rear roof rubber stops |
last337 |
Jan 14 2013, 07:08 PM
Member Group: Members Posts: 421 Joined: 4-December 12 From: New Orleans Member No.: 15,221 Region Association: None |
Mike Bellis |
Jan 14 2013, 08:20 PM
Not really sure what you are referring to. I see a Targa bolster in the center and the top latch above. Plastic screw plugs (right and left) and weather stripping on the far right.
last337 |
Jan 14 2013, 08:39 PM
Sorry im asking about the rubber block like pieces that go around the latches. They are broken off around the latches
mrbubblehead |
Jan 14 2013, 08:53 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
I need a couple of sets also. I wish mark would start making these. I do know there is an early and late style. One is a little taller than the other, I dont remember which is which. it looks like yours are the shorties. If you find a supplier would you post em up?
Mikey914 |
Jan 15 2013, 01:18 AM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Just a matter of making it pay off. Tooling is the big cost. 2 different sets of tooling adds up faster. If there were 50 people that needed 1 set each (for each type), it would be do-able. Cost I'd ballpark at $17 a piece. ($34 a set).
If there is enough interest I'll do it, but my gut tells me there is't enough demand for these..... maybe I'm wrong. |
bluhun |
Jan 15 2013, 02:53 AM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
Just a matter of making it pay off. Tooling is the big cost. 2 different sets of tooling adds up faster. If there were 50 people that needed 1 set each (for each type), it would be do-able. Cost I'd ballpark at $17 a piece. ($34 a set). If there is enough interest I'll do it, but my gut tells me there is't enough demand for these..... maybe I'm wrong. I'll take a pair for my '75 6-cylinder conversion car. |
last337 |
Jan 15 2013, 06:46 AM
Id be in for a pair for my 1973. Are you die-cutting that from sheet rubber? That tooling would only cost less than a few hundred for a multi-cavity steel rule die.
Mikey914 |
Jan 15 2013, 12:53 PM
These would have to be a molded part. I can look at just the rubber block rather than the whole strap (with the steel to mount it). That's the major portion of the cost on these the hook is imbedded in the rubber.
mrbubblehead |
Jan 15 2013, 02:41 PM
These would have to be a molded part. I can look at just the rubber block rather than the whole strap (with the steel to mount it). That's the major portion of the cost on these the hook is imbedded in the rubber. Yes, the hook and the part that bolts to the roof are inbedded. I believe they are aluminum. Unless you made the whole thing out of aluminum. Then wrapped the part that touches in felt or somenting. At least they would last then.... |
last337 |
Jan 15 2013, 03:05 PM
Granted I have never had a pair that arent all busted like mine in the picture, but it would seem that a rubber block with a hole for the hook to slide in would work as well.
worn |
Jan 15 2013, 03:56 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Just a matter of making it pay off. Tooling is the big cost. 2 different sets of tooling adds up faster. If there were 50 people that needed 1 set each (for each type), it would be do-able. Cost I'd ballpark at $17 a piece. ($34 a set). If there is enough interest I'll do it, but my gut tells me there is't enough demand for these..... maybe I'm wrong. Well, I have started hoarding them because they all go bad with time and the time is roughly the same with all of them. Had to replace two in one year. Also AA no longer has any left. So I am the guy who keeps asking you to think about making them. They have an aluminum frame with a die cast center molded with rubber in between so it isn't simple. The problem is that the pot metal tends to break. Maybe there is a simple fix or substitute, but I would be in. |
gms |
Jan 16 2013, 10:17 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I have a bunch if needed
dave1075 |
Mar 4 2013, 10:28 AM
Newbie Group: Members Posts: 15 Joined: 15-April 09 From: Cologne, Germany Member No.: 10,267 Region Association: Germany |
I am looking for those for quite a while. So I would be happy if someone decides to make them. I would definitely go for 2 pairs.
worn |
Mar 4 2013, 04:16 PM
Just a matter of making it pay off. Tooling is the big cost. 2 different sets of tooling adds up faster. If there were 50 people that needed 1 set each (for each type), it would be do-able. Cost I'd ballpark at $17 a piece. ($34 a set). If there is enough interest I'll do it, but my gut tells me there is't enough demand for these..... maybe I'm wrong. I've asked for this before and would take two sets hands down. It seems like the supply is now reaching the critical point, and you could design them so they don't break, but I would understand if you wanted to go for authenticity. So, count me in! |
timothy_nd28 |
Mar 4 2013, 04:52 PM
I'd be in for a set
finchmunoz |
Mar 5 2013, 09:59 AM
Newbie Group: Members Posts: 34 Joined: 3-July 11 From: Manila, Philippines Member No.: 13,272 Region Association: None |
Id be in for a set!
Chris Pincetich |
Mar 5 2013, 02:34 PM
FYI - I just "restored" an old set like Glenn posted above and they look amazing. Clean, buff, repaint. Maybe others have broken theirs?
Mar 5 2013, 03:26 PM
I've been using short pieces of small rubber hose over the little pins that the latch hooks into.
That takes up the slack of the often missing powdercoat layer on the latches and hooks and helps keeping the top on tight. (IMG:style_emoticons/default/popcorn[1].gif) |
MoveQik |
Mar 5 2013, 04:12 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
I've been using short pieces of small rubber hose over the little pins that the latch hooks into. That takes up the slack of the often missing powdercoat layer on the latches and hooks and helps keeping the top on tight. (IMG:style_emoticons/default/popcorn[1].gif) I used heatshrink tubing on mine. Similar idea. (IMG:style_emoticons/default/smile.gif) |
montoya 73 2.0 |
Mar 5 2013, 06:10 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
I've been using short pieces of small rubber hose over the little pins that the latch hooks into. That takes up the slack of the often missing powdercoat layer on the latches and hooks and helps keeping the top on tight. (IMG:style_emoticons/default/popcorn[1].gif) I have done the same. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:36 AM |
