FFC04 Swap Meet, Post your needs / whatcha bringing |
Engman |
Oct 12 2004, 08:00 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Just like the title says -
I need - Front tronk floor - I think Brad is coming with it an 043 MPS an old shifter assy - need parts inside it clutch pedal stops I will bring - some of the parts I make M |
seanery |
Oct 12 2004, 09:32 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,852 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I need:
Ale-8-one (couple cases) Diet Barq's Red Cream Soda (4 cases if possible) I know this sounds wierd, but they don't sell either here. Can someone from Southern Ohio, Southern Indiana, Kentucky pick this up? I'll pay you for it (in advance if necessary) Thanks! (IMG:style_emoticons/default/beerchug.gif) |
Engman |
Oct 13 2004, 02:16 PM
Sorry Sean - none down here - maybe someone will speak up.
M |
kafermeister |
Oct 13 2004, 09:13 PM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
Sean, I've got the blessing from the wife to go to the FFC. Now if work doesn't interfere, I'll bring you some Ale-8. There's a place that elegedly sells them not far from the sign shop (in Dry Ridge, Ky).
Engman, what year shifter? If I didn't throw it away, I've got an early unit from a tail-shifter car. Rick |
Doug Leggins |
Oct 13 2004, 10:07 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
QUOTE Engman, what year shifter? I have a few that I can check to see if i have the one you need. I have 1 maybe 2 clutch stops. They are a bit rusty but should clean up. The folks that make it to my place can pick through a lot of parts. I'll likely take some of the smaller stuff to the gathering in Columbus. Engman's got a good idea here - "post what you need" This could be a great way to get parts at a good price and no shipping costs. |
mudfoot76 |
Oct 14 2004, 07:36 AM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
I have a rear sway bar. I think it is Weltermeister, but not sure. Don't know the size either, but this I can measure.
If I have room in the car, I might be able to bring my old engine case. GA case with shredded main bearings, and it needs an align-bore. I also have a set of USA 2.0L pistons and cylinders from the old engine. I think I have a crapped out alternator as well. Wow, I didn't know that only 2 years into ownership, I already have piles of "junk" parts sitting around. A side effect of owning a 914? On another note -- do I need to remove the front bumper in order to mount a front spoiler? I was looking at this last night and wasn't sure how to get everything fastened together... |
seanery |
Oct 14 2004, 08:06 AM
Geoff,
you don't need to remove the bumper. There are a couple screws in the wheels wells and and a couple in the front trunk. Both going from inside to out. |
qa1142 |
Oct 14 2004, 09:13 AM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I need sunny weather
I can only bring a few things since I have me and the wife and our luggage. Couple of tachs, speedos, other misc small stuff i plan to bring. |
mudfoot76 |
Oct 14 2004, 09:20 AM
QUOTE(seanery @ Oct 14 2004, 09:06 AM) There are a couple screws in the wheels wells and and a couple in the front trunk. Both going from inside to out. The ones in the wheel wells are easy, it is the ones through the front trunk that I have trouble with. I can barely get my fingers between bumper and body as it is, and with the spoiler in place I can't see anything. I'll give it another try this afternoon. Maybe I just need a big hammer (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 09:50 AM |
