SPEAKERS, WHERE TO MOUNT |
914.SBC |
Feb 13 2011, 07:12 PM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
There are not too many places to mount speakers other than the door panels. But If you guys have mounted them anyhwere else, I would be curious to know.
Thanks |
JmuRiz |
Feb 13 2011, 07:23 PM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Morph's 6.5" speaker pods are the best...no hacking up the door panels. I did make a console with some up-firing 3.5" speakers, works well at focusing sound right at you w/ the top off at-speed.
underthetire |
Feb 13 2011, 07:32 PM
Yep, put some 41/2 speakers in the stock location with an mdf adapter board. Can't even tell, then a sub in the center consul or one of morphs stealth sub. Frys had Boston acoustics plates on sale a while back that fit right in the stock location.
914.SBC |
Feb 13 2011, 07:40 PM
rick 918-S |
Feb 13 2011, 08:16 PM
Hey nice rack! -Celette Group: Members Posts: 20,458 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Morphs speaker housings in the stock location. They will hold a larger speaker and they are aimed at you. Don't hack the door panels.
914.SBC |
Feb 13 2011, 08:45 PM
Tom_T |
Feb 13 2011, 09:55 PM
In the corners of the driver & passenger footwells, as in the pix of Johnnie L's "Orangina" in the pix below - ^ these are the stock OE housings, Morph's look similar & fit there (he's canned the door speakers/panels - or will do soon BTW - bad idea door speakers). See him in the member vendors' section, or 914a&p.com IIRC (914 Appearance & Performance - if all else fails, but mention 914world for discount). I've also seen this which may fit behind the passenger or both seats sitting vertical on the side - depending on how tall you & passenger are.. They're actually located in Costa Mesa. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=230584186094 ... and this for stealth 3.5 mm modern audio into a classic radio: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...em=230584560671 But what the heck - you can't hear the radio if you're cranking that T4 motor through the gears anyway! (IMG:style_emoticons/default/biggrin.gif) |
mikea100 |
Feb 13 2011, 09:56 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
Check out this thread.
http://www.914world.com/bbs2/index.php?sho...amp;hl=speakers There are not too many places to mount speakers other than the door panels. But If you guys have mounted them anyhwere else, I would be curious to know. Thanks |
FlatIV |
Feb 13 2011, 10:07 PM
AP Group: Members Posts: 55 Joined: 4-May 06 From: Circleville, Ohio Member No.: 5,978 Region Association: None |
bfrymire |
Feb 13 2011, 10:35 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
I have those speakers from AP and they are well made. I got mine with the speakers. Now, I do have a stupid question... Most modern stereo's have front and rear speakers. So, those would work fine as the fronts. What about the rears? The ones mounted in the doors are usually the rears. So, AP's speakers handle the front.... I like the post above with the slimline speakers, but there is precious little space to mount speakers. -- brett |
rktmn247 |
Feb 13 2011, 10:45 PM
Irish Green with GT envy! Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None |
I have this ready to install when I get mine back on the road. Only plan on running 2 ch and a morph foot well sub. Tested it all in the house and hope it sounds as good in the car. (IMG:style_emoticons/default/aktion035.gif)
http://www.clarion.com/us/en/products/2008...2385079386.html |
ConeDodger |
Feb 13 2011, 10:50 PM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have what I would describe as a very good sounding system in my car. I have the Morph subbox with JL Audio 8" sub powered by an amp. I have a component Polk set with the midrange speakers in the Morph speaker pods mounted in the stock location. I mounted the tweeters on top of the vinyl forward of the dash. The amp and crossovers are inside my center console box behind the gauges...
Very rich full sound... This picture is before the dash and window went back in. Attached image(s) |
gothspeed |
Feb 13 2011, 10:59 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
That place is awesome!!! They will be getting some of my money soon!! |
rohar |
Feb 13 2011, 11:02 PM
Senior Member Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
You guys have it all wrong. You mount the speakers in the living room. When you're in your teener, you're supposed to be entertained by the engine!
rick 918-S |
Feb 13 2011, 11:40 PM
You guys have it all wrong. You mount the speakers in the living room. When you're in your teener, you're supposed to be entertained by the engine! (IMG:style_emoticons/default/agree.gif) but if you have to do speakers the door panels are only inches from the stock location. You would be wiser to make a cabinet behind the seats on the space at the floor. Even with the seats moved all the way back there is a nice space there. Stock location with Morphs setup, sub in the console, rears behind the seats. |
914.SBC |
Feb 14 2011, 08:15 AM
You guys have it all wrong. You mount the speakers in the living room. When you're in your teener, you're supposed to be entertained by the engine! (IMG:style_emoticons/default/agree.gif) but if you have to do speakers the door panels are only inches from the stock location. You would be wiser to make a cabinet behind the seats on the space at the floor. Even with the seats moved all the way back there is a nice space there. Stock location with Morphs setup, sub in the console, rears behind the seats. Thank you boyz... GOTTHESPEED, Appreicte the link. Just made the purchase. |
gothspeed |
Feb 14 2011, 09:05 AM
McMark |
Feb 14 2011, 11:39 AM
My 'behind the seats' thread from 2004 ((IMG:style_emoticons/default/yikes.gif)) is here.
(IMG:http://www.914world.com/members/markd/misc/speaks/1.jpg) |
Rod |
Feb 14 2011, 02:35 PM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Or just do it properly in the doors!!!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1284911350.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i62.photobucket.com-8526-1284911351.3.jpg) |
gothspeed |
Feb 14 2011, 03:01 PM
Lo-Fi Version | Time is now: 15th May 2024 - 09:28 PM |
