bandjoey
Mar 18 2012, 09:11 AM
2.0 motor. By the #3 spark plug hole is a wire with end connector coming from another hole in the tin. Wha'ts it for?
In Haynes it says 4.35 ft lbs of torque on the nuts holding the manifold to the head. That's only 1/2 grunt on a wrench, much less a real torque - sounds like to me. Error in the book or that's right??
Thanks Guys
dangrouche
Mar 18 2012, 09:17 AM
http://www.autohausaz.com/search/product.a...lid=1263181@914 &year=1974&cid=22@Fuel %26 Air System&gid=5084@Cylinder Head Temperature Sensor
looks to be your temp. head sensor lead.
Cap'n Krusty
Mar 18 2012, 09:58 AM
2 MKP, more or less. I use 18 ft/lbs for all the conventional 8mm fasteners. The injector hold down nuts go to about 7ft/lbs (1MKP). Just another reason NOT to use Haynes.
TheCabinetmaker
Mar 18 2012, 10:40 AM
You have carbs. you don't need it. Just leave it.
euro911
Mar 18 2012, 10:41 AM
I thought gentlemen preferred Haynes
Gentlemen Prefer Haynes
