Sway Bar bushings...the ones on the bar, how do you get them on? |
jim912928 |
Aug 31 2004, 10:48 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Ok, all holes are drilled, painted...everything is done and ready to go but I can't get the bushings on the bar...what is the trick? I've beat, pounded, greased and I'm at a loss on how to get that square end through that small round hole.
Oh, factory sway bar. Thanks again for all the advice. Jim |
Doug Leggins |
Aug 31 2004, 11:22 AM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I've only taken them apart and not put them back together on a car. The bushings that I have seen are slit in a way that they can be slid over the body of the bar, not slid on from the end. The bushing will need to be removed from the triangular mount in order to open it up along the slit. After the bushing is installed on the bar then press the triangular mount over the bushing.
Again, I haven't installed a set, but based on what I've seen this is what I would try. |
jim912928 |
Aug 31 2004, 12:17 PM
That makes alot of sense...just like the rear bar bushings.....Thanks!
Joe Ricard |
Aug 31 2004, 12:18 PM
Yup. get a razor and cut the one side length wise. (especially the poly units) put on bar from side. the triangle bracket will hold it together
jim912928 |
Aug 31 2004, 01:16 PM
Just finished...this sure made it simpler! Thanks all (including Brad Mayeur who also suggested slitting these)!
Jim |
Eric_Shea |
Aug 31 2004, 05:40 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Johnny Come Lately says (IMG:style_emoticons/default/agree.gif)
If you order factory bushings they come with the slit in them. If you simply order the "bushings" from a popular parts house they send you Weltmeister parts. The Weltmeisters need to be slit. I called them back when I got mine and dufus on the phone said they couldn't get factory ones. Me thinkz if I gave them a 901.341.xxx.xxx part number they could come up with them. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 03:29 PM |
