Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Mike Bellis |
Sep 22 2012, 08:33 PM
Pulled the drive train today. Kind of depressing since it still runs... (IMG:style_emoticons/default/sad.gif) Some of these parts have new owners (IMG:style_emoticons/default/piratenanner.gif)
The Audi/Boxster tranny is almost the same length as the 901. Only about an inch or so longer. From the bell housing to axle center looks exactly the same. At least you can't "eye ball" any difference. I may have to move it forward for engine clearance. No more than an inch. Looks like fitting it in will be no problem compared to what I have done already. The biggest bonus will be the modern transaxle. get in line now if you want to test drive it later. This thing shifts... well, it shifts just like a Boxster. (IMG:style_emoticons/default/smile.gif) Night and day compared to a 901. My ECU goes to 034 Motorsport next week. $850 to turn it into a 350hp ECU with no smog or un-needed junk. OUCH! (IMG:style_emoticons/default/blink.gif) But I get to keep the drive by wire. I may have to have them put it on the dyno to fine tune the flash once it's driveable. Here's some side by side pics for those that want to see... Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 07:37 AM |
