Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Mike Bellis |
Jun 15 2012, 11:37 PM
Sent the Passat to the wrecking yard today. Fuching tow truck driver stole my wheel chock. They did pick it up for free. Not much left but some interior and suspension. Body was rough, no cherry panels. Glad its gone. Now it's time to clean up the garage and get the 914 inside and stripped apart... again... (IMG:style_emoticons/default/dry.gif)
Parts heaven wants $100ea for the axle stubs and $250 for the complete Boxster shift setup. This includes all the parts from the PET shifter page. I can get the shifter stuff from ebay cheaper but not complete. It will take weeks/months of waiting for items to pop up online. I can buy a complete but unknown Boxster tranny from ebay for as little as $400 (on a good day). Most have the axle stubs and 1/3 of the shifter parts (Tranny linkage). PH wants $2500 for a Boxster tranny with warranty (no shifter). I think I will wait for the right opportunity to jump on cheap parts. I am a CSOB 914 owner (IMG:style_emoticons/default/biggrin.gif) I do need the Boxster tranny mounts to get started. The Audi mounts interfere with the Boxster shifter. Those are cheap online; About $30 each. Anybody ever pulled the axle flange on a Boxster or Audi transaxle? No bolts but there is a circlip on the stub In the diff. Not exactly sure how to pull it. Slide hammer? Puller tool? Pry bar? (IMG:style_emoticons/default/smash.gif) |
jcd914 |
Jun 16 2012, 01:36 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Anybody ever pulled the axle flange on a Boxster or Audi transaxle? No bolts but there is a circlip on the stub In the diff. Not exactly sure how to pull it. Slide hammer? Puller tool? Pry bar? (IMG:style_emoticons/default/smash.gif) VW says: Place a chisel or spacer -A- behind drive flange. Pull drive flange shaft out of differential gears by turning bolt -B-. Jim |
Mike Bellis |
Jun 16 2012, 09:46 AM
Anybody ever pulled the axle flange on a Boxster or Audi transaxle? No bolts but there is a circlip on the stub In the diff. Not exactly sure how to pull it. Slide hammer? Puller tool? Pry bar? (IMG:style_emoticons/default/smash.gif) VW says: Place a chisel or spacer -A- behind drive flange. Pull drive flange shaft out of differential gears by turning bolt -B-. Jim I was considering doing this but it think it was the "correct" way. (IMG:style_emoticons/default/confused24.gif) I guess I will go for it... Maybe I'll use 2 so I don't bend anything. Thanks! |
Lo-Fi Version | Time is now: 26th April 2024 - 03:58 AM |
