44 Pages V « < 28 29 30 31 > »
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
Andyrew
post Jun 14 2016, 10:18 PM
Post #570
Spooling.... Please wait
QUOTE(r_towle @ Jun 14 2016, 08:30 PM) *
When you figure all of this out, will you do my 4.2 conversion?
Wiring would probably be similar, but no.. I have probably 3-500 hours into this conversion so far, and a good 50 of it in wiring alone with what is likely another 20 to go before the chassis is all wired.
In the future if this conversion gets popular I might entertain making kits or doing all the wiring mods, but its so much custom stuff it just doesnt make sense. You pretty much have to just fabricate everything.
Andyrew
post Jun 18 2016, 10:03 PM
Post #571
Ill fill in details later. Still issues, but this did happen.
https://www.youtube.com/watch?v=qSrB9kXreM4
Chris H.
post Jun 18 2016, 11:05 PM
Post #572
Congrats! That's a big payoff moment for hours of tracing wires, cross-referencing diagrams, fabricating, welding, etc, etc. Nice work.
914forme
post Jun 19 2016, 07:43 AM
Post #573
Huge step, congratulations (IMG:style_emoticons/default/piratenanner.gif)
mgp4591
post Jun 19 2016, 08:16 AM
Post #574
Hell yeah! Congratulations! (IMG:style_emoticons/default/aktion035.gif)
Mueller
post Jun 19 2016, 09:16 AM
Post #575
914 Freak!
Sounds good, I like!
Mike Bellis
post Jun 19 2016, 11:28 AM
Post #576
Resident Electrician
Awesome! (IMG:style_emoticons/default/piratenanner.gif)
Now all you need to do is finish... (IMG:style_emoticons/default/poke.gif)
dan10101
post Jun 19 2016, 09:07 PM
Post #577
TORQUE-o-holic
I like the tune it plays wish I could have been there to hear it. But, I'd rather have it happen without me than not happen with me.
Is is it loud, 11 of 10 or 9 of 10?
I like it either way!
Andyrew
post Jun 19 2016, 10:10 PM
Post #578
Its louder than I expected. Its basically 3" straight pipe..
I dont think the mufflers do much at all (IMG:style_emoticons/default/smile.gif) I might need to put a chambered muffler in there somewhere. Cruising on the freeway may be a bit.. loud.
post Jun 20 2016, 08:19 AM
Post #579
QUOTE(Andyrew @ Jun 18 2016, 09:03 PM) *
Congrats Andrew. (IMG:style_emoticons/default/piratenanner.gif) We need a Gene Wilder avatar that screams "It's alive". (IMG:style_emoticons/default/beerchug.gif)
matthepcat
post Jun 20 2016, 10:02 AM
Post #580
Meat Popsicle
You might try some exhaust inserts. I used a brand called "car chemistry" on my old V8 and was able to reduce some drone. Not sure on a turbo car though.
Sounds great
QUOTE(Andyrew @ Jun 19 2016, 09:10 PM) *
Andyrew
post Jun 27 2016, 01:48 PM
Post #581
Not much progress over the weekend, Worked on wiring a couple things and figuring out some other things. I dont want to start the car again until I am ready to put some load on the rings. I think I figured out why my 02 sensor and MAF sensor are not reading, I dont think they are getting 12v. I found out that wiring and will force them to get 12v with a keyed trigger.
I do know that the oil pan as well as I assume the front main seal or oil shaft seal is leaking. Not happy about that because all the seals are new. After I get some break in miles I'll pull the engine, finish off the rear engine shelf, check for other potential issues and clean things up some more.
Matt, thanks for the tip on inserts, That is certainly a good option. Since my exhaust is V banded I could possibly just make a new exhaust with more restrictive muffler. I'll get some sound charts later after some break in.
Andyrew
post Jul 1 2016, 10:01 PM
Post #582
Final June Update:
Finished up a bunch more little things like all the hose clamps I was missing and fixed my fuel leak that developed.
I am still not getting the car running with the MAF connected and I havent gotten a reading from the O2 but I havent forced power to it yet. I am going to try forcing that again before I get it on the road for some fuel correction but that will need to be next month.
I was able to hook up the boost controller and run my vacuum lines to my boost controller, solenoid, DV, and wastegate actuator. I just need to figure out my throttle angle sensor wire and tap into that for my boost controller.
And here is the final engine bay layout. (EDIT: Just noticed the positive wire was hanging down. Put that back up tucked away..)
Stay tuned! In about 2 weeks you'll see it hit the road (IMG:style_emoticons/default/smile.gif)
Mueller
post Jul 1 2016, 10:20 PM
Post #583
914 Freak!
Awesome!
cali914
post Jul 2 2016, 07:58 AM
Post #584
cali914
Awesome you will have to get a chamber muffler I had to canister mufflers on mine and had to replace the drone was killing me at 3k rpm on highway.
Mike Bellis
post Jul 2 2016, 10:50 AM
Post #585
QUOTE(matthepcat @ Jun 20 2016, 09:02 AM) *
Sounds great
I would be worried about back pressure with these. back pressure is good for a NA motor, not so good for a turbo application.
It may come down to muffler selection. I run a 4" Aero Turbine muffler and I like the sound. Not too much drone.
Andyrew
post Jul 11 2016, 01:12 PM
Post #586
This weekend was the beginning of the end of wiring the engine.
I got the MAF figured out. I had the power and voltage wire mixed up, swapped those around and it is running really well.
I finished wiring up the boost gauge as well as the water pump and fans with a relay.
However...
When I tested the coolant system I think there was either a design flaw with the water pump OR my water pump is not doing its job. I have/had the temp sensor mounted up near the radiator. It was supposed to cycle the pump from key on to move the water to the temp sensor but it was barely moving any water from what I could tell from the lines. I am now thinking that 8' is just to long for it to get to the sensor on a low speed pulsing cycle.
I am relocating the temp sensor on to the back of the engine right off the coolant flange. It takes a 1/4" NPT sensor so I found a galvanized steel NPT adapter and will weld it in so long as it takes a weld well. This way the radiant heat from the block should get to the sensor much quicker and should start actually cycling the water pump at full power, see image below.
I am going to test the system again after moving the sensor and if it ends up the way I like it then I'll wrap up the wiring, drop the car on the ground and take it for a test drive. The oil leak is more of a concern now. I was hoping to put a couple hundred break in miles but I think that it might be dripping oil at a decent rate. It doesnt leak unless the engine is running which helps a bit.
Anyways, stay tuned. (IMG:style_emoticons/default/smile.gif)
Mike Bellis
post Jul 11 2016, 01:30 PM
Post #587
Sensor at the engine inlet might be better. Water temp at the engine is more important than at the radiator.
I notice on mine the fans kick on at 180­° but the motor is running 190°. the water might heat back up a little as it returns to the motor due to heat soak in the hose.
Andyrew
post Jul 11 2016, 01:44 PM
Post #588
It'll be at its hottest point right off the back of the engine so thats a plus..
Once I get the damn thing working I'll just pick a temp I dont want it any higher than and go. I was thinking 185* should be good. I had it at 140* just to make sure the system cycles properly. And if I can get it to maintain 140* in my garage on a hot day then it should prove the system pretty efficient.
Andyrew
post Jul 18 2016, 03:36 PM
Post #589
So,
I finished off the radiator system, put the seals on the radiator and buttoned it up. Found a small leak on the turbo feed line and fixed it. Put the wheels back on and checked everything in that regard, backed it out of the driveway and took it for its first spin around the block (IMG:style_emoticons/default/smile.gif)
https://www.youtube.com/watch?v=Tl_GCoEC9-U
https://www.youtube.com/watch?v=YOCFI15nTfU
https://www.youtube.com/watch?v=36CBdqYQN-4
I'll be posting a youtube video weekly either as progress of the vehicle or myself driving the car (IMG:style_emoticons/default/smile.gif)
Findings of the first drive:
1. Steering needs to be fixed. Pretty sure the shaft got welded unevenly. I will be buying some new shafts and starting from scratch instead of trying to use mine. It works for now but who knows. You can see me struggling as the knuckle is binding. Everything is exactly in the same layout as factory its just 1/8" off center and I think that is causing the problem.
2. Clutch is on the floor. I will put some spacers behind the slave cylinder to get a bit more action out of the clutch. I'd like it to be an inch off the floor to halfway through the travel. Clutch is however very light and easy to modulate. Probably the reason why its all the way on the floor is I didnt give it enough travel thus making the action much easier. I will also re-bleed it and see if that helps.
3. The engine bar was loose after the run. I tightened it up with some red lock tight, It might not have been snugged down all the way the first time... If it keeps loosening up I might double nut them. I painted a line on the nuts like factory to determine if anything loosens up.
4. I need a smaller wheel and I need the wheel to be removable.
5. The water pump and controller work fantastic. I drove the car around for 5 minutes then let it idle. You can see in the video that it stays pretty cool. I had it set for a higher temp and dropped the controller down down in another video to see what would happen. The water pump turned on constant and the fans kicked on. Shut off the car and both the fans and water pump stayed on for one minute and then shut off (IMG:style_emoticons/default/smile.gif)
6. The turbo is not a low RPM turbo. I gave it 1/2 throttle a lot and fed into it a couple times and while the turbo will start spooling around 2500 it doesnt seem to really make much boost until about 3500. Similar to what I remembered, but the heavy weight of the Audi A4 made it hold the RPM's more thus spooling technically faster.
7. 1st gear is going to be a handful even at 10psi... You can see in one of the video's I give it about 3/4 throttle over 4k rpms (I had my hand in the way so I dont know what RPM I shifted..), I am pretty sure the tires spun because the RPM's climbed so quickly. I am really glad I have an 8500rpm redline because I am going to need that in first gear..
8. Its fast. Damn fast. I havent gone full throttle or even reved it out at all, but its going to be a monster.
9. Its F'in LOUD. The blow off valve is very loud and crisp. I know for a fact I cant drive it over 5k in the neighborhood or else I am sure the cops will be called. Im sure you can hear the blow off valve from a mile away. I'm going to have to route the blow off into the intake to quiet it down some.
- Lo-Fi Version Time is now: 9th September 2025 - 11:27 PM
