Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
ConeDodger |
Sep 22 2012, 09:10 PM
Apex killer! Group: Members Posts: 23,568 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
What intercooler are you running Mike?
Mike Bellis |
Sep 22 2012, 09:20 PM
What intercooler are you running Mike? I running the same air to water intercooler I had with the rotary. The heat exchanger and fan are located in the drivers quarter panel behind the NACA duct. I may end up moving it to work better with the mathanol injection. Most "experts" (used loosely), say to inject after the inter cooler and before the throttle body. Right now the plumbing from cooler to TB is super short. If I rework the plumbing a little, I can increase the distance and get better evaporation/cooling from the meth. This may take a complete relocation of the intercooler. First things first. Get the motor mocked up and see what fits. |
Lo-Fi Version | Time is now: 28th April 2024 - 09:46 PM |
