44 Pages V « < 33 34 35 36 > »
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
Mueller
post Aug 16 2018, 08:51 AM
Post #670
914 Freak!
QUOTE(Andyrew @ Aug 16 2018, 07:34 AM) *
Got some new tools and consumables. Not pictured is a new 60watt soldering iron with orange case (IMG:style_emoticons/default/smile.gif) , flux, solder, heat shrink terminal kit, and on the way is more heat shrink (3:1), and a new butane torch.
Last night I spent an hour stripping the wires of tape(thread remover works great if your slow to avoid crossed wires) and cutting a couple unused plugs out. Probably a pound of wire removed. I'll weigh it all when done. I've got to do this real slowly to not cut anything critical out.
More tools...nice!
Things I don't see in the picture....safety glasses, a carbon filter exhaust fan and a "third hand" (IMG:style_emoticons/default/smile.gif)
Andyrew
post Aug 16 2018, 08:56 AM
Post #671
Spooling.... Please wait
QUOTE(Mueller @ Aug 16 2018, 07:51 AM) *
More tools...nice!
Safety glasses are directly above the table.
That big ass fan isnt big enough for you? And nope, I dont have a "third hand" yet. Im thinking of putting a "T" track in the front of my table and putting a third hand in it. Havent gotten around to soldering yet, just thinning out the harness still (And probably for another couple weeks if I work on it every other night).
dan10101
post Aug 16 2018, 09:00 AM
Post #672
TORQUE-o-holic
Finnegan's garage is giving away a $2500 worth of tools for wiring etc.
https://www.youtube.com/watch?v=DNwjFWv3iNs
All you have to do is comment something that catches his eye or his heart.
What you have looks good. Good tools are the key...
post Aug 16 2018, 02:36 PM
Post #673
Something I found invaluable was the dual range heat gun from HF ($14.99) https://www.harborfreight.com/1500-watt-dua...1112-62340.html and the helping hands tool ($4.99) https://www.harborfreight.com/Helping-Hands-60501.html
The dual range heat gun is perfect for the Heat Shrink. Find the perfect temp setting for whichever style your using then set it and forget it. IIRC, 730F was perfect for melting the silicone in the Marine grade. The helping hands is that 3rd hand but doesn't let the wires move as we do by hand. Rather than twist the wires together I like to slide the exposed ends upon each other then push any stray wires back in before soldering. This way I don't end up with a knot or bulge after soldering. It's not important but looks a lot neater and I don't need the next larger size of heat shrink for it to slide over the hump. Does that make sense? I know that you know this but many guy's don't. A perfect resin core solder joint will shine when set. If the soldered object is allowed to cool too quickly
(eg by blowing on it) or moves before it is set then the joint will appear cloudy indicating an improper solder joint. Before sure that you have a Cold Beer each evening afterwards so you can relax. (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis
post Aug 16 2018, 06:44 PM
Post #674
Resident Electrician
QUOTE(Andyrew @ Aug 13 2018, 07:19 AM) *
Tried that, replaced the plug with no change. My coolant temp comes up like normal as well. Its all taken apart now ready for inspection/cleaning and continuity testing.
This is a video explaining the wiring. Note its a bit difficult to follow as it was about 12:30am and I was a bit tired.
My temp came up fine too. The water sensor is a dual element. One goes to the gauge and one to the ECU. It was the ECU wire that had an intermittent connection.
Check all the plugs for every system and try to pull out the wire from the metal terminal. Pull hard. Don't be afraid to yank on it. Like I said, failure at this type of connection point is a known point of failure and run problems. I've even seen some crimps where they crimp over the insulation. This works for a while and then wiggles out of contact.
Mike Bellis
post Aug 16 2018, 06:45 PM
Post #675
What does you VCDS say the problem is? When was the last time you did a throttle body calibration?
Andyrew
post Aug 16 2018, 07:01 PM
Post #676
QUOTE(Mike Bellis @ Aug 16 2018, 05:45 PM) *
I can no longer connect to the obd2. This happened about 3 months after the issue. Vcds showed bad crank position sensor, then it stopped showing an issue, then I could no longer connect to it. Another reason why I'm doing the wiring cleanup.
Andyrew
post Aug 16 2018, 07:04 PM
Post #677
QUOTE(Mike Bellis @ Aug 16 2018, 05:44 PM) *
I changed the sensor 3 times then changed the wiring twice. Another item I'll be checking while doing the wiring again. All the junkyard connectors we're junk. I haven't found a source for the connector new or else I would do that.
Andyrew
post Aug 16 2018, 11:36 PM
Post #678
Progress from tonight. More of the easy slow stuff. Removed about 10 connectors I don't need. Probably about 15 left to cut out throughout the harness, these were all in two simple clumps.
I am still leaving some wires to trim in case I find I make a mistake and need to solder one back. I'll power up the system and test it before I trim everything back and finish the looms.
Andyrew
post Aug 18 2018, 02:25 AM
Post #679
Cleared out some more wiring but as I was doing the light wiring I got worried that I was clearing out too much... So I removed the relay holder, the turn signal/wiper/headlight stalks and the ignition switch and my battery and set it all up on the bench. I was able to figure out the headlights but I didn't get the turn signals to work with a test light. So I'm going to finish up the wiring the best that I can tell for the lights and add some connectors at appropriate lengths and then I will put it in the car. I suspect that it needs more bulbs/resistance to work. The hazard switch works great and it's what holds the turn signal relay.
I spent a bit of time writing out all the wiring per the diagrams I have so I can confirm I did wire it up appropriately the first time. I have been having issues with one of the headlight fuses constantly going out so I suspect I have it on the wrong wire/ fuze/ something so that's one of my big things I'm working on solving with this wiring.
The loom is substantially thinner at this point, and I have a lot of wires I still can remove/trim.
Note I still have the engine harness to go through. I just decided to start with this as I'm going to be spending a considerable amount of time measuring and lengthening/shortening the wires for the engine harness.
Andyrew
post Aug 22 2018, 08:42 PM
Post #680
I did someore trimming a couple nights ago, no pics. I went over the lights and turn signal situation and I have a bit more to do but I think I have it figured out. I am ready to start trimming the engine harness and in doing so I'll be able to trim the chassis harness a bit more as well. After all the triming I'll size everything to proper lengths and move from there.
Monday night I was modifying some steel frames for work (I rarely do this kind of stuff in my position, but I needed it done faster than my shop was going to be able to do it) and I got a piece of metal in my eye. I didn't notice it till yesterday after work and thus made an emergency trip to my optometrist, who luckily is a family friend and I can typically pull strings when needed like this. Got it out and after a hard night last night I am feeling better. Still blurry but I'm dialated pretty good and he took a bit of material out as there was a little rust.
However it's healing well (follow-up appointment) so no worries there.
Back on topic I decided to replace my failing welding helmet, and I took the advice of you guys and got a nice set of helping hands.
I should have a little bit more progress this weekend. I should be testing the system sometime in the next month and then wrapping it for good.
dan10101
post Aug 22 2018, 09:58 PM
Post #681
TORQUE-o-holic
Hmm, DejaView all over again.
Or was it me last time...
#Dadmodeon
Wear your safety equipment!!!
#Dadmodeoff
Glad you got it taken care of.
Andyrew
post Aug 23 2018, 07:03 AM
Post #682
I was wearing my good goggles.. damn dremmels just kick out a ton of debris. I'm getting a full face mask to use over my goggles. When I am using the dremmel it typically shoots the Sparks directly in my face, and I have to be very close to see perfectly (IMG:style_emoticons/default/sad.gif)
post Aug 23 2018, 08:22 AM
Post #683
Careful with those eyes. Replacement parts rival Porsche parts in price. Your heading down the right path. Should be a runner soon. Stay after it. (IMG:style_emoticons/default/beerchug.gif)
worn
post Aug 23 2018, 12:47 PM
Post #684
QUOTE(Andyrew @ Aug 23 2018, 06:03 AM) *
Have used the dremmel a lot and find that wire brush wheels are extremely dangerous. To the point where I had a piece of stainless brush wire pierce through my nose. Not really that keen on jewelry and it could have been my eye.
Andyrew
post Aug 23 2018, 12:52 PM
Post #685
QUOTE(worn @ Aug 23 2018, 11:47 AM) *
Wire brush wheels are not my favorite thing either.. This was the tiny cutoff wheels with the EZ lock connector. I like them, they cut well, but when they wear down they just throw debris and finally explode.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i5.walmartimages.com-172-1535050352.1.jpeg)
Andyrew
post Aug 26 2018, 01:10 PM
Post #686
Cleaned up a bit more. Working on the connections to the 914 body harness/lights. Decided to try the new connector hardware. Works pretty good but it needs the special tool or else it's pretty difficult to install. I soldered them when I was done with crimping them.
Helping hands was nice (IMG:style_emoticons/default/smile.gif)
Andyrew
post Sep 11 2018, 10:57 PM
Post #687
Been busy!
I made the mistake of cutting out two connectors that ran to the rear of the car for lighting. The thing is when I cut things out I also cut the wires back as far as possible. I do however leave enough room to connect to the wire in the future if need be and put some heat shrink on each wire.
So after 3 nights of research testing and scouring for like wire colors and size to splice back in I got it back... In the end the job will be cleaner.
I got as far as air dare go on the main harness and went after the engine harness.
If you remember I wanted to extend the harness. Well I found a way of routing it that I don't need to. I'm going to put a couple extra inches Into the engine bay and maybe extend a wire or two but I think I'll be ok. If I need to extend it I'm extending it like 3 feet to wrap around the engine bay and be completely hidden.
The blue bucket is full of removed wires, relays and connectors from the engine bay harness. Not pictured are 3 sensors that have resistors that Ishortened and moved out of the engine bay.
A couple of pieces I got was a new temp sensor connector and sensor. I'm going to pray that this is the issue as I haven't found anything else wrong yet. I'll wire this in next.
Next step is to cut the hole in the firewall out of plain sight (like I did last time) and confirm the wires are long enough. Then connect everying up and test it all and look for issues. I've been bench testing the lights and guage cluster but that's it so far.
Once everything is all good I'll finalize some connections run some wires for a pop up headlight switch, and finally wrap everything. I have some great wrap as well as some new super awesome heat shrink. This stuff is up to 2" wide!! When it's fully shrink it's about 1/8" thick!
Some connectors I pinned up and heat shrunk below. 3:1 shrink ratio is also awesome.
post Sep 12 2018, 09:05 AM
Post #688
The temp sensor is the suspect, correct? Post a link to the 3:1 heat shrink. Is it marine grade? Stay after it. (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Sep 12 2018, 09:41 AM
Post #689
QUOTE(76-914 @ Sep 12 2018, 08:05 AM) *
Temp sensor is what Bellis thinks it is, I've replaced it a couple times but never had a good connector in the harness so hopefully this ends up being the issue. If not, more spares (IMG:style_emoticons/default/dry.gif)
My other thought is the crank position sensor, I havent gone through and checked the wiring on it yet but its on my short TO DO list prior to wrapping both harnesses.
Sorry, its 4:1 shrink tube (IMG:style_emoticons/default/biggrin.gif)
https://www.amazon.com/gp/product/B07FNC7VW...=UTF8&psc=1
This supplier has lots of sizes, I ordered 4 feet of each size I needed that should cover any size needed (4:1 is NICE) and shipping was only $6 total for a total order of $42.
So far REALLY happy with it, I just need to shrink it on LOW heat with my heat gun as it melted my wrap on one of my wire bundles. Also when its cooled its almost completely stiff. It should do an amazing job protecting my connector wiring. Lastly its adhesive lined so it wont move on the connector.
- Lo-Fi Version Time is now: 20th June 2025 - 10:05 PM
