Lexan quarter window |
LS6/914 |
Jul 24 2004, 05:29 PM
Never leaves the shop member Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest |
I need a source for 914 lexan quarter windows in the doors. It will be a interior vent project for a 914/8 track car. All the HVAC ducting at the dash has been sealed (P.O.) At the track its blistering in the interior. Not that Iam complaining. There was a Ferrari 250GTO running also however the owner and his tech would not say who built thier lexan side windows (IMG:style_emoticons/default/laugh.gif) Thanks, Lar
Kerrys914 |
Jul 24 2004, 05:45 PM
I have some extra sheets of LEXAN. I guess I could cut you some windows from a template.
I have never tried to make windows before so any tips would be helpful. Cheers Kerry |
Brett W |
Jul 24 2004, 08:37 PM
You can drape form them over the original if you want. Cut the pattern of what you need and then lay it over the original and use a heat gun to form it.
TimT |
Jul 24 2004, 08:56 PM
Make your own windows, there is no need for heating and shaping the quarter window shapes. take your old window out, use it as pattern, then cut the lexan. The lexan will be flexible enough to follow the slight curve of the window
Heres one I made for my 911, 1/8 lexan, with a naca duct Attached image(s) |
Brad Roberts |
Jul 24 2004, 08:59 PM
OK.. call me crazy.
Do you want to replace the vent window or the main roll up glass ?? B |
campbellcj |
Jul 24 2004, 09:05 PM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
For a track car, do you really need windows?
I removed my door glass recently, as the rules allow it and it is usually too effin' hot around here anyway. All the inner door stuff & glass saves a ton of weight! (IMG:style_emoticons/default/smilie_pokal.gif) |
jgiroux67 |
Jul 24 2004, 09:34 PM
Guitar Shredder Group: Members Posts: 593 Joined: 4-June 04 From: Turlock, CA Member No.: 2,157 |
QUOTE(TimT @ Jul 24 2004, 06:56 PM) Heres one I made for my 911, 1/8 lexan, with a naca duct Wher do you get a naca duct and how much is it? |
machina |
Jul 25 2004, 07:45 AM
cut all my windows from lexan except the windshield.
vent is from wicks. dr Attached image(s) |
TimT |
Jul 25 2004, 10:52 AM
I like tose little aircraft vent!! does Wicks have an online presence? edit just found them (IMG:style_emoticons/default/biggrin.gif)
I bough my naca ducts from Butler, but you can also get them from Pegasus |
LS6/914 |
Jul 25 2004, 02:50 PM
dr. & gang thank you for the input. The quarte window with the round vent should work well. Yes it gets incredibly hot in the cabin. Last weekend at Pacific Raceway PCA required the top on even with a full cage & harness. The v8 ran all day at 190, its the driver that overheated (IMG:style_emoticons/default/sawzall-smiley.gif) prompting more airflow. Lar
Scott Carlberg |
Jul 26 2004, 12:36 AM
Porsche MOTORSPORTS Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
Lo-Fi Version | Time is now: 13th May 2024 - 11:40 AM |
