)
I hope to just finish this car enough to drive the bugs out of it this year. Anyone know if I can drive on a base stage 3 big turbo tune? Or should I try and dyno tune this thing without any of the bugs worked out?
Andyrew
post Jan 2 2016, 10:51 PM
Post #468
Awesome!
Do you have an active build thread on here? If not you should really make one, your build looks interesting! I think you have your engine about 2" forward of mine, do you have any cv issues and what cvs are you using?
What turbo are you using and what turbo is your stage 3 file for? I ran my turbo on my apr stage 3 file(made for a gr28rs) and didnt have any issues at 10psi but I was getting stuttering above that. You can get it tuned by some online tuners that give you a base tune and then fine tune it from logs you run.
paroxysm
post Jan 3 2016, 12:17 PM
Post #469
QUOTE(Andyrew @ Jan 2 2016, 08:51 PM) *
Awesome!
http://www.914world.com/bbs2/index.php?sho...0stuka&st=0
This should be my build thread.
The turbo is a gt28rs, my program is revo stage 3 for the turbo. My motor is an AWW 2001 with only 7000 kilometers on it, I paid $1200 for it.
The motor came with a electronic boost controller(not hooked up yet), walboro fuel pump, wideband O2 sensor, genesis 500cc fuel injectors, all new never used.
Now for the CV passenger side is a stock 911 with a empty CV case from a passat B5 used as a spacer, drivers side is a bmw 540i that was the correct length. Don't know how long they last but I had to go cheap for now and that setup only cost $10.
Only problem I've been experiencing is sometimes the car refuses to shut off, place the key in the off position car tries to shut down but then it revs up and continues running, also if I put the car in reverse with the ignition off the backup lights are on.
Andyrew
post Jan 3 2016, 01:22 PM
Post #470
Ill continue this post on your thread (IMG:style_emoticons/default/smile.gif)
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th November 2026 - 10:31 AM
