44 Pages V « < 41 42 43 44 >
> Andyrews Progress Thread, 1/16/22 A Trip to The Red Barn - Lets fab a Firewall!
Cairo94507
post May 26 2019, 07:25 AM
Post #830
Michael
Hi Andrew,
I look forward to seeing your car at WCR. (IMG:style_emoticons/default/beerchug.gif) Michael
tygaboy
post May 26 2019, 07:29 AM
Post #831
Full custom fabrication! (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/aktion035.gif)
Andyrew
post May 27 2019, 01:20 AM
Post #832
Spooling.... Please wait
Alina hadn't had her nap and it was almost 3pm. So we decided to go drive. Her naps are about 2 hours... So where do we drive? Petaluma to grab the piece I left at Chris's. Thanks Chris for letting me swing by on such short notice!! (IMG:style_emoticons/default/smilie_pokal.gif)
Alina went to sleep almost immediately in the car...
Had a nice dinner at a local Petaluma restaurant that had a great playground and had some nice BBQ.
Got home and couldn't resist myself I wanted to see where we were with fitment of the panel.
I knew this one would take some more work... We'll like the other one I needed to bend it and since I don't have nice press brakes I make do (IMG:style_emoticons/default/smile.gif)
Couple go around to get this one right. But happy with it. I need to work on mounting it and the other side. But I pulled them together loosly and checked out the top.
Some measurements and I'll need to make a new piece for the top I think. I'll cut out the shifter hole and see what I think. I also need to figure out how to mount this one. Outside the box thinking might be necessary.
914 Ranch
post May 27 2019, 02:27 AM
Post #833
Team Sharp where the 914 grow wings
Andrew, you and I have been thinking outside the box so long that I forgot where I put that fucking box. Now I just toss the piescs at the car and some how they seem to guide me to the solution. I believe that is form fallowing function.
Man I want a bead roller.
dan10101
post May 27 2019, 08:49 AM
Post #834
TORQUE-o-holic
A man on a mission!
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
Andyrew
post May 28 2019, 01:48 PM
Post #835
Received my tow bar from @914werks. Nice looking product! Very heavy duty.
Not designed for a 916 bumper so I'll just trim my bumper to fit as its probably going to be changed at some point.
Mounting of the actual pieces. Some shims needed to be made to fit it right. But 4 bolts holding each piece firm.
Construction paper to the rescue for the new shifter plate.
And new shifter plate in place, not mounted.
I've determined im going to build a removable upper cage to hold the plate in place, Should be pretty simple to build, probably a couple hours.
tygaboy
post May 28 2019, 03:39 PM
Post #836
That there is some real progress! WCR, here it comes! (IMG:style_emoticons/default/aktion035.gif)
Andyrew
post Jun 1 2019, 07:34 PM
Post #837
The 914 and 951 have a different stablemate for the week (IMG:style_emoticons/default/smile.gif)
Stay tuned for fun progress. (IMG:style_emoticons/default/w00t.gif)
Andyrew
post Jun 3 2019, 12:01 AM
Post #838
Dad and I redid the clutch reservoir and used a spare of his mounted next to the brake. This gave us an easier bleed and we could pressurize it with his system. Not that it helped. It was still a very difficult bleed.
We're going to try bleeding it again. Still difficult to get into first. But it does shift.
Changed front shocks to Koni Yellows
Changed the valve cover gasket. Hopefully this fixes the leak.
Spent a lot of time on the center console. You can see the shifter solution I made. Really happy with it.
And the big question is black or brown
I'm leaning towards brown. But not sure. I'll powder coat the screws whatever color I need them. Shifter trim will stay black for contrast and the foam arm rest needs to be done still.
Also my tuner came by and set me up with the ability to change my tune myself. (IMG:style_emoticons/default/piratenanner.gif)
My wife and I went for a quick drive. She liked it, but the clutch still needs work. LSD is working well though, put down good power in first!
tygaboy
post Jun 3 2019, 06:50 AM
Post #839
Andrew - Looking good! Also good to hear you're making progress on the drive-ability items.
On the console, it's totally a personal taste thing but the brown will likely make the beading detail more noticeable, which I happen to like!
Hi to your dad for me.
Cairo94507
post Jun 3 2019, 07:26 AM
Post #840
Michael
I like the idea of the contrast with the brown. If you cover the console in black it might get kind of lost in all the black. It's nice piece and the brown will look nice. Love the seats BTW. (IMG:style_emoticons/default/beerchug.gif)
Andyrew
post Jun 5 2019, 01:32 AM
Post #841
Been a busy couple days.
Yesterday my dad worked and prepped the fabric for the dash, removed the dash, and put carpet on the car. Today we put the vinyl on the dash with the basketweve pattern. There is a seam in the middle but I'll figure something for that.
We also worked and tested the tow system. Lots of work to make it better needed. Not the happiest with how clunky flat towing is and we're working on streamlining it.
We also added a trans cooler to the Honda so it shouldn't have any issues pulling up the hill.
Pics.
10 internet points if you can figure out what the metal pieces are for.
tygaboy
post Jun 5 2019, 07:17 AM
Post #842
Dash pad replication? (IMG:style_emoticons/default/idea.gif)
Andyrew
post Jun 5 2019, 01:47 PM
Post #843
Lower dash pad (IMG:style_emoticons/default/smile.gif)
Mike Bellis
post Jun 5 2019, 10:13 PM
Post #844
Resident Electrician
Wow! Lots of fab in a short amount of time. Great job.
Andyrew
post Jun 29 2019, 01:01 AM
Post #845
WCR 2019 Came and went.
Nothing major happened except dads car almost falling off the trailer. Honda pulled the 914 incredibly well. I got 29mpg going to the event and got 24mpg back with a bit of city driving, both times up and over the grapevine. It might be slightly elevated, but I confirmed the 24mpg number on the way back when I filled up, didnt have a chance to confirm the 29mpg.
I had a great time driving around a couple of guys, some decent compliments on the car, especially the sound. It was really great getting together with everyone. So many familiar faces I was surprised I knew half or better!
The 914's hot start issue is better, It takes on average 3 times to start the car, sometimes when its warm it'll start right up, sometimes when cold it'll start right up. I think we can tune it out now. Clutch is MEH at best when warm. Odd bit is when the car is very cold or a cold morning it shifts really well. I have some ideas on it. Probably will redo the master cylinder with a universal master cyl maybe oversized to give me some extra throw and I'll adjust a clutch stop accordingly. Another possibility is its simply air in the lines still. I'll try bleeding it some more and see what we get.
Dad and I had a great time driving together and spending some good time together, It was a fantastic early fathers day!
(IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-4-11722-1560517990.1.jpeg)
Some pics from the event. Some great photographers there!
(IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-4-11722-1559885290.0.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-4-11722-1560126490.0.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-4-11722-1560374890.0.jpeg)
Interestingly, Magnus Walker took a couple pics of a few cars, including mine and my dads and posted it on instagram. Very nice guy, took time to say hi to anyone that wanted to.
https://www.instagram.com/p/BybZWVZJN0f/
(IMG:http://www.914world.com/bbs2/uploads_offsite/914world.com-4-11722-1560374291.1.jpeg)
Oh I also won the DIY award, which is pretty fitting given my DIY attitude towards the car. (IMG:style_emoticons/default/smile.gif)
Some shaky video. Note, Im on wastegate here just so I dont get into trouble, but we all took it really easy. Small pull at 19:55 and some decent views around 15mins.
https://www.youtube.com/watch?v=Rlm-4iVpzXI
Going to a local autox tomorrow, Swapped over to the 944 turbo track tires (Toyo Proxy RA1's) so I'll have a decent amount of grip. I normally bag the tires and swap them out at the track but Im going solo tomorrow so I just mounted them tonight. Im concerned about gearing, I dont think I'll be able stay in 2nd the whole track, the smaller tires and the fact my tuner turned my redline down at our last dyno event means I could have to go between 2nd and third or bounce off the rev limiter... Theres only a couple straights so we'll see. If I have to I'll just throw it in 3rd and stay out of the powerband most of the run.
ValcoOscar
post Jun 29 2019, 06:53 AM
Post #846
Garage Life
Andrew-
Your two cars at WCR side by side were quite the head turners (IMG:style_emoticons/default/piratenanner.gif)
Great that you can share these 914 events with your dad but I wouldn't want to race him. (IMG:style_emoticons/default/beerchug.gif)
Until next time...
Oscar
Cairo94507
post Jun 29 2019, 07:20 AM
Post #847
Michael
I love both cars. How cool that you and your dad share this passion. (IMG:style_emoticons/default/beerchug.gif)
dan10101
post Jun 29 2019, 10:23 AM
Post #848
TORQUE-o-holic
It was definitely a life event for us. Andrew getting his car road worthy after many years. Me bringing a car back to life after devastation. Many many thanks to our families for giving us the space and time needed to make this happen.
We will continue to develop our cars until they are ‘done’ and then do it some more…
Thanks to whoever took the picture of Andrew and I at the table. That doesn't happen a lot.
Andrew in his element…
I like my angle better… (IMG:style_emoticons/default/smile.gif)
The best shot of the week.
Maltese Falcon
post Jun 29 2019, 11:24 AM
Post #849
Love the center console treatment & shifter knob Andrew, a classy touch of the CGT right out of the Leipzig Factory (IMG:style_emoticons/default/aktion035.gif)
- Lo-Fi Version Time is now: 22nd June 2025 - 03:48 PM
