20 Pages V « < 6 7 8 9 10 > »
> College budget restoration, Trudging forward
ThePaintedMan
post Aug 14 2012, 02:28 PM
Post #141
QUOTE(JawjaPorsche @ Aug 14 2012, 03:00 PM) *
And you did all this while on your back! I am impressed!
I guess the PO has enter witness protection to prevent a real ass whupping!
Yeah, wait till you see the pics. Its bad. I honestly never knew a car could be so neglected. Scratch that, if all he did was neglect it, I would be fine. Instead, this owner or owners made it worse with redneck engineering. I'm learning a real appreciation for doing things the right way the first time!
Out of curiousity, since we don't really have anyone in Florida that I know of who does good machine work, do any of you think it would be reasonable/remotely cost effective to ship heads to one of the many shops you guys have out in California?
rnellums
post Aug 14 2012, 02:34 PM
Post #142
Professional Enthusiast
It seems to me like rebuilding those heads would be WAY more trouble than it is worth. I would think that finding some 1.7 heads off a core engine wouldn't be too hard...
URY914
post Aug 14 2012, 02:35 PM
Post #143
I think I have some heads if you need them. I'll look this weekend.
ThePaintedMan
post Aug 14 2012, 04:34 PM
Post #144
Paul,
That would be fantastic! Let me know what you're looking to get for them. Either way, it would be nice to finally get over to your place to check out your car, even though it'll stay boxed up till it cools off a little more.
Also, I forgot to mention this. Guess how many copper sealing rings were under the manifolds? I pulled out 7 of them. No wonder why it wasn't sealing right and one side of the exhaust was higher than the other.
FourBlades
post Aug 14 2012, 05:06 PM
Post #145
From Wreck to Rockin
Sorry you are having so much trouble with the exhaust. (IMG:style_emoticons/default/sad.gif)
A better set of heads and sealed up exhaust will make your engine run much
better, maybe fixing some of the carb/ignition problems you were having.
John
URY914
post Aug 14 2012, 05:15 PM
Post #146
Right now I have nothing schduled for Sat. if you want to come over and play 914's.
Spoke
post Aug 14 2012, 07:29 PM
Post #147
Jerry
QUOTE(ThePaintedMan @ Aug 14 2012, 04:28 PM) *
What is it that attracts redneck engineering to finely engineered German vehicles like the 914?
Dr Evil
post Aug 17 2012, 02:37 PM
Post #148
Send me your transmission!
ThePaintedMan
post Sep 20 2012, 09:47 PM
Post #149
Been awhile, but as I cleaned out out my camera/sd card in preparation for my race on Saturday, I figured I'd post some of the madness I've had over the past month and half.
Below are pictures of the broken door hinge debacle. Note: it would have been easy to drive the pin out.... if it hadn't been broken in two different places! Not sure how that is possible, but I finally ended up cutting in in half. Found another half from the parts car at the end of the street and drove in two new pins from PP.
ThePaintedMan
post Sep 20 2012, 09:51 PM
Post #150
... Then moved onto the exhaust. Think its pretty obvious how messed up this is, but what you're seeing are the he's welded straight to the muffler, then cut/patched poorly. When I pulled the exhaust off, it cracked right in half.
ThePaintedMan
post Sep 20 2012, 10:13 PM
Post #151
Of course when the exhaust came off, it brought about another set of problems. Most of the studs were loose or already pulled out, so I ended up installing time serts for the time being. Paul (URY) found a set of heads he had, which I'm looking into getting rebuilt at a local machine shop. Paul, when I found out what condition they're in, we can figure out a price?
In the meantime, I'm stuck with these heads. I'm pretty sure #3 has a burned ex valve. Below is a picture - is there anything obvious from it?Attached Image
Also, last oil change was pretty curious. At the bottom of the tuna can was a bunch of crusty stuff. I ran a magnet through the sludge, and nothing stuck to it except a few very small slivers. I wonder where all this crap came from then?
Valy
post Sep 21 2012, 04:07 PM
Post #152
QUOTE(ThePaintedMan @ Sep 20 2012, 09:13 PM) *
Seems to me that the plug hole was already fixed once but someone didn't take the time to cut a flat set for the plug.
It can be fixed but make sure it's cut it straight this time.
ThePaintedMan
post Dec 12 2012, 07:58 PM
Post #153
Been quite awhile, and in fact, only a little over a year after I purchased the car, I can't believe how far its come. Dropped a transmission, drove it, dropped the trans/engine, repaired the passenger long, floorboards, put the drivetrain back in and now almost ready for paint in a little over 12 months. So, after the Tropical Ramble, landing a full-time gig and sort of figuring out school and money for the time being, I got a chance to tackle what I consider my specialty (and my favorite hobby, believe it or not) - bodywork. I started with the front and rear trunks.
ThePaintedMan
post Dec 12 2012, 08:09 PM
Post #154
I guess I don't have a good picture of the front trunk or rear trunk painted. But here is the prep work on the rear. This was probably one of the most difficult tasks I've done on the car. The PO sprayed some kind of rubberized undercoating all over it. The "lie detector", as Scotty B calls it, didn't work very well, neither did a standard wire wheel. The heat gun made progress but it was slow and I was removing a lot of good paint, which I felt was unnecessary, since there wasn't rust in the majority of the trunk. Finally I tried brake cleaner, which is dirty, greasy work, but removes that rubberized stuff like a charm. I wonder if the same would be true for you guys removing the floor tar? The last pic is after filling in pin holes and reapplying seam sealer where necessary, then a coat of POR.
billh1963
post Dec 12 2012, 08:11 PM
Post #155
Car Hoarder!
That's awesome progress compared to many cars on this board that have been on jack stands for years!!!
ThePaintedMan
post Dec 12 2012, 08:17 PM
Post #156
I've said from day one that this was to be a "rolling restoration." By that I mean, I wanted to get the car mechanically as sound as I could so I could enjoy it, even if it looks like a turd. The other part is that since I do not have the ability to own a compressor where I live, I have to drive to my previous company's shop (which they graciously allow me to use) in Tampa to do any kind of work that requires one. And, well, I'm tired of working outside. I also happen to work in Tampa, so when I get off at the end of the day I spend a couple hours doing a little bit of body work here and there with filler. Here is the last bit of welding that I had to do before I could start with the filler.
Madswede
post Dec 12 2012, 08:22 PM
Post #157
Flat Out Driver
(IMG:style_emoticons/default/smilie_pokal.gif) Lookin' good man!
ThePaintedMan
post Dec 12 2012, 08:26 PM
Post #158
Unfortunately I welded this up with flux-core prior to the Tropical Ramble, where John Faure (Fourblades) so graciously donated his great Hobart mig setup (IMG:style_emoticons/default/headbang.gif) . However, as John said, the proverbial and literal torch has been passed and I plan to put it to good use with the roll cage. Thank you once again John.
On a side note, if any of you are ever going to re-paint your cars or do any work around the door jamb area, make sure to check not only the little round vent for rust, but also the area I cut out. Poke and prod there and more than likely you will find plenty of weak metal. If you didn't have the sail panel trim, you might get lucky. This is a big blunder I think on Karmann's part - below you will see the white epoxy-like chunks I scraped out of this area, which trapped water, most of which came in through the holes in the sail panel.
ThePaintedMan
post Dec 12 2012, 08:31 PM
Post #159
Here is something interesting. I didn't know till recently looking at all the other cars at the TR that the fenders are not supposed to be flush with the cowl. The PO of my car had at some point filled all this in. So, I ground out the filler to see what was underneath. Sure enough, the fenders are welded to the cowl where there would normally be a seam. Luckily, they did a decent job and there was no rust under the filler, so I re-filled it.
ThePaintedMan
post Dec 12 2012, 08:42 PM
Post #160
Almost forgot about this. The front of this car was tagged pretty good at some point, obviously.Attached Image
The headlight bucket was pretty buckled. If I were in a different spot financially or this car had been in better shape to begin with, I would have just sourced a replacement piece. Attached Image
But, as I wanted to learn more about metal and collision work during this process, I thought this would be a good chance.
Started by drilling out spot welds (anyone else who has tackled any metal work will know this is usually the first step).
- Lo-Fi Version Time is now: 27th September 2026 - 06:50 PM
