Installing rear window |
Howie's 914 |
Oct 26 2011, 01:40 PM
Member Group: Members Posts: 76 Joined: 29-June 04 From: Greensboro, NC Member No.: 2,273 |
I need some help. After about 6 years I am finally getting to installing the rear window. Only thing is I didn't write down or take and pictures of it. Any help would be great.
Thanks Howie |
mark21742 |
Oct 26 2011, 01:43 PM
Member Group: Members Posts: 162 Joined: 31-August 11 From: pa Member No.: 13,502 Region Association: North East States |
$24 for a tube of it, but I'll recomend using urethane instead of vital tape
eric9144 |
Oct 26 2011, 01:44 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
There's a thread on the rear window install by Eric Shea...give me a sec and I'll dig up a link to it.
eric9144 |
Oct 26 2011, 01:52 PM
Chris Pincetich |
Oct 26 2011, 01:54 PM
I just did this w guidance from McMark while my 914 was in his shop. It was pretty easy with most all of the interior, including seatbelts, removed. Starting at the top middle, press on the 1/4" butyl tape onto clean metal all around the frame, then put your clean window back on and press to seal from the inside. I loved having it off so I could clean off the rest of the 20 years of cigarette smoking residue from the previous owner. Now, it does not leak!
Good luck (IMG:style_emoticons/default/beerchug.gif) |
Drums66 |
Oct 26 2011, 05:26 PM
I just did this w guidance from McMark while my 914 was in his shop. It was pretty easy with most all of the interior, including seatbelts, removed. Starting at the top middle, press on the 1/4" butyl tape onto clean metal all around the frame, then put your clean window back on and press to seal from the inside. I loved having it off so I could clean off the rest of the 20 years of cigarette smoking residue from the previous owner. Now, it does not leak! Good luck (IMG:style_emoticons/default/beerchug.gif) I 2nd this way! (IMG:style_emoticons/default/flag.gif) and it was'nt cigar smoke LOL (IMG:style_emoticons/default/smoke.gif) |
tod914 |
Oct 26 2011, 06:58 PM
You can get the butyl tape with a foam core. You won't have to worry about it melting on a hot summer day.
76-914 |
Oct 26 2011, 07:05 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,497 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Me 3. Some have said to join the tape in some mystical location in case it leaks. (IMG:style_emoticons/default/lol-2.gif) Just do it right, Clean, clean, clean. You can increase the sealing area i.e. a better seal at the joint, if you cut both ends of the tape at a 45' angle. Also, butyl tape is very stiff when cold. Warm is your friend. Press it as much as you've got the cojones for. Remember the little support bracket at the bottom.
bperry |
Oct 26 2011, 11:12 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Lo-Fi Version | Time is now: 11th May 2024 - 05:09 PM |
