nine14cats |
Bill Pickering -- 914-6 GT aka....Leeloo ![]() ![]() ![]() ![]() Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None ![]() |
Hi Gang,
I'm currently running Bilstein's all around on my track car. No special valving. Right out of the box. If we were to assume the current set up at the bottom and the JWE Fox shocks at the top, what are my options in between? My current car setup: Front = --------- 23mm solid t-bars 27mm Smart racing AR bar 911T struts, calipers, brakes turbo tie rods Bilstein shocks Rear = -------- 350lbs to 450lbs springs (depending upon track or application) adjustable perches Bilstein shocks 944 calipers and brakes I will be going to bigger brakes all around, so I won't have the 911T struts much longer. What are my shock options and approx. costs? i.e. low end $500, Fox shocks $4400.... We run this car at Thunderhilll, Laguna Seca, Sears, Buttonwillow. Thanks, Bill P. |
Lo-Fi Version | Time is now: 14th July 2025 - 08:58 PM |
