3rd Brake light with pulse strobe, My $5 buck 3rd brake light with $5 strobe |
dangrouche |
Jun 15 2013, 01:04 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
How many of you are paranoid of being rear ended? I certainly am. Here's my installation of a 24-LED brake light that I installed with a few bits from my workbench. I got this 24-LED from a Bang Good.com. That website gives free shipping. The current model is on sale for $5.19 and that model is SKU010514. I bought the 24-LED version, which they no longer stock and it cost me $4.55. Its $7.49 at AMAZON. NO RELAY OR OTHER ELECTRICAL PARTS NEEDED. I know I have seen these in the FLAPS for at least double or triple that. Anyway, as long as you can wait a couple of weeks, you can either buy it there or go to the FLAPS. I finished the install last night. This morning when I went to open the rear trunk, I see that I should installed the light closer to the rear window. Almost tore the thing off! Pic one shows the wrong way to do it. Pic two shows the wiring from the left rear tail light housing. I put on brass spades (get from FLAPS) that sisters the existing connections and no OEM wiring was cut or spliced to do this install. Pic three shows routing for two leads into the engine compartment into the engine compartment. Pic four shows how I drilled the plastic with a 1/8" bit and threaded the wiring. I also used speed clips (from car speaker install kits) and you see the galvanized metal in the pic. I stuck a patch of velcro as a vibration pad. Pic five shows the velcro in place. I also added a flat washer and a lock washer when I screwed it into place. Pic six shows the completed installation. I also covered the entire wiring in small plastic tubing and zip tied everything in place, leaving a large loop of wire so the engine lid can be opened. I considered installing this under the targa bar, but routing the wire would have been too much work and I did not want to use the double sided foam tape that came with the light. This install can quickly undone with a pair of dykes in a few minutes.
Attached thumbnail(s) |
anderssj |
Oct 2 2013, 06:56 PM
Dog is my copilot... Group: Members Posts: 1,654 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Nice work, and thanks for the tip on the LSC-100A . . . I need to look into that!
Rick, nice look on the white car--very discrete. Do you have any info on the light? (vendor, PN, price, etc.) Also, how did you mount it? 3M foam tape? (IMG:style_emoticons/default/biggrin.gif) Where did you run the wiring? I'm always looking for better ways to skin this cat . . . and both shown will help with my current set up. Thanks! Steve A- |
RickS |
Oct 2 2013, 10:32 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Nice work, and thanks for the tip on the LSC-100A . . . I need to look into that! Rick, nice look on the white car--very discrete. Do you have any info on the light? (vendor, PN, price, etc.) Also, how did you mount it? 3M foam tape? (IMG:style_emoticons/default/biggrin.gif) Where did you run the wiring? I'm always looking for better ways to skin this cat . . . and both shown will help with my current set up. Thanks! Steve A- ------------------------------------------ Hi Steve thanks for the kind words. This is the source and a video of the compact but bright flashing LED brake light. I did not use the red wire for the running light, only the flashing brake: Knight Rider Non-Sequential LED http://www.customdynamics.com/knight_rider...l_led_video.htm I used Dan's wiring method to the tail light and then discretely popped out the wires though the fixed wing of the engine grill next to the targa bar. I then removed the targa chrome trim and ran the wires under the trim and popped them out in the center of the bar - since it is very low voltage, I used a thin gauge speaker wire. The light indeed is attached by 3M double stick tape. The cost was $30.00 but felt that was cheap to save my ass. Here is the link to the page for the NON-SEQUENTIAL DUAL INTENSITY (not yelling but they sell several types). Scroll down around mid-page: http://www.customdynamics.com/knight_rider_led_light_bar.htm |
Lo-Fi Version | Time is now: 4th May 2024 - 12:26 PM |
