Questions about Alternator and Brake Bleeding |
tornik550 |
May 23 2012, 11:44 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Two short questions-
My battery is not charging. How can I check to see if the alternator is working. I suspect there may actually be a wiring issue somewhere cause all the wiring has been screwed with on my car. I bled my brakes and everything seems solid. I noticed that when I am at a stoplight, The pedal starts to slowly creep get softer. It only travels about an inch or so more. If I let of the brake and reapply, then the brake is hard again. - one problem that may or may not be associated is when I was bleeding my brakes, I bled the right rear brake first. I used a hand held pump. I pumped it to 25 mmhg, slightly turned the bleeder screw and the fluid started to flow. The issue was that the 25mmhg quickly bled down to about 10mmhg. It seemed logical that the pressure would decrease however all of the other brakes maintained the 25mmhg even when the brake fluid was coming out. Not sure if that is an issue? Thanks |
JawjaPorsche |
May 23 2012, 12:03 PM
If you will go to local auto parts store, they will check to see if it is charging for free.
Brakes. Did you have help with bleeding or did you use speed bleeders? You did not mention in your post. Sounds like you still have air in your brakes. |
two-strokejohn |
May 23 2012, 12:20 PM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
Sounds like a little bit of air left in the system. Two man bleeding is the way to go. If you need help Steve, give me a shout and I'd be glad to help..... here or at your place....John
kerensky |
May 23 2012, 01:11 PM
Senior Member Group: Members Posts: 531 Joined: 1-February 06 From: Norman, OK Member No.: 5,508 Region Association: Southwest Region |
From my Bug experience, those cars get better brake bleeding results if you jack up the rear of the car higher than the front, then start at the right rear. I wonder if 914's might benefit from that tactic...
76-914 |
May 23 2012, 01:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Put a volt meter on the bat with engine running above idle. You should see 13-14v nom. Read this http://www.914world.com/bbs2/index.php?showtopic=117551 more especialy, Spokes post within that thread.
Lo-Fi Version | Time is now: 29th May 2024 - 07:01 AM |
