Sasquatch Part III Audi 1.8t transplant..., PCV upgrades finally... |
Mike Bellis |
Jun 10 2012, 05:41 PM
I have A.D.D. I admit it. I also can't leave well enough alone. I got really motivated by Andrew Dalen and seeing a 914 with Subie power driving to WCR12 from Idaho. What a beautiful car...
I stumbled on a steal of a deal for a 2001 Passat 1.8t, Audi ATW engine and 5 speed transaxle. Long story short and here you go. New engine cleaned and ready for fab time. The exhaust and turbo have been removed before power washing. Here is a link to Part I http://www.914world.com/bbs2/index.php?act...=0#entry1396734 Part II http://www.914world.com/bbs2/index.php?showtopic=172455 Here is the challenge. The transaxle. Either I fab an adapter, Fab an axle to take 1 Porsche CV and 1 Audi/VW CV or Replace with Boxster tranny, that will: Bolt right on, Shifter is cheap and available and requires less fab time. I'm leaning to the Boxster due to the 100mm Porsche CV flange. The Audi is 114mm. This is whats left of the wiring after the car gets gutted. The ECU and gauge cluster have a symbiotic relationship. They work together and have to stay together to run. It looks like it will fit nicely into the stock location. I may have to adjust the column lower and build an trim ring around the cluster. |
Mike Bellis |
Sep 23 2012, 05:49 PM
I have read about a couple guys blowing through the MAF without any problems. I am considering doing this and using a traditional BOV. wooosh! That way it doesn't go rich when it blows. They make a nice aluminum housing for the sensor instead of the stock plastic one. This engine will be set up more like a race engine than a commuter. Really all depends of what fits in the engine bay and how to plumb it.
Andyrew |
Sep 23 2012, 07:37 PM
I have read about a couple guys blowing through the MAF without any problems. I am considering doing this and using a traditional BOV. wooosh! That way it doesn't go rich when it blows. They make a nice aluminum housing for the sensor instead of the stock plastic one. This engine will be set up more like a race engine than a commuter. Really all depends of what fits in the engine bay and how to plumb it. I've had issues with MAF... Gone through PLENTY. (I have a box of 6 blown MAF's... Quite a chunk of change...) See if 034 will tune your setup for a VR6 MAF housing(3" vs 2.75" or something like that). Or even better see if you can use a ford 4" MAF, You wont break that, and its much cheaper.. The issue is the stock MAF is maxed out shortly after 300hp, and running it at that point fries the internals for some reason.. A bigger housing lets you run more air through the same mass air flow, but the ECU needs to be tuned properly. BTW when you get tired of 350hp you can always put some rods in, put 1k in the head and put a GT35R in for a nice solid 600hp and rev it to 9k (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 03:15 PM |
