FS New Brass Tumbler Set w/ Springs, Re-Do All of your Locks Once and for All |
tweet |
Apr 12 2013, 11:55 AM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
These are brand new brass tumblers and copper springs for 914 and 911. Finally have one set of keys to open all of your locks. This is way cheaper than having a Porsche dealer cut you a key. (I called a Porsche dealer; they said $83.00 to duplicate one master key and $200 to order one by VIN.)
You will receive the following in each set ordered: #1 Tumblers - four each #2 Tumblers - four each #3 Tumblers - four each #4 Tumblers - four each 10 new springs #5 Tumbler not included; reuse your own, it is found in your secondary locks (glove box, front trunk, rear trunk) for use with a master key. Also included (not in picture, but is included in first set only; you only need one) : 1 new pair of tweezers 1 plastic container (so you can find your tumblers the next time you need to re-key a lock) Each set is $37.95 shipped to your door. (CONUS) This is a discounted price for forum members from my Ebay shipped price of $44.95 - 15% off. Paypal to TYPE4PLUS@gmail.com money order check If you need individual Tumblers ($3.50 each shipped) Springs (5 for 3.50 shipped). These are from a reputable source, from an American supplier. Remember you can still reuse your old tumbler pins that don't need to be changed or keep them as spares. You should have left overs for future locks. References on re-keying lock cylinders: MarkB's article, here on 914 world. http://www.914world.com/specs/rekey.php How to: Repair or re-key door locks http://forums.vwvortex.com/showthread.php?3496179 Rekeying Porsche Locks http://www.pelicanparts.com/techarticles/m..._lock_rekey.htm This is a youtube video of of two styles of ignition locks being removed from a mid 70's beetle. This ignition is like the one on a 914. The process is basically the same as for our cars. http://www.youtube.com/watch?v=0rB3KYA3Xpw Attached thumbnail(s) |
db9146 |
Mar 2 2014, 10:51 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Tweet,
Since all my keys are old and worn, could I have a new key cut and then refurbish the cylinders with your set to wind up with new keys that work well? Any problem with this approach? |
tweet |
Mar 2 2014, 10:58 PM
Tweet, Since all my keys are old and worn, could I have a new key cut and then refurbish the cylinders with your set to wind up with new keys that work well? Any problem with this approach? That is the best logical approach. New tumblers help compensate for excessively worn keys and deeply scored cylinder housings. So if you have a new duplicate cut, and then use it for your re-key, it will also help you out in the re-key process. With the new key in hand, and your lock apart, you will see exactly if the tumblers sit flush as they should. When you reassemble the locks, your new key will let you know immediately, if things are keyed correctly and if your key is cut correctly. |
Lo-Fi Version | Time is now: 10th May 2024 - 05:38 AM |
