looking for 914-6 CV joint |
914Gelb |
Jul 8 2011, 02:59 AM
Member Group: Members Posts: 90 Joined: 7-July 11 From: Vienna Member No.: 13,288 Region Association: Austria |
Hello 914 friends,
I've bought a 914-6 two years ago. Since I have my new six in my garage I'm working on my restoration project. During the tear down of axles (original six with 25 splines) I noticed one cv joint is worn. Two are brand new one used but without any grooves and one bad. Now I have the possibility to change to 4 cylinder axles ore I modify the 6 axles with cv's coming from 911. I also tried to get one from different companies with any outcome. Maybe there is one 914-6 colleague which has already done the step to an 944/911 axle conversion and has one/more original used cv's on stock and like to sell them. |
Jul 25 2011, 08:30 PM
Hello 914 friends, I've bought a 914-6 two years ago. Since I have my new six in my garage I'm working on my restoration project. During the tear down of axles (original six with 25 splines) I noticed one cv joint is worn. Two are brand new one used but without any grooves and one bad. Now I have the possibility to change to 4 cylinder axles ore I modify the 6 axles with cv's coming from 911. I also tried to get one from different companies with any outcome. Maybe there is one 914-6 colleague which has already done the step to an 944/911 axle conversion and has one/more original used cv's on stock and like to sell them. I could be wrong, but i don't think there are any 911 CV's that are a direct bolt in for the 914-6 CVs ... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/welcome.png) |
914Gelb |
Jul 25 2011, 11:32 PM
You are right, conversion to 911 CV's are more than just the CV's. I read already a postings/descriptions. Thanks.
Jul 25 2011, 11:42 PM
You are right, conversion to 911 CV's are more than just the CV's. I read already a postings/descriptions. Thanks. You could always save your original 914-6 axles and CVs and replace them with modified /4 axles using 944 CVs. That way, you get bigger and stronger CVs and the 944 units are still available. I did this on my car and it has been working great so far. http://www.914world.com/bbs2/index.php?showtopic=80641 (IMG:style_emoticons/default/bye1.gif) |
mskala |
Jul 26 2011, 10:41 AM
Or you can use stock 914-4 axles with -4 CV's, or beetle CV's that have the
2 holes drilled larger for the pins (PMB Performance). |
Lo-Fi Version | Time is now: 16th May 2024 - 03:44 PM |
