| 76-914 |
May 6 2019, 10:29 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,830 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Are you using the new plastic back pad from 914rubber or using the OEM cardboard. If the plastic one, what were you quoted? This info will help me decide if I want to be an upholsterer or not. (IMG:style_emoticons/default/biggrin.gif)
| Andyrew |
May 6 2019, 11:22 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Are you using the new plastic back pad from 914rubber or using the OEM cardboard. If the plastic one, what were you quoted? This info will help me decide if I want to be an upholsterer or not. (IMG:style_emoticons/default/biggrin.gif) I havent bought/tried anything yet. I have a feeling Im going to make something out of fiberglass as I'll need to make some considerations. Not sure. I'll probably do that next year (IMG:style_emoticons/default/smile.gif) |
| Andyrew |
May 9 2019, 07:02 AM
Progress!
Drove it yesterday! If your at all interested in a 5 min video of the sky and 11minutea of me looking around and diagnosing stuff your welcome to watch (IMG:style_emoticons/default/smile.gif) https://www.youtube.com/watch?v=U2FqsUZ5pW4 In short. The good: The new trans shifts like a boxster, buttery and amazing. The steering system feels fantastic. The engine runs just like it always has. Chassis feels much stiffer with the steering system improved. Feedback is much better. Dash has a very usable layout. The bad: First gear was difficult, I didn't have enough throw in the shifter to engage it. A little 20second shifter adjustment and I think that's taken care of. AFR guage needs calibration Intercooler fan controller isn't working for some reason. The Ugly: I warmed it all the way up and tried restarting. No avail even with my modulating or full throttle work around. I let it cool down some and took some video of it struggling to start and what I was doing with the throttle to coax it to start. Myself, my dad and my tuner think it needs more fuel. My tuner says it has two fuel maps, one for enrichment and one for normal operation. He says we can add fuel to make it right. I'm going to get some starter fluid and see if adding starter fluid helps the hot starts. If it does we finally know what the problem is and can correct it. I have a Dyno day I'm working on scheduling before WCR so I can get a bit more torque and clean up the map just to make sure I have my basis covered. |
| Krieger |
May 9 2019, 08:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,829 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Congratulations! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
| tygaboy |
May 9 2019, 08:01 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,724 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Progress, indeed! Happy to hear you're getting it there!
| dan10101 |
May 9 2019, 08:38 AM
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
Awesome progress!
(IMG:style_emoticons/default/piratenanner.gif) Stacking um up and knocking them down! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif) |
| 76-914 |
May 9 2019, 09:46 AM
I hope that is the answer. (IMG:style_emoticons/default/beerchug.gif)
| 76-914 |
May 9 2019, 09:49 AM
duplicate
| Andyrew |
May 9 2019, 09:58 AM
Same (IMG:style_emoticons/default/dry.gif) |
| Chris H. |
May 9 2019, 01:39 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,070 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Yeah that is so WEIRD. Seems like it has to be fuel since you replaced almost all the senders/sensors. Normally I would say temp sensor but I think you checked it already. It would also likely be easier to start when warm vs. cold with a bad or miswired temp sensor. Sounds like you have the opposite problem. The starter fluid is a good idea. Nice work on the new steering setup. Love the dash. That's going to be really nice. |
| ValcoOscar |
May 9 2019, 02:00 PM
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,558 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California
| Andyrew |
May 9 2019, 10:23 PM
Starter fluid works.
More driving around video and me trying out the starter fluid. https://www.youtube.com/watch?v=vlPDrgQBAmQ |
| Chris914n6 |
May 10 2019, 12:28 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,510 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Are you losing fuel pressure when the car is off? Takes easily 2-3 seconds to build pressure with the pump on the other side of the car. Your cranks on film are too short.
BMW and likely a few others (like your Infiniti) actually trigger the fuel pump when the door is opened or other sign of pending use, like the remote is nearby, say in my pocket, as I replace an injector... (IMG:style_emoticons/default/dry.gif) |
| jd74914 |
May 10 2019, 05:02 AM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,864 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Yeah that is so WEIRD. Seems like it has to be fuel since you replaced almost all the senders/sensors. Normally I would say temp sensor but I think you checked it already. It would also likely be easier to start when warm vs. cold with a bad or miswired temp sensor. Sounds like you have the opposite problem. The starter fluid is a good idea. It's not an uncommon problem actually. You typically have a one time starting pulse adder which is a function of engines temperature and also a startup enrichment table with pulse modifier which is on a temperature vs. crank number table. If you taper off too fast with temperature you can have issues. Sometimes, people also have the thresholds for starting engine speed too low so they car starts thinking it's running when it's cranking really fast and doesn't get any extra fuel. Lots of little nuances can cause a lack of hot start fuel unfortunately. Hope you guys figure it out soon! |
| Andyrew |
May 10 2019, 06:43 AM
Are you losing fuel pressure when the car is off? Takes easily 2-3 seconds to build pressure with the pump on the other side of the car. Your cranks on film are too short. BMW and likely a few others (like your Infiniti) actually trigger the fuel pump when the door is opened or other sign of pending use, like the remote is nearby, say in my pocket, as I replace an injector... (IMG:style_emoticons/default/dry.gif) Pump is literally next to the engine, and it's an 044. I've tried letting it build pressure with no avail and letting it crank for a minute with no results. Audi kills ignition on cranking after 5 seconds. JD is correct my tuner said the same thing. It's going to take some time to figure out but we'll get it. Also quick note, I am running 1300CC injectors, so I have a strong feeling with them being so large its compounding this start issue. |
| 76-914 |
May 10 2019, 08:39 AM
Hot Damn! Way to go. Why didn't Mike encounter these problems. Is he running an aftermarket ECU?
| Chris914n6 |
May 10 2019, 01:23 PM
Are you sure you're getting a start signal to the ecu? Usually it triggers batch fire as the air isn't moving fast enough for sequential to work right.
Injectors timed to spray into OPEN valves? 1300cc is going to have some latency. |
| Andyrew |
May 11 2019, 01:18 AM
Are you sure you're getting a start signal to the ecu? Usually it triggers batch fire as the air isn't moving fast enough for sequential to work right. Injectors timed to spray into OPEN valves? 1300cc is going to have some latency. Interesting point. Very possible that its not getting start signal. Not really sure how I would test it, I'll bring it up to my tuner. Injectors should be timed right, but who knows... I'll have my tuner check the existing tune and figure it out and we'll go from there. Taco bell run for lunch. Ran pretty good. Transmission seems to be getting slightly worse. Not as slick as it was last night for some reason specifically getting into first. I'll try it again next week and see what I find. Some noises I didnt like, and the steering has a weird spot where something feels loose, I'll nut and bolt everything and check the bearings in the column. Also did a 1-2 pull. For some reason the gearing seems much shorter than I remember. 2nd gear should be the same but it was shorter than I remember. Im only on wastegate so it wasnt very quick, first gear probably didnt make more than 6lbs or it spun (which with the new LSD it shouldnt) and 2nd gear was decent, then it seemed to get a bit more boost for some reason and felt OK. My frame of reference is my 350hp daily sedan... I think theres room for improvement in the tune (IMG:style_emoticons/default/smile.gif) Cant wait till I get the boost in the 20's. Should feel like a rocket. My tuner says he's ran 25psi on 91 octane with no adders. Which would be deep in the 300whp range. So to recap the items Im going to be focusing on during the week this week are: 1. Solving the hot start issue with my tuner remotely 2. Calibrating the AFR guage 3. Fixing the intercooler fan controller power issue 4. Wiring in switches for the electric water pump and fuel pump 5. Program in the new boost controller settings 6. Start figuring out what Im going to work on at the build day and get materials accordingly. 7. Mount and wire in the USB charger and stereo 8. Find a better permanent home for the water pump controller |
| Andyrew |
May 11 2019, 01:34 AM
Messing around with the new boost controller programing. It's now closed loop capable (IMG:style_emoticons/default/smile.gif)
Im building an rpm x throttle position tune as I'm thinking this would be best for drivability. Attached thumbnail(s) |
| tygaboy |
May 11 2019, 07:59 AM
Hi Andrew - Regarding how the shifting is feeling: I don't recall if you have a 5 or 6-speed but if it's a 6, I have the Numeric shifter and cables. You're welcome to borrow them to see if any/all of those components are the root cause.
Or, if you're planning to bring the car to my place on the 18th, we could swap it in for a quick test. The Numeric site also has some nice vids on adjusting the cables. Not sure if this helps with non-Numeric parts but it may be worth a look. https://numericracing.com/guides/ See you soon! Chris |
Lo-Fi Version | Time is now: 20th December 2025 - 05:08 AM |
