Over the counter degreaser suggestions? |
Scott S |
Apr 14 2011, 02:09 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Tonight I am going at my transmission (it is sitting on a furniture dolly). My only tools are garden hose, some scrapers and some wire brushes. The bottom is very clean, it is the top that is a mess. I want to just use the low pressure garden hose to avoid any internal contamination. Was curious what peoples opinions are on an over the counter degreaser, as I only have access to an Autozone or an Oreily's on the way down to the shop tonight - nothing fancy.
Thanks! Scott S |
yeahmag |
Apr 14 2011, 02:17 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Oil Eater or Simple Green. Then add some Ez-Off oven cleaner to get the baked on stuff. In theory you need to coat the trans with paint or something to keep it from oxidizing after it is clean.
-Aaron |
Jeffs9146 |
Apr 14 2011, 02:19 PM
Awesome at the $ store is totaly Awesome!!
rick 918-S |
Apr 14 2011, 02:20 PM
Hey nice rack! -Celette Group: Members Posts: 20,463 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Scott, I use a spray gun with mineral spirits in it. Use a parts cleaning brush and poke at it while you spray. Crap fly's everyplace but it cleans up nice and fast. Oh and it will ruin your grass. (IMG:style_emoticons/default/evilgrin.gif) AND Your wife WILL give you the look (IMG:style_emoticons/default/dry.gif)
pcar916 |
Apr 14 2011, 02:29 PM
Simple Green is an outstanding water-based cleaner and won't mess with the surface much but mineral spirits is a good solvent to use as well. But the latter leaves the surface bare unprotected. This is a time-consuming thing to do while the transaxle is still together.
Places to avoid spraying water into. In other words, Spray with the SG bottle and wipe/brush/scrape - Vent hole - the input shaft - output flange seals - shift seals (tail or side shifter) - speedo-drive hole This all works better when the trans is warm. There are a bunch of threads here on cleaning and coating magnesium. Good luck |
Apr 14 2011, 02:34 PM
Custom Member Group: Members Posts: 24,576 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
This is the strongest stuff I found that is water based.
http://www.superclean.com/products a word of caution...wear goggles and crappy clothes. The spray hose will shoot water back at you no matter where you stand... Rich |
TheCabinetmaker |
Apr 14 2011, 02:41 PM
I like purple power too.
benalishhero |
Apr 14 2011, 02:48 PM
Member Group: Members Posts: 313 Joined: 28-November 07 From: Portland, Maine Member No.: 8,384 Region Association: North East States |
Yep purple power or pink stuff.......
Cap'n Krusty |
Apr 14 2011, 02:54 PM
If you use any of that purple cleaner, and possibly other strong products, BE SURE you have more-than-adequate ventilation. I'm thinkin' like a box fan set on medium or high blowing all over you and the work while you're doing it. I didn't, and I almost had to visit the ER. It's BAD stuff! BTW, I was working outdoors!
The Cap'n |
Scott S |
Apr 14 2011, 03:47 PM
Thanks all! (IMG:style_emoticons/default/beerchug.gif)
Oh, and Rick, I could crap gold bars and diamonds all day long, every day, and she would still be giving me "that look" (IMG:style_emoticons/default/dry.gif) Ha! |
Ferg |
Apr 14 2011, 03:52 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I like the Oil Eater stuff they sell at costco, that with my steamer would make quick work, you wanna borrow it?
Ferg |
Scott S |
Apr 14 2011, 03:55 PM
Thanks a million Ferg. I will see how it all goes tonight. If it goes bad, I will drop you a line for sure.
Thanks again! |
MoveQik |
Apr 14 2011, 04:03 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
TheCabinetmaker |
Apr 14 2011, 04:10 PM
If you use any of that purple cleaner, and possibly other strong products, BE SURE you have more-than-adequate ventilation. I'm thinkin' like a box fan set on medium or high blowing all over you and the work while you're doing it. I didn't, and I almost had to visit the ER. It's BAD stuff! BTW, I was working outdoors! The Cap'n Strange, Been using it for years. I use it full strength and never had that problem. Maybe your just alergic to it? However, it doesn't like rubber. |
Ferg |
Apr 14 2011, 04:26 PM
I like the Oil Eater stuff they sell at costco, that with my steamer would make quick work, you wanna borrow it? Ferg What kind of steamer do you have? I forgot the brand, will have to check tonight. Looks like this... Attached image(s) |
Gint |
Apr 14 2011, 05:07 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I like the Oil Eater stuff they sell at costco, that with my steamer would make quick work, you wanna borrow it? (IMG:style_emoticons/default/agree.gif) +1 on Costco, Oil EaterFerg ...and, Ferg, I want to borrow your steamer. |
brant |
Apr 14 2011, 05:54 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
ferg,
I don't have a costco membership. but I want a bottle of that oil-eater some time can I give you some cash when your shopping anyways to pick me up one. |
MartyYeoman |
Apr 14 2011, 05:56 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Gint |
Apr 14 2011, 06:44 PM
brant |
Apr 14 2011, 07:22 PM
ferg, I'll get you one Brant. It's on my way home.I don't have a costco membership. but I want a bottle of that oil-eater some time can I give you some cash when your shopping anyways to pick me up one. don't make a special trip though tell me what I owe you and I'll get you the moola$ |
Lo-Fi Version | Time is now: 20th May 2024 - 07:28 PM |
