Strange Wire? What's it go to?, And manifold to head torqueing? |
bandjoey |
Mar 18 2012, 09:11 AM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
2.0 motor. By the #3 spark plug hole is a wire with end connector coming from another hole in the tin. Wha'ts it for?
In Haynes it says 4.35 ft lbs of torque on the nuts holding the manifold to the head. That's only 1/2 grunt on a wrench, much less a real torque - sounds like to me. Error in the book or that's right?? Thanks Guys Attached thumbnail(s) |
dangrouche |
Mar 18 2012, 09:17 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
http://www.autohausaz.com/search/product.a...lid=1263181@914 &year=1974&cid=22@Fuel %26 Air System&gid=5084@Cylinder Head Temperature Sensor
looks to be your temp. head sensor lead. |
Cap'n Krusty |
Mar 18 2012, 09:58 AM
2 MKP, more or less. I use 18 ft/lbs for all the conventional 8mm fasteners. The injector hold down nuts go to about 7ft/lbs (1MKP). Just another reason NOT to use Haynes.
TheCabinetmaker |
Mar 18 2012, 10:40 AM
You have carbs. you don't need it. Just leave it.
euro911 |
Mar 18 2012, 10:41 AM
I thought gentlemen preferred Haynes (IMG:style_emoticons/default/confused24.gif)
Gentlemen Prefer Haynes |
Lo-Fi Version | Time is now: 10th May 2024 - 03:37 PM |
