> Replacing Weltmeister sway bar bushings
Scott S
post May 15 2013, 11:43 AM
Small Member
Hi All -
I am getting ready to replace the bushings on my weltmeister sway bar. The bushings I am referring to are the ones that are actually on the bar itself - not the drop links.
I did a bunch of searching but did come up with much.
Has any one done this? Once I remove the three bolts in the wheel well, do the bushings simply slide on and off of the bar? They are a pretty hard material.
Thanks!
Scott S
shuie
post May 15 2013, 12:41 PM
http://www.914world.com/bbs2/index.php?showtopic=163439
jmill
post May 15 2013, 09:26 PM
Green Hornet
I have a 22mm Welt bar and bought new bushings for it also. I haven't installed them yet. I will say that the larger bar will slide through one side and out the other with semi worn bushings. I highly doubt you need to split them with a large bar. If it's the smaller stock bar then you need to split them.
r_towle
post May 15 2013, 09:27 PM
Custom Member
Custom bronze, after I crushed the first set.
lrm914
post May 17 2013, 09:50 PM
QUOTE(Scott S @ May 15 2013, 01:43 PM) *
Hi All -
Thanks!
Scott S
Hey Scott,
Coincidentally I am doing the same replacement you are. Can you please tell me
where you purchased the new bushings for your 22mm Weltmeister sway bar. I need to replace mine as well.
Does Automotion carry them? Pelican? Do the stock bushing fit on the aftermarket sway bar?
Thanks Larry
Scott S
post May 20 2013, 11:03 AM
Small Member
Hi Larry -
I got them from automotion (prepare yourself - unless you are ordering a bumper for a 1996 chevy pickup, their customer service folks are absolutely worthless...)
Here is the part number for the 22mm: PZC-SB-1100D
If anyone should need the 19mm, here is the part number: P9132343
They may tell you that the part numbers sound incorrect. That means they did not actually take the time look it up. Trust me, the numbers are correct. I bought a set of each size just last month just to have them on hand.
If you dont mind - can you update me on how your install goes? I am still nervous about simply opening mine up (previous owner install - no idea how it goes togther....)
Good luck!
- Lo-Fi Version Time is now: 17th June 2026 - 02:30 AM
