| Andyrew |
Aug 16 2018, 08:34 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Got some new tools and consumables. Not pictured is more heat shrink (3:1), and a new butane torch.
Last night I spent an hour stripping the wires of tape(thread remover works great if your slow to avoid crossed wires) and cutting a couple unused plugs out. Probably a pound of wire removed. I'll weigh it all when done. I've got to do this real slowly to not cut anything critical out. Attached thumbnail(s) |
| Mueller |
Aug 16 2018, 08:51 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Got some new tools and consumables. Not pictured is a new 60watt soldering iron with orange case (IMG:style_emoticons/default/smile.gif) , flux, solder, heat shrink terminal kit, and on the way is more heat shrink (3:1), and a new butane torch. Last night I spent an hour stripping the wires of tape(thread remover works great if your slow to avoid crossed wires) and cutting a couple unused plugs out. Probably a pound of wire removed. I'll weigh it all when done. I've got to do this real slowly to not cut anything critical out. More tools...nice! Things I don't see in the picture....safety glasses, a carbon filter exhaust fan and a "third hand" (IMG:style_emoticons/default/smile.gif) |
| Andyrew |
Aug 16 2018, 08:56 AM
Got some new tools and consumables. Not pictured is a new 60watt soldering iron with orange case (IMG:style_emoticons/default/smile.gif) , flux, solder, heat shrink terminal kit, and on the way is more heat shrink (3:1), and a new butane torch. Last night I spent an hour stripping the wires of tape(thread remover works great if your slow to avoid crossed wires) and cutting a couple unused plugs out. Probably a pound of wire removed. I'll weigh it all when done. I've got to do this real slowly to not cut anything critical out. More tools...nice! Things I don't see in the picture....safety glasses, a carbon filter exhaust fan and a "third hand" (IMG:style_emoticons/default/smile.gif) Safety glasses are directly above the table. That big ass fan isnt big enough for you? And nope, I dont have a "third hand" yet. Im thinking of putting a "T" track in the front of my table and putting a third hand in it. Havent gotten around to soldering yet, just thinning out the harness still (And probably for another couple weeks if I work on it every other night). |
| dan10101 |
Aug 16 2018, 09:00 AM
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Finnegan's garage is giving away a $2500 worth of tools for wiring etc.
https://www.youtube.com/watch?v=DNwjFWv3iNs All you have to do is comment something that catches his eye or his heart. What you have looks good. Good tools are the key... |
| 76-914 |
Aug 16 2018, 02:36 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,927 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Something I found invaluable was the dual range heat gun from HF ($14.99) https://www.harborfreight.com/1500-watt-dua...1112-62340.html and the helping hands tool ($4.99) https://www.harborfreight.com/Helping-Hands-60501.html
The dual range heat gun is perfect for the Heat Shrink. Find the perfect temp setting for whichever style your using then set it and forget it. IIRC, 730F was perfect for melting the silicone in the Marine grade. The helping hands is that 3rd hand but doesn't let the wires move as we do by hand. Rather than twist the wires together I like to slide the exposed ends upon each other then push any stray wires back in before soldering. This way I don't end up with a knot or bulge after soldering. It's not important but looks a lot neater and I don't need the next larger size of heat shrink for it to slide over the hump. Does that make sense? I know that you know this but many guy's don't. A perfect resin core solder joint will shine when set. If the soldered object is allowed to cool too quickly (eg by blowing on it) or moves before it is set then the joint will appear cloudy indicating an improper solder joint. Before sure that you have a Cold Beer each evening afterwards so you can relax. (IMG:style_emoticons/default/biggrin.gif) |
| Mike Bellis |
Aug 16 2018, 06:44 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Tried that, replaced the plug with no change. My coolant temp comes up like normal as well. Its all taken apart now ready for inspection/cleaning and continuity testing. This is a video explaining the wiring. Note its a bit difficult to follow as it was about 12:30am and I was a bit tired. My temp came up fine too. The water sensor is a dual element. One goes to the gauge and one to the ECU. It was the ECU wire that had an intermittent connection. Check all the plugs for every system and try to pull out the wire from the metal terminal. Pull hard. Don't be afraid to yank on it. Like I said, failure at this type of connection point is a known point of failure and run problems. I've even seen some crimps where they crimp over the insulation. This works for a while and then wiggles out of contact. |
| Mike Bellis |
Aug 16 2018, 06:45 PM
What does you VCDS say the problem is? When was the last time you did a throttle body calibration?
| Andyrew |
Aug 16 2018, 07:01 PM
What does you VCDS say the problem is? When was the last time you did a throttle body calibration? I can no longer connect to the obd2. This happened about 3 months after the issue. Vcds showed bad crank position sensor, then it stopped showing an issue, then I could no longer connect to it. Another reason why I'm doing the wiring cleanup. |
| Andyrew |
Aug 16 2018, 07:04 PM
Tried that, replaced the plug with no change. My coolant temp comes up like normal as well. Its all taken apart now ready for inspection/cleaning and continuity testing. This is a video explaining the wiring. Note its a bit difficult to follow as it was about 12:30am and I was a bit tired. My temp came up fine too. The water sensor is a dual element. One goes to the gauge and one to the ECU. It was the ECU wire that had an intermittent connection. Check all the plugs for every system and try to pull out the wire from the metal terminal. Pull hard. Don't be afraid to yank on it. Like I said, failure at this type of connection point is a known point of failure and run problems. I've even seen some crimps where they crimp over the insulation. This works for a while and then wiggles out of contact. I changed the sensor 3 times then changed the wiring twice. Another item I'll be checking while doing the wiring again. All the junkyard connectors we're junk. I haven't found a source for the connector new or else I would do that. |
| Andyrew |
Aug 16 2018, 11:36 PM
Progress from tonight. More of the easy slow stuff. Removed about 10 connectors I don't need. Probably about 15 left to cut out throughout the harness, these were all in two simple clumps.
I am still leaving some wires to trim in case I find I make a mistake and need to solder one back. I'll power up the system and test it before I trim everything back and finish the looms. Attached thumbnail(s) |
| Andyrew |
Aug 18 2018, 02:25 AM
Cleared out some more wiring but as I was doing the light wiring I got worried that I was clearing out too much... So I removed the relay holder, the turn signal/wiper/headlight stalks and the ignition switch and my battery and set it all up on the bench. I was able to figure out the headlights but I didn't get the turn signals to work with a test light. So I'm going to finish up the wiring the best that I can tell for the lights and add some connectors at appropriate lengths and then I will put it in the car. I suspect that it needs more bulbs/resistance to work. The hazard switch works great and it's what holds the turn signal relay.
I spent a bit of time writing out all the wiring per the diagrams I have so I can confirm I did wire it up appropriately the first time. I have been having issues with one of the headlight fuses constantly going out so I suspect I have it on the wrong wire/ fuze/ something so that's one of my big things I'm working on solving with this wiring. The loom is substantially thinner at this point, and I have a lot of wires I still can remove/trim. Note I still have the engine harness to go through. I just decided to start with this as I'm going to be spending a considerable amount of time measuring and lengthening/shortening the wires for the engine harness. Attached thumbnail(s) |
| Andyrew |
Aug 22 2018, 08:42 PM
I did someore trimming a couple nights ago, no pics. I went over the lights and turn signal situation and I have a bit more to do but I think I have it figured out. I am ready to start trimming the engine harness and in doing so I'll be able to trim the chassis harness a bit more as well. After all the triming I'll size everything to proper lengths and move from there.
Monday night I was modifying some steel frames for work (I rarely do this kind of stuff in my position, but I needed it done faster than my shop was going to be able to do it) and I got a piece of metal in my eye. I didn't notice it till yesterday after work and thus made an emergency trip to my optometrist, who luckily is a family friend and I can typically pull strings when needed like this. Got it out and after a hard night last night I am feeling better. Still blurry but I'm dialated pretty good and he took a bit of material out as there was a little rust. However it's healing well (follow-up appointment) so no worries there. Back on topic I decided to replace my failing welding helmet, and I took the advice of you guys and got a nice set of helping hands. I should have a little bit more progress this weekend. I should be testing the system sometime in the next month and then wrapping it for good. Attached thumbnail(s) |
| dan10101 |
Aug 22 2018, 09:58 PM
Hmm, DejaView all over again.
Or was it me last time... #Dadmodeon Wear your safety equipment!!! #Dadmodeoff Glad you got it taken care of. |
| Andyrew |
Aug 23 2018, 07:03 AM
I was wearing my good goggles.. damn dremmels just kick out a ton of debris. I'm getting a full face mask to use over my goggles. When I am using the dremmel it typically shoots the Sparks directly in my face, and I have to be very close to see perfectly (IMG:style_emoticons/default/sad.gif)
| 76-914 |
Aug 23 2018, 08:22 AM
Careful with those eyes. Replacement parts rival Porsche parts in price. Your heading down the right path. Should be a runner soon. Stay after it. (IMG:style_emoticons/default/beerchug.gif)
| worn |
Aug 23 2018, 12:47 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,637 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I was wearing my good goggles.. damn dremmels just kick out a ton of debris. I'm getting a full face mask to use over my goggles. When I am using the dremmel it typically shoots the Sparks directly in my face, and I have to be very close to see perfectly (IMG:style_emoticons/default/sad.gif) Have used the dremmel a lot and find that wire brush wheels are extremely dangerous. To the point where I had a piece of stainless brush wire pierce through my nose. Not really that keen on jewelry and it could have been my eye. |
| Andyrew |
Aug 23 2018, 12:52 PM
I was wearing my good goggles.. damn dremmels just kick out a ton of debris. I'm getting a full face mask to use over my goggles. When I am using the dremmel it typically shoots the Sparks directly in my face, and I have to be very close to see perfectly (IMG:style_emoticons/default/sad.gif) Have used the dremmel a lot and find that wire brush wheels are extremely dangerous. To the point where I had a piece of stainless brush wire pierce through my nose. Not really that keen on jewelry and it could have been my eye. Wire brush wheels are not my favorite thing either.. This was the tiny cutoff wheels with the EZ lock connector. I like them, they cut well, but when they wear down they just throw debris and finally explode. (IMG:http://www.914world.com/bbs2/uploads_offsite/i5.walmartimages.com-172-1535050352.1.jpeg) |
| Andyrew |
Aug 26 2018, 01:10 PM
Cleaned up a bit more. Working on the connections to the 914 body harness/lights. Decided to try the new connector hardware. Works pretty good but it needs the special tool or else it's pretty difficult to install. I soldered them when I was done with crimping them.
Helping hands was nice (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
| Andyrew |
Sep 11 2018, 10:57 PM
Been busy!
![]() I made the mistake of cutting out two connectors that ran to the rear of the car for lighting. The thing is when I cut things out I also cut the wires back as far as possible. I do however leave enough room to connect to the wire in the future if need be and put some heat shrink on each wire. So after 3 nights of research testing and scouring for like wire colors and size to splice back in I got it back... In the end the job will be cleaner. ![]() I got as far as air dare go on the main harness and went after the engine harness. ![]() If you remember I wanted to extend the harness. Well I found a way of routing it that I don't need to. I'm going to put a couple extra inches Into the engine bay and maybe extend a wire or two but I think I'll be ok. If I need to extend it I'm extending it like 3 feet to wrap around the engine bay and be completely hidden. The blue bucket is full of removed wires, relays and connectors from the engine bay harness. Not pictured are 3 sensors that have resistors that Ishortened and moved out of the engine bay. A couple of pieces I got was a new temp sensor connector and sensor. I'm going to pray that this is the issue as I haven't found anything else wrong yet. I'll wire this in next. Next step is to cut the hole in the firewall out of plain sight (like I did last time) and confirm the wires are long enough. Then connect everying up and test it all and look for issues. I've been bench testing the lights and guage cluster but that's it so far. Once everything is all good I'll finalize some connections run some wires for a pop up headlight switch, and finally wrap everything. I have some great wrap as well as some new super awesome heat shrink. This stuff is up to 2" wide!! When it's fully shrink it's about 1/8" thick! ![]() Some connectors I pinned up and heat shrunk below. 3:1 shrink ratio is also awesome. ![]() ![]() ![]() |
| 76-914 |
Sep 12 2018, 09:05 AM
The temp sensor is the suspect, correct? Post a link to the 3:1 heat shrink. Is it marine grade? Stay after it. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 5th August 2026 - 04:30 PM |
