| Razorbobsr |
Sep 14 2011, 06:01 AM
Member ![]() ![]() Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
Not looking to hijack the thread.. But I remember an old Hot Rod Magazine that had a big article on the 215 V8. They had a graph that showed what bore, stroke and heads to use to bring the 215 up to a 350. I'm pretty sure they even used aluminum heads.. I have nothing against a SBC.. But I'd be curious about the weight difference of an Aluminum 350.. I have to try to find that magazine.. The alum 215 weight is about 50lbs less than an iron Triumph Spitfire 4 banger. In MI, theres a guy that did this to a spit!!!!! Sunbeam Tigers never had a chance, no hood scoops, no signs that it was other than stock.......... till he powered up. Bob |
| jimkelly |
Sep 14 2011, 07:36 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
what - no new pics : (
per these charts - the sbc is almost twice the weight of a buick 215 - 575 vs 318 - and the porsche 914-4 is 265 lbs - so a 300 lb increase - that's it - no more passengers : ) except for carmen electra : ) so a sbc doubles the engine weight over a stock 914-4 but adds @ 200 more hp - and increase the overall 914 weight by 10% or so - seems a reasonable compromise. http://www.gomog.com/allmorgan/engineweights.html http://www.carnut.com/specs/engdim.html http://www.ultimatecarpage.com/forum/showthread.php?t=39353 jim : ) |
| sean_v8_914 |
Sep 14 2011, 09:09 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
the nice thing about Porsche color Tangerene is that it can be swapped for Chevy hugger orange and its priced like a chevy color
if teh heads were not rebuilt I strongly recommend changing the valve guide seals now while its out and easy to do. they are VERY cheap and head removal it not required |
| Razorbobsr |
Sep 14 2011, 09:15 AM
what - no new pics : ( Got nude!!] per these charts - the sbc is almost twice the weight of a buick 215 - 575 vs 318 - and the porsche 914-4 is 265 lbs - so a 300 lb increase - that's it - no more passengers : ) except for carmen electra : ) so a sbc doubles the engine weight over a stock 914-4 but adds @ 200 more hp - and increase the overall 914 weight by 10% or so - seems a reasonable compromise. http://www.gomog.com/allmorgan/engineweights.html http://www.carnut.com/specs/engdim.html http://www.ultimatecarpage.com/forum/showthread.php?t=39353 jim : ) |
| Andyrew |
Sep 14 2011, 09:34 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Jim, 575 would be with stock intake, all accessories and stock exhaust manifolds.
Your aluminum intake removes probably 40lbs and your headers probably 10lbs. If you had aluminum heads it would be another 50+! |
| jimkelly |
Sep 14 2011, 09:37 AM
guess i could live with signal orange ???
| mepstein |
Sep 14 2011, 09:55 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
guess i could live with signal orange ??? Tell Scott to start spraying so we can see it by the party. (IMG:style_emoticons/default/biggrin.gif) |
| jimkelly |
Sep 14 2011, 10:08 AM
paint will be part of a to-be-scheduled phase 2, along with ...
body work smoothed roof paint all weather rubber fiberglass bumpers polished 4 lug fuchs vitaloni baby tornado side mirrors late model doors engman 3 piece inner long reinforcement kit cabin heater - $199 - http://www.jegs.com/i/Flex-a-lite/400/640/10002/-1 |
| TargaToy |
Sep 14 2011, 04:03 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- ![]() ![]() ![]() Group: Members Posts: 714 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region
Jim, I forget and I'm too lazy to look back. Are you adding any stiffening components to the tub while you're doing phase 1?
| jimkelly |
Sep 14 2011, 04:07 PM
i was thinking about having scott weld in an engman inner long 3 piece kit but this was pushed onto phase 2. thanks for reminding me - i will add it to my phase 2 list above which is getting longer : )
| TargaToy |
Sep 14 2011, 04:19 PM
I've got 1/3 of the Engman welded into mine but....my phases are kind of running together (and taking really long, I might add).
This is great for you getting so much knocked out in one shot. Can't wait to read you're back on the road! |
| matthepcat |
Sep 14 2011, 04:43 PM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Jim, 575 would be with stock intake, all accessories and stock exhaust manifolds. Your aluminum intake removes probably 40lbs and your headers probably 10lbs. If you had aluminum heads it would be another 50+! Aluminum heads....50 lbs savings...hmmm. Wonder if you could do a head swap without removing the engine.. . . |
| Andyrew |
Sep 14 2011, 05:46 PM
You could lower the engine down at the front and do it, but then your dead lifting 60lbs of cylinder head... each head..
Instead spending the 2 hours to remove the engine/trani would be the way to go.. |
| matthepcat |
Sep 14 2011, 06:15 PM
I hate when the logical answer is not instant gratification. (IMG:style_emoticons/default/smile.gif)
| jimkelly |
Sep 15 2011, 07:25 AM
gear stack pic
my plan is to ... delete 1st gear - block it off. 2nd = stock F 3rd = flipped V ( equal to using an R ) 4th = ZD ( move ZD from 5th to 4th position ) 5th = H flipped ( as overdrive ) Attached image(s)
| BajaXJ92 |
Sep 15 2011, 07:30 AM
Extended Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,146 Joined: 20-April 06 From: Prescott, AZ Member No.: 5,895 Region Association: MidAtlantic Region |
Jim,
What kind of RPM do you expect to see @ 60-70mph cruising in 5th with that flipped H? Of course that also depends on tire size, which you're relatively close to stock IIRC? |
| jimkelly |
Sep 15 2011, 07:57 AM
according to this chart - using 205x50x15 tires - and HA gets
62 mph at 2500 rpm - vs - 55 mph for stock ZD and 74 mph at 3000 rpm - vs - 66 mph for stock ZD my tires are 195x60x15 - slightly taller - so speeds will be slightly higher if i was using a flipped HA and higher again due to i will be using an H jim Attached image(s)
| computers4kids |
Sep 15 2011, 08:08 AM
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
gear stack pic my plan is to ... delete 1st gear - block it off. 2nd = stock F 3rd = flipped V ( equal to using an R ) 4th = ZD ( move ZD from 5th to 4th position ) 5th = H flipped ( as overdrive ) Jim, I just run an H and the gears feel just right, with 16" rims with low profile tires. Will you have a higher ratio for 3rd and 4th than stock? It seems like your going have about the same hp and torque and as I do. Mark PS I was going to do something similar with the gears but evil talked me out of it. |
| jimkelly |
Sep 15 2011, 08:23 AM
with stock gears - i feel that 2nd 3rd 4th just wind out too fast - so the plan was to replace 3rd and 4th with one gear ratio centered between 2nd and 5th - and then add H as more of an overdrive for highway use.
since this set up does not require buying any extra gears - i figured it is worth a try in my 225hp +- car. |
| Andyrew |
Sep 15 2011, 07:34 PM
Throw some 285 35 18's on there (aka 25.9" tall), that'll help wind it upslower (IMG:style_emoticons/default/wink.gif)
I just did a couple of runs today and it really felt good. 3d gear was very nice and I had some good good power from 40-85mph. And also why get rid of first? I use it all the time when for some reason im having a hard time getting it into 2nd.. |
Lo-Fi Version | Time is now: 26th September 2026 - 05:23 AM |
